DarrylLicht Posted September 16, 2023 Author Posted September 16, 2023 6 minutes ago, WRYS709 said: Daily nap time soon... Did you do these two steps in Freq/VFO mode? Push Menu, Push UP ARROW to SFT-D, Push Menu, Push Up Arrow to +, Push Menu, Push Exit Push MENU, Push UP ARROW to OFFSET, Push MENU, Enter 005.000, Push MENU, Push Exit Yes sir and with that 462.600 in the A position not B Quote
WRYS709 Posted September 16, 2023 Posted September 16, 2023 5 minutes ago, DarrylLicht said: Yes sir and with that in the A position not B What do you mean by A and B positions? Quote
WRYS709 Posted September 16, 2023 Posted September 16, 2023 Oh, the upper display and not the lower display? Quote
WRYS709 Posted September 16, 2023 Posted September 16, 2023 Can you link me to the model you purchased online? Quote
WRYS709 Posted September 16, 2023 Posted September 16, 2023 OK: gotta go! Hopefully someone else will jump in or I'll be back tonight! Good luck! Quote
DarrylLicht Posted September 16, 2023 Author Posted September 16, 2023 Thanks WRYS709 I am WRYR809 Quote
WRYS709 Posted September 16, 2023 Posted September 16, 2023 47 minutes ago, WRYS709 said: Can you link me to the model you purchased online? Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 23 minutes ago, WRYS709 said: https://www.amazon.com/dp/B0BGHXV6Y4?ref=ppx_yo2ov_dt_b_product_details&th=1 Quote
OffRoaderX Posted September 17, 2023 Posted September 17, 2023 12 minutes ago, DarrylLicht said: https://www.amazon.com/dp/B0BGHXV6Y4?ref=ppx_yo2ov_dt_b_product_details&th=1 That is the GMRS version so your life is going to be a lot easier getting repeaters set up. To set up the Inland Empire "Ranchino" repeater, start on Repeater 17/Channel 25 and enter the DTC TX tone 023. For a pro, this should take about 15 seconds to set up right on the keypad, no computer or cables needed.. For your first time, set aside at least an hour. WRUU653 1 Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 16 minutes ago, OffRoaderX said: That is the GMRS version so your life is going to be a lot easier getting repeaters set up. To set up the Inland Empire "Ranchino" repeater, start on Repeater 17/Channel 25 and enter the DTC TX tone 023. For a pro, this should take about 15 seconds to set up right on the keypad, no computer or cables needed.. For your first time, set aside at least an hour. Unfortunately there are only REPTR #s 1 to 8 CH 25 on this one is REPTR3 - according to the Appendix that equates to 462.600 Is that correct so far? Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 DTC TX tone is set to 023. The silence is deafening. On what peak is this repeater in RC? Quote
OffRoaderX Posted September 17, 2023 Posted September 17, 2023 Its on Haven Peak.. step outside and look north, unless you are north of Hillside, then just look toward haven. Is that you that keeps calling out for Unit 2 ? Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 Whomever was just broadcasting for the "new guy with Baofeng" I was RXing But apparently not TXing Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 5 minutes ago, OffRoaderX said: Its on Haven Peak.. step outside and look north, unless you are north of Hillside, then just look toward haven. I'm thinking Riverside might be too far for this lil handheld??? Quote
OffRoaderX Posted September 17, 2023 Posted September 17, 2023 Than you are either not in range (try outside) or you dont have the right tone.. DTC/DCS/DPL: D023 Quote
OffRoaderX Posted September 17, 2023 Posted September 17, 2023 ...and Riverside might be a stretch, depending on where you are/if you dont have good line of sight to North Rancho. WRYS709 1 Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 12 minutes ago, OffRoaderX said: ...and Riverside might be a stretch, depending on where you are/if you dont have good line of sight to North Rancho. Time to head for the hills... I'm certainly learning the menus well on this UV5R! LMAO WRYS709 1 Quote
WRYS709 Posted September 17, 2023 Posted September 17, 2023 I wanted to buy a UV-5R GMRS just to play with. i just didn’t want to buy two! Use the refund on the DigiRig to buy a genuine Nagoya 771G antenna with the proper SMA for that radio, to improve your range. WRUU653 and fremont 2 Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 3 minutes ago, WRYS709 said: I wanted to buy a UV-5R GMRS just to play with. i just didn’t want to buy two! Use the refund on the DigiRig to buy a genuine Nagoya 771G with the proper SMA for that radio, to improve your range. Before I even got this msg the Nagoya 771G is ordred! I had also opted out of the DigiRig this AM! I believe you were pinging me earlier I heard "709" and "new guy with the baofeng"! Just you could not hear me respond WRYS709 1 Quote
WRYS709 Posted September 17, 2023 Posted September 17, 2023 Not me! I was listening on Zello but probably napping! Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 3 minutes ago, WRYS709 said: Not me! I was listening on Zello but probably napping! Musta been OffRoaderX then as he was active online at that time. I wanted two for camping and hiking with the wife n grandkids. We had an "incident" several years ago in J-tree, (kids went climbing and exploring, we all got separated I found kids and the wife didn't show up for several more hours). Lesson learned and I wanted a way to keep in touch and teach the GKs. Plus I am wanting to start going out on 4x4 group drives and they usually require a GMRS radio (scored a midland MTX275 for the truck). Hell the 2 for the $44 special with all the accessories felt like a cheap investment. Adding the antenna, extended batts, and the programming cable I'm still well under $200 total. I'm no techno-phobe, taught Computer Science, PC repair, data communications, networking, etc for over 20 years. I just might not be as quick to pick up as when i was 20... or 30... or 40! Getting old sucks, but it sure beats the alternative! BUT I WILL PICK THIS UP! Again, I want to thank you all for the wonderful help and support today. Tomorrow I will be in NFL mode, but I'll check in here. WRYS709 1 Quote
OffRoaderX Posted September 17, 2023 Posted September 17, 2023 7 minutes ago, DarrylLicht said: Plus I am wanting to start going out on 4x4 group drives and they usually require a GMRS radio (scored a midland MTX275 for the truck). In case you werent aware - anyone that runs into me while off-roading (IN the dirt, not on the streets!) gets a free GMRS radio! (while supplies last). Just find me most saturdays anywhere between Anza Borrego and Randsburg, and unless I've already given away that days radio(s), you'll get one (IF you need one) WRYS709, SteveShannon, WRUU653 and 2 others 4 1 Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 35 minutes ago, OffRoaderX said: In case you werent aware - anyone that runs into me while off-roading (IN the dirt, not on the streets!) gets a free GMRS radio! (while supplies last). Just find me most saturdays anywhere between Anza Borrego and Randsburg, and unless I've already given away that days radio(s), you'll get one (IF you need one) LOL! I think I am flush with radios now! Quote
DarrylLicht Posted September 17, 2023 Author Posted September 17, 2023 Q - Once I have entered the right DTC/DCS/DPL tone of: D023 for this repeater, does it remain in memory after I turn the unit off? Quote
