Is It Possible To Import A CSV File To The Vertex CE59 Program?
tcp2525
I know this is going to sound like a really dumb question, but since this program has an "export" function I'm assuming it also has a way to import this data as well? I see no options to import CSV data. Am I overlooking something or is there a convoluted way to import. I'm hoping someone with more experience using Vertex software has a solution as it's easier to do all my editing in Excel and import. Thanks.
6 answers to this question
Yes, I figured that, but I had to ask to rule out stupidity on my part as I've been known for high levels of it.😀
I'm now totally bewildered at why they would even put in an export feature when I already have my frequencies typed and/or written down. I know the backup file holds everything including the settings, so  I'll just rely on that like I have always done. Thanks again for the help.
I'm with you in that having an Export feature is "usually" side by side with an Import feature.
I tried to find a copy of this software to play with for your benefit, but I only see it for sale used on eBay. Do you have a copy to share for  fair use - educational/test purposes?
On 1/22/2023 at 5:49 AM, gortex2 said:
There is no import feature. You need to type it in.
Hey, Jeff: Do you know what this File Convert function does?
I think I know, but would rather get an educated answer...
I can check again this evening; I think I clicked on it the other day and it was to convert between a handheld format (vx820/920) file and a mobile format  (vx4200) file, as that software package  does all 3 model lines.
