I agree.  I am a HAM as well as a new GMRS user (moving more to GMRS, just because folks seem nicer).  Just last evening, I added a stale repeater (open, no permission required to use) to my handheld and received an acknowledgement of my transmission and them promptly instructed to turn off the roger beep.  It took me by surprise.  Didn't know it was a thing with folks.  I wanted to respond back, but didn't want to start a thing... And I didn't know if it was his repeater (and it is always him) or not.  Just want to chat and learn...
No good buddy beeps unless you want to find yourself with no one to talk to.
Sent from my SM-S911U1 using Tapatalk
4 hours ago, UncleYoda said:
But I have a new radio that let's me select different sounds for the beep!  You know I've got to try it out.
Let me know which one gets the most reactions. 😆
1 minute ago, Northcutt114 said:
It is interesting to me that so many people in the GMRS community, if one can call it that, have such strong opinions about something so silly. Is it because CB bois use it and GMRS people are much serious "radio operators?" What's the aversion? I really don't get it.
I've often wondered the same thing.
Actually, the only people that won’t talk to you if you have a Roger beep are the folks who want to control others’ use of the Roger beep.  I would rather talk to the other people anyway. 😀
I would but I'm probably putting this radio away in a faraday cage box so I can grab it and throw in the car.  I selected option 3, a static burst that makes it sound like an old pro radio.  The first two are double beeps, indistinguishable from one another to my ears. I'm not sure the static will get the same hate reaction.  I would enable on my GMRS handhelds if they had it.
If anything, even worse on ham.  AFAIK, they just hate the sound.  But repeaters that have a courtesy tone (not much different) are fine.
I can see, especially on a repeater or a net, where - if you have fifteen different users with fifteen different roger beeps, AND the repeater might have some tones or squelches or something - it could be a little bit chaotic. But, on a quiet, simple repeater to immediately be told, with no tact, to "turn off your roger beep" is wild to me. Same vibes as the guy who wears the CCW sash. Calm down, Boss Hog. You'll get them Duke Boys one day.
Roger beeps don't bother me when on simplex.
Yes it can be a little chaotic and annoying with a bunch of different Roger beeps along with the repeaters courtesy tone every time someone un-keys their mic.
I normally won't say much on our repeater if it is slow and there are only two people talking at the time. But I definitely don't want to hear a bunch of Roger beeps when there are multiple people on at one time or during a net.
I recently trolled a ham Facebook page with that very fact. 😆 In reality, I think it has to do with the fact that hams almost exclusively use repeaters while GMRS users use simplex a lot. If the repeater has a courtesy tone, roger beeps just create chaos. I was challenging the people on the page to justify hatred of the roger beep, but nobody came up with anything beyond, "they suck and so do people who use them".
I'll use the Roger Beep on simplex with new users.
Me: Don't forget that you can't talk at the same time, you have to wait for them to stop talking.
New User: How do I know when they've stopped talking?
Me: When you hear the beep.
New User: Oh, okay.
I keep it off on my repeater units. I don't know why some people get so torqued-up over it, but I don't want a sad HAM to have an aneurism.
There is a system by me that MDC or DTMF is REQUIRED to use the repeater.  It sees your assigned ID given to you by the owner and will open the repeater.   It also tracks who is using the repeater to cut out the people from playing around being "dumb".
13 minutes ago, UncleYoda said:
What is MDC?  I don't think any of my radios have that.  They do have other types of codes.
Motorola Data Communications
MDC = Motorola Data Communications.
It Is An ID Assigned, Programmed Into & Associated To A Specific Radio To Allow Transmissions On To A Repeater.
It May Be A Pre, Post Or Both On A Transmission For ID So A Controller Can Recognize & Validate The Incoming Signal.
Some Use It As A ID Only For Other Radios To Recognize The Individual Ttansmitting.
I thought that M might be for Motorola.  So these guys are setting up repeaters for only Motorola users?  That's the ultimate snobbery.  I don't own one, never have, never will (don't like the company or the Motorola-only attitudes of users.)
No, Not At All. Kenwood Vertex Standard, Icom & Others Recognize This Type Of ID. MDC Is Commonly Referred To As The "Squawk" After A Transmission.
There Are Also Other Types Of ID For This Purpose. They're Just Not Called MDC.
Baofengs can do that, but it's at least called something different, don't know if they're compatible.
Don't Believe They Are.
I Personally Don't Mind If Folks Use Them On My Repeaters, But I Do Not.
May Sound Cool Like PD & FD - But To Me It Sounds Like Someone Is Pulling The Gizzard Out Of A Chicken From The Wrong End......
SQUAWK........
Reverse burst is usually generated on commercial 2-way transmitters to eliminate the squelch tail noise burst in systems using PL, or Private Line.   "Reverse burst" is a Motorola term, and GE calls the same thing "STE" for Squelch Tail Elimination.
Reverse burst or Squelch Tail Elimination ("STE") is a process that uses a change of the phase of the PL tone encoder for a short period of time after the user unkeys the PTT button. The term "reverse burst" is used to describe the deliberate phase change for a specific abount of time while the transmitter carrier stays on - about 150 to 200ms - with the phase of the PL encoder offset by from 120 to 180 degrees (180, naturally is a complete reversal). During the reverse burst time period the reverse phase stops the PL decode reed dead in its tracks - which slams the receiver squelch closed right now.   By the time the transmitter actually drops off the air the RX squelch is already closed - which results in no burst of squelch noise being heard.
Mobile Digital Communicator.  its en encrypted communications which is pretty much illeagle for public use.  You can legally play with it on MURS or a business radio license.
