WRVX677 Posted February 9, 2023 Report Posted February 9, 2023 Hi all. Im trying to find a pair of handhelds, likely Baofengs, that meet these criteria: 1. One Amateur/HAM and one GMRS 2. Batter interoperability / compatibility between the two radios 3. Water-resistant 4. Uses the Baofeng multi pin connector. (Would ultimately like to pair them up with a Disco32 or Sky Eye PTT and a set of Comtacs) Potential matches: 1. UV-9R Plus / GT-3WP and UV-9G 2. UV-9R Pro and GMRS-9R Do any of these or others share batteries? Any suggestions? Thanks! Quote
1 WRUU653 Posted February 9, 2023 Report Posted February 9, 2023 4 minutes ago, WRVX677 said: It’s just been really difficult to find solid information on some of the slight model changes. Baofeng GT-3WP Ham and the Baofeng UV-9GGMRS are exactly the same radio. you'll get the program cable with the UV-9G that works for both and if you are so inclined the GT-3WP can be unlocked. WRVX677 and SteveShannon 2 Quote
0 SteveShannon Posted February 9, 2023 Report Posted February 9, 2023 47 minutes ago, WRVX677 said: Hi all. Im trying to find a pair of handhelds, likely Baofengs, that meet these criteria: 1. One Amateur/HAM and one GMRS 2. Batter interoperability / compatibility between the two radios 3. Water-resistant 4. Uses the Baofeng multi pin connector. (Would ultimately like to pair them up with a Disco32 or Sky Eye PTT and a set of Comtacs) Potential matches: 1. UV-9R Plus / GT-3WP and UV-9G 2. UV-9R Pro and GMRS-9R Do any of these or others share batteries? Any suggestions? Thanks! So the two plug connector used by Baofeng is a K-1 connector, as in K for Kenwood. There are better radios than the Baofeng. I would look at Wouxun KG-UV9G and KG-UV9D or P. https://bettersaferadio.com/wouxun-kg-uv9g-pro-gmrs-two-way-radio-shtf-scanner/ wayoverthere and kerstuff 2 Quote
0 WRVX677 Posted February 9, 2023 Author Report Posted February 9, 2023 8 minutes ago, Sshannon said: So the two plug connector used by Baofeng is a K-1 connector, as in K for Kenwood. There are better radios than the Baofeng. I would look at Wouxun KG-UV9G and KG-UV9D or P. https://bettersaferadio.com/wouxun-kg-uv9g-pro-gmrs-two-way-radio-shtf-scanner/ Thank you, Steve. I imagine I’ll end up with a nice Wouxun eventually. I do like how those look as well as the KG-S88Gs. I have an FT-65, so I’m covered for a decent handheld on the HAM side. The multi pin connector from Baofeng (UV-9R/G family) is different than the two-pin that most Baofeng’s have, and more closely resembles the contact pins that are on some professional Motorola radios. SteveShannon 1 Quote
0 SteveShannon Posted February 9, 2023 Report Posted February 9, 2023 Just now, WRVX677 said: Thank you, Steve. I imagine I’ll end up with a nice Wouxun eventually. I do like how those look as well as the KG-S88Gs. I have an FT-65, so I’m covered for a decent handheld on the HAM side. The multi pin connector from Baofeng (UV-9R/G family) is different than the two-pin that most Baofeng’s have, and more closely resembles the contact pins that are on some professional Motorola radios. I have the FT-65 as well. I really like it. I have it’s little sister as well. Both can easily be opened up for GMRS. wayoverthere, kerstuff and WRVX677 3 Quote
0 wayoverthere Posted February 9, 2023 Report Posted February 9, 2023 (Disregard....this would be for the k1 plug, not the multi pin) Wouxun...kg805g, and the uv7d (dual band, 2m and your choice of 6m, 1.25., or 70cm as the 2nd). Ip54 and ip55 water resistance, same battery, same k1 cable, and same desk chargers. Edit: missed it was the multi pin similar to the xpr rather than the k1 plug....disregard. SteveShannon and WRVX677 1 1 Quote
0 Lscott Posted February 9, 2023 Report Posted February 9, 2023 If you’re looking for a “cheap” radio the TYT TH-350 is a tri-band, 2M - 1.25M - 70cm, type. It can be opened up for GMRS. It uses the Baofeng type programming cable and microphone accessories. Just be aware the radio is NOT Part 95 certified if that matters. https://store2.rlham.com/shop/catalog/product_info.php?products_id=74359&osCsid=gsc5lupm4qgc3dnoijn4go3o27 The other radios mentioned will likely work better but are going to cost more. You get what you pay for. WRVX677 and SteveShannon 2 Quote
0 WRVX677 Posted February 9, 2023 Author Report Posted February 9, 2023 1 hour ago, wayoverthere said: (Disregard....this would be for the k1 plug, not the multi pin) Wouxun...kg805g, and the uv7d (dual band, 2m and your choice of 6m, 1.25., or 70cm as the 2nd). Ip54 and ip55 water resistance, same battery, same k1 cable, and same desk chargers. Edit: missed it was the multi pin similar to the xpr rather than the k1 plug....disregard. I have a passing familiarity with Wouxun from the GMRS side, but always forget that they make Amateur radios too. Not quite what I’m looking for but a good suggestion. I like the idea of the 805 line and could see getting one in GMRS and MURS eventually. wayoverthere 1 Quote
0 gortex2 Posted February 9, 2023 Report Posted February 9, 2023 What is the intended use of both ? This will help answer the question. If this is a throw away handheld to use here and there the choice above is fine. If you want something that will last a a heavy use handheld none of the CCR stuff is in that category. WRVX677 1 Quote
0 Lscott Posted February 9, 2023 Report Posted February 9, 2023 1 hour ago, gortex2 said: If you want something that will last a a heavy use handheld none of the CCR stuff is in that category. I agree. In that case he would be better off looking for a good used or new commercial grade radio. Unfortunately they are almost universally mono band radios so he would need two, one each for VHF and UHF. The upside to that is with the right frequency range, typical range is 136 MHZ to 174 MHZ, the VHF radio will handle all of the 2M band, MURS, railroad FM, marine and NOAA weather frequencies. On the UHF side a frequency range of 400 MHZ to 470 MHz will cover the full 70cm band, GMRS and most of the commercial business band frequencies. WRVX677 1 Quote
0 SteveShannon Posted February 9, 2023 Report Posted February 9, 2023 13 hours ago, WRVX677 said: Hi all. Im trying to find a pair of handhelds, likely Baofengs, that meet these criteria: 1. One Amateur/HAM and one GMRS 2. Batter interoperability / compatibility between the two radios 3. Water-resistant 4. Uses the Baofeng multi pin connector. (Would ultimately like to pair them up with a Disco32 or Sky Eye PTT and a set of Comtacs) Potential matches: 1. UV-9R Plus / GT-3WP and UV-9G 2. UV-9R Pro and GMRS-9R Do any of these or others share batteries? Any suggestions? Thanks! The Baofeng UV9R (ham) and UV9G (GMRS) appear to meet your criteria. Both share the BL-9 battery and it looks like they both use the 328 Moto jack. https://www.amazon.com/dp/B098JGLWZ1/ref=emc_b_5_i and https://www.amazon.com/Mirkit-Waterproof-Handheld-2200mAh-Portable/dp/B082Q1VL5Y/ref=sr_1_1_sspa?crid=3TV0O3YBECTEG&keywords=baofeng+uv-9r&qid=1675951266&s=electronics&sprefix=%2Celectronics%2C630&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFHTkdOVFNQUVdZWEcmZW5jcnlwdGVkSWQ9QTA0NTE1NjQzTTlXRVBUNjhQMlRHJmVuY3J5cHRlZEFkSWQ9QTA5NzE4NDcxVjRRSjIwTFJBSjlCJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== WRVX677 1 Quote
0 WRVX677 Posted February 9, 2023 Author Report Posted February 9, 2023 38 minutes ago, Sshannon said: The Baofeng UV9R (ham) and UV9G (GMRS) appear to meet your criteria. Both share the BL-9 battery and it looks like they both use the 328 Moto jack. https://www.amazon.com/dp/B098JGLWZ1/ref=emc_b_5_i and https://www.amazon.com/Mirkit-Waterproof-Handheld-2200mAh-Portable/dp/B082Q1VL5Y/ref=sr_1_1_sspa?crid=3TV0O3YBECTEG&keywords=baofeng+uv-9r&qid=1675951266&s=electronics&sprefix=%2Celectronics%2C630&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFHTkdOVFNQUVdZWEcmZW5jcnlwdGVkSWQ9QTA0NTE1NjQzTTlXRVBUNjhQMlRHJmVuY3J5cHRlZEFkSWQ9QTA5NzE4NDcxVjRRSjIwTFJBSjlCJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Thanks Steve. It’s just been really difficult to find solid information on some of the slight model changes. I do like the other suggestions of looking at used or new commercial radios as Lscott had mentioned. SteveShannon 1 Quote
0 SteveShannon Posted February 9, 2023 Report Posted February 9, 2023 49 minutes ago, WRVX677 said: Thanks Steve. It’s just been really difficult to find solid information on some of the slight model changes. I do like the other suggestions of looking at used or new commercial radios as Lscott had mentioned. I can understand that; I had to look at the UV9R, UV9R Pro, UV9R Plus, and UV9R Mk1 to find the one that looked like it was the same as the UV9G. The GT-3WP that @wruu653 posted appears to be the same radio as what I posted, but in a 5w version rather than 8w and for 30% lower cost. Fortunately, Amazon has easy returns. WRUU653 and WRVX677 2 Quote
0 WRVX677 Posted February 9, 2023 Author Report Posted February 9, 2023 16 minutes ago, WRUU653 said: Excellent. Perfect. I am very new to GMRS and HAM. Looking forward to get more involved. I got my GMRS license a couple weeks ago and am signed up for a Tech test in April. Thank you and thanks to everyone for your input! WRUU653 and SteveShannon 2 Quote
0 WRUU653 Posted February 9, 2023 Report Posted February 9, 2023 6 minutes ago, WRVX677 said: I am very new to GMRS and HAM. Looking forward to get more involved. I got my GMRS license a couple weeks ago and am signed up for a Tech test in April. just be forewarned you won't stop there. I think @Sshannon said something like "how many radios is enough"? The answer, Just a few more... AdmiralCochrane, WRVX677, SteveShannon and 1 other 3 1 Quote
0 WRVX677 Posted February 9, 2023 Author Report Posted February 9, 2023 2 hours ago, WRUU653 said: just be forewarned you won't stop there. I think @Sshannon said something like "how many radios is enough"? The answer, Just a few more... How many radios is the right number to have? N+1, where N is the number you currently have! SteveShannon, wayoverthere and WRUU653 3 Quote
0 pcradio Posted February 12, 2023 Report Posted February 12, 2023 The Wouxun UV9PX (and G version) are the best of the cheaper style radios. Very easy to use, work well. SteveShannon 1 Quote
0 muggz Posted February 13, 2023 Report Posted February 13, 2023 6 hours ago, pcradio said: The Wouxun UV9PX (and G version) are the best of the cheaper style radios. Very easy to use, work well. I have both coming. I'm hoping they share a body and just run different firmware. pcradio 1 Quote
0 pcradio Posted February 13, 2023 Report Posted February 13, 2023 13 hours ago, muggz said: I have both coming. I'm hoping they share a body and just run different firmware. I think they are identical. Let me know when you get them. Quote
0 muggz Posted February 19, 2023 Report Posted February 19, 2023 On 2/13/2023 at 8:01 AM, pcradio said: I think they are identical. Let me know when you get them. Yes, I got my KG-UV9PX this past week and compared it with a friend's KG-UV9GX and the bodies are exactly the same. pcradio 1 Quote
WRVX677
3. Water-resistant
Potential matches:
Any suggestions?
Thanks!
20 answers to this question
