WRPJ403 Posted November 1, 2023 Report Posted November 1, 2023 How do you know if you are hitting a repeater? Thanks Quote
kidphc Posted November 1, 2023 Report Posted November 1, 2023 One way is to listen for a repeater tail after you unkey.Sent from my SM-S901U using Tapatalk Quote
JamesBrox Posted November 1, 2023 Report Posted November 1, 2023 1 minute ago, WRPJ403 said: How do you know if you are hitting a repeater? Thanks You'll hear a "kerchunk". Quote
WRYU400 Posted November 1, 2023 Report Posted November 1, 2023 You will hear a courtesy tone, squelch tail and then the repeater should identify (in Morse code). Sometimes you will hear the repeater owner tell you to identify and stop kerchunking their repeater. Sent using Tapatalk Quote
SteveShannon Posted November 1, 2023 Report Posted November 1, 2023 13 minutes ago, kidphc said: One way is to listen for a repeater tail after you unkey. Sent from my SM-S901U using Tapatalk 12 minutes ago, JamesBrox said: You'll hear a "kerchunk". 10 minutes ago, WRYU400 said: You will hear a courtesy tone, squelch tail and then the repeater should identify (in Morse code). Sometimes you will hear the repeater owner tell you to identify and stop kerchunking their repeater. Sent using Tapatalk All of those are optional, or, in the case of the the repeater ID, dependent on timing. The only way to be sure is to have someone else monitoring the repeater when you transmit. Raybestos 1 Quote
gortex2 Posted November 1, 2023 Report Posted November 1, 2023 Correct. Some repeaters do not have repeater tails or squelch tails. All of mine drop as soon as carrier/PL drops. I do it to stop the "kerchunkers" Quote
WRPJ403 Posted November 1, 2023 Author Report Posted November 1, 2023 I have heard the morse code but when i did not key the mike. Thanks for the replys WRUU653 1 Quote
SteveShannon Posted November 1, 2023 Report Posted November 1, 2023 13 hours ago, WRPJ403 said: How do you know if you are hitting a repeater? Thanks Simply say: “Can anyone hear me? WRPJ403”. If someone is listening they might respond. WRUU653 and WRXB215 2 Quote
WRZE000 Posted November 3, 2023 Report Posted November 3, 2023 On 11/1/2023 at 9:36 AM, Sshannon said: Simply say: “Can anyone hear me? WRPJ403”. If someone is listening they might respond. (This is a question as much as a statement since I am terribly new) ... but what you say @Sshannon was my understanding. "Kerchunks" aside, If you are transmitting to a repeater TX side, and someone on the RX side can actually hear you, then you are hitting it. The same would be true if you had a second HT in the house (on RX chan) and could hear yourself on it. True? Quote
SteveShannon Posted November 3, 2023 Report Posted November 3, 2023 46 minutes ago, WRZE000 said: (This is a question as much as a statement since I am terribly new) ... but what you say @Sshannon was my understanding. "Kerchunks" aside, If you are transmitting to a repeater TX side, and someone on the RX side can actually hear you, then you are hitting it. The same would be true if you had a second HT in the house (on RX chan) and could hear yourself on it. True? True, except that sometimes having a second HT in the house fails because the transmission from the first HT is orders of magnitude higher in power than the return signal from the repeater and the second HT is temporarily deafened, which is called “de-sensing.” But if you get someone to take that other HT some slight distance away it would work. And I want to point out that de-sensing isn’t a sure thing. My Yaesu and Alinco radios can be right on the same table and work fine with one transmitting to the repeater and the other receiving from the repeater. So try it. There’s nothing to lose. redshadow16 and WRUU653 2 Quote
WRQC527 Posted November 4, 2023 Report Posted November 4, 2023 On 10/31/2023 at 5:36 PM, WRPJ403 said: How do you know if you are hitting a repeater? Thanks Set a roger beep on your radio. That's a sure-fire way to get a response. Perhaps not a favorable one, but maybe a response nevertheless. OffRoaderX 1 Quote
