Repeater Antenna RG-213 Power Loss
WRZM243
4 answers to this question
On 1/9/2024 at 5:12 PM, tweiss3 said:
Each connector adds approximately 0.1db of loss. Other than the fact that at 50' you already have 4.4db of loss (64%) in power and sensitivity, the connector not a concern.
RG-213 on the charts I have seen shows 5.2 dB loss per 100 feet. at 45 feet it should be a bit less than half that. https://www.w4rp.com/ref/coax.html
Additional connectors do have issues with the potential for water intrusion and corrosion. For a temporary installation it is not much of an issue, but for permanent installations the better practice is to have a single run.
And LMR400 has 1dB of loss for the same length.
