I have been struggling to suppress injector background noise (low pitched buzz that changes intensity with RPM increase) on my 2013 F150 ecoboost (steel body) that occurs only on transmit. No noise on receive.
My antenna setup is a midland MXTA26 mounted on a comet nmo front fender mount using pro58au coax cable (USA made). SWR reads about 1.0 to 1.5 depending on frequency.
My radio is a wouxun kg1000g plus and I used the factory provided wiring harness run from the battery through the passenger fender cavity away from vehicle harnesses down under the passenger footwell to the wiring access hole under the footwell carpet. Positive is at the battery, negative is at the same grounding point on the inside fender that the negative battery cable attaches to so the ford BMS hall sensor is not bypassed. I used quality copper crimp on terminals at both points.
My first effort to suppress it I tried cheap Amazon ferrite beads of unknown mix on both antenna coax and power leads. They helped some but didn't solve it. I returned them and ordered the Palomar engineering troubleshooting kit beads containing mix 31, 75, and 61 covering a lot of frequencies. This kit hasn't arrived yet.
I also tried putting a Powerwerx LF-1 DC noise suppressor on the power cable and it had no effect. Returned it.
Thinking I have a ground loop isolation problem I then proceeded to place bonding straps on each hood latch and also at 3 places along the exhaust (exhaust tip, between muffler and catalytic converter, and before the catalytic converter with no effect.
One item of interest. I connected my handheld kg935g to my truck's antenna coax with so239 to sma adapter and when that radio transmits with the vehicle running, the ignition noise on transmit is not present. So it appears to be on the power side.
So my question is this, which ferrite mix is likely going to be most helpful out of the 3 types I have coming and given my symptoms would I want to target the DC power only or would it also be smart to choke the coax with multiple turns as well?
Also, would it be worth my time to continue trying to bond more truck body parts?
And lastly, could having an older battery with decreased cold cranking amps be contributing to my issue due to voltage drop even though when running the truck is on alternator power? And related to that, should I think about moving up to 10 AWG wiring making my own harness instead to help with voltage drop?
WRQJ559
12 answers to this question
