Darmie Posted March 20, 2024 Report Posted March 20, 2024 5 hours ago, WSAA635 said: I have mine programed with GMRS, MURS and I scan local Airbands with it. I is there much activity on MURS? I have two of the talkpods and really like them for the ease of use and that you can program the small side button to Push to Talk on the B band. Word of warning. Think before you push one of the buttons to know if you want to xmit on A or B. SteveShannon 1 Quote
WRXB215 Posted March 20, 2024 Report Posted March 20, 2024 5 minutes ago, Darmie said: Think before you push one of the buttons to know if you want to xmit on A or B. Yep, dual watch can be confusing if there are conversations on both at the same time. Quote
TNFrank Posted March 20, 2024 Author Report Posted March 20, 2024 1 hour ago, Darmie said: is there much activity on MURS? No, that's why I like it. I know if I'm talking to someone while hunting /shooting I won't have to worry about others on the channel. WRQC527 1 Quote
WSBB368 Posted March 21, 2024 Report Posted March 21, 2024 I’m in the fence on this one while I do have uv9g gmrs radios I’ve been thinking of just going with either a Anytone atd878uvll plus it’s has dual band cause if and when the shtf I want to be able to communicate on both gmrs and ham frequencies I do plan to get a ham license but that all get thrown out the door in an emergency. I do play by the rules but it doesn’t make sense to carry around 2 radios when one can do it all Sent from my iPhone using Tapatalk Quote
SteveShannon Posted March 21, 2024 Report Posted March 21, 2024 16 minutes ago, WSBB368 said: I’m in the fence on this one while I do have uv9g gmrs radios I’ve been thinking of just going with either a Anytone atd878uvll plus it’s has dual band cause if and when the shtf I want to be able to communicate on both gmrs and ham frequencies I do plan to get a ham license but that all get thrown out the door in an emergency. I do play by the rules but it doesn’t make sense to carry around 2 radios when one can do it all Sent from my iPhone using Tapatalk Before you invest in the Anytone, have someone show you how to program it. I believe it’s nearly the same radio as my Alinco DJ-MD5xt. Programming it from the front panel is very difficult. Using the CPS is very detailed because it’s designed around the data structure necessary for DMR channels. You have to create Talk Groups, Zones, and Channels and link them together, even for the most basic analog channels. Other than that it performs well, but I would hate to have to program it from the front panel. Added, here’s a video showing how to change the frequency: WSBB368 and WRUU653 1 1 Quote
Lscott Posted March 21, 2024 Report Posted March 21, 2024 9 hours ago, Sshannon said: Using the CPS is very detailed In my experience it's also somewhat buggy too. Maybe by now they have more of the crappy bugs fixed. Also the firmware in the radio had some annoying quirks too. The feature I find most useful is the DMR monitoring mode in the radio. I wish my commercial radios had this, but that wasn't necessary since the market for them ends up with the radios pretty much programmed up once and that's the end of it. SteveShannon and WRUU653 2 Quote
WRXB215 Posted March 21, 2024 Report Posted March 21, 2024 9 hours ago, WSBB368 said: I do plan to get a ham license but that all get thrown out the door in an emergency. Even though this scenario can actually happen, I encourage you to get your ham license and get on the air. You will increase your circle of trusted friends which can be a real asset during such an event. Also, I think it was @Lscott that pointed out once that in a stressful situation you want a radio that is very simple to operate. It sounds like good advice to me. SteveShannon, Lscott, Darmie and 3 others 6 Quote
TNFrank Posted March 21, 2024 Author Report Posted March 21, 2024 From what little I've researched about DMR there's way more to programming them than with the standard analog radios. I'm going to stick with analog for now. Quote
SteveShannon Posted March 21, 2024 Report Posted March 21, 2024 14 minutes ago, WSAA635 said: From what little I've researched about DMR there's way more to programming them than with the standard analog radios. I'm going to stick with analog for now. There is. I’m still helping my blind friend with his DMR radio (as well as my own) and I wish I could get the ear of the firmware programmers for these Anytone and Alinco DMR radios. There’s absolutely no reason it has to be as difficult as it is. With simple changes in firmware a person could easily just create two channels for each repeater (one per timeslot) and then just input or select the talk group. DMR radios would only be slightly more complicated than analog. WSCS769, WRUU653 and Lscott 3 Quote
TNFrank Posted March 21, 2024 Author Report Posted March 21, 2024 56 minutes ago, Sshannon said: There’s absolutely no reason it has to be as difficult as it is. With simple changes in firmware a person could easily just create two channels for each repeater (one per timeslot) and then just input or select the talk group. DMR radios would only be slightly more complicated than analog. I guess it just takes diving in and doing it so that you'll learn it. It's like anything, it's going to be difficult until you do it a few times and get the hang of it. Quote
SteveShannon Posted March 21, 2024 Report Posted March 21, 2024 18 minutes ago, WSAA635 said: I guess it just takes diving in and doing it so that you'll learn it. It's like anything, it's going to be difficult until you do it a few times and get the hang of it. It's not really difficult, but it is needlessly complex, mostly because of leftover commercial radio characteristics: First, you have to create a list of talkgroups. Then you have to create channels. A channel consists of a channel name, Brandmeister ID (or other digital ID), timeslot, color code, frequency, bandwidth, whether transmit is inhibited, whether it's an analog or digital channel, and if it's digital you need a talkgroup assigned. That's why you have to create the list of talkgroups first. There are other fields as well including encryption etc., but you get the idea. Then you have to create at least one zone and assign channels to the zone. You may (not mandatory) also populate a database of digital IDs which links the call sign, Brandmeister ID, and contact name. This can be downloaded. The newest DMR radios have room for 500,000 contacts. My radio handles 200,000 so I can only load most of North America. On your radio you select a zone and then select a channel within that zone. AdmiralCochrane, Knilc, WSCS769 and 2 others 4 1 Quote
Lscott Posted March 22, 2024 Report Posted March 22, 2024 5 hours ago, Sshannon said: It's not really difficult, but it is needlessly complex, mostly because of leftover commercial radio characteristics: First, you have to create a list of talkgroups. Then you have to create channels. A channel consists of a channel name, Brandmeister ID (or other digital ID), timeslot, color code, frequency, bandwidth, whether transmit is inhibited, whether it's an analog or digital channel, and if it's digital you need a talkgroup assigned. That's why you have to create the list of talkgroups first. There are other fields as well including encryption etc., but you get the idea. Then you have to create at least one zone and assign channels to the zone. You may (not mandatory) also populate a database of digital IDs which links the call sign, Brandmeister ID, and contact name. This can be downloaded. The newest DMR radios have room for 500,000 contacts. My radio handles 200,000 so I can only load most of North America. On your radio you select a zone and then select a channel within that zone. Yeah, programming a DMR radio is a PIA. Then again NXDN and P25 isn’t much different. I’ve done all three of the above. SteveShannon and WRUU653 2 Quote
WRXB215 Posted March 22, 2024 Report Posted March 22, 2024 My wife and I wrote a script for a training video on how to program and use DMR radios. Yep, our marriage was strained for a while. WRUU653 and Lscott 1 1 Quote
Lscott Posted March 22, 2024 Report Posted March 22, 2024 1 hour ago, WRXB215 said: My wife and I wrote a script for a training video on how to program and use DMR radios. Yep, our marriage was strained for a while. I've done some technical writing for the company I work at, Power Point slide shows for training/sales, test procedures and manuals, but it's not my primary job. People think it's easy. Nope! It's boring mind numbing work and requires a lot of attention to details. People who do it full time professionally really earn their money. Doing design calculations, simulations and circuit design is much more fun, and it keeps the mind sharp too. WRUU653, AdmiralCochrane and WRXB215 3 Quote
Knilc Posted March 25, 2024 Report Posted March 25, 2024 On 3/21/2024 at 7:17 PM, Sshannon said: It's not really difficult, but it is needlessly complex, mostly because of leftover commercial radio characteristics: First, you have to create a list of talkgroups. Then you have to create channels. A channel consists of a channel name, Brandmeister ID (or other digital ID), timeslot, color code, frequency, bandwidth, whether transmit is inhibited, whether it's an analog or digital channel, and if it's digital you need a talkgroup assigned. That's why you have to create the list of talkgroups first. There are other fields as well including encryption etc., but you get the idea. Then you have to create at least one zone and assign channels to the zone. You may (not mandatory) also populate a database of digital IDs which links the call sign, Brandmeister ID, and contact name. This can be downloaded. The newest DMR radios have room for 500,000 contacts. My radio handles 200,000 so I can only load most of North America. On your radio you select a zone and then select a channel within that zone. And here I was thinking programming a GMRS radio for a repeater was a PITA. I clearly underestimated how complex radios could get. WRUU653 and amaff 1 1 Quote
WSBB368 Posted March 25, 2024 Report Posted March 25, 2024 So I received my radio on Saturday and yes it’s a lot took me the whole day to figure it out but I have it set up now and have a somewhat good understanding of how to program it. You definitely need a hotspot to connect to the internet to use talk groups. I am just barely close enough to a repeater but the socal and California talk groups are pretty much dead. Someone will chime in every now and then but that’s about it. Gonna play with it some more today and see if maybe I’m doing something wrong Sent from my iPhone using Tapatalk Quote
Lscott Posted March 25, 2024 Report Posted March 25, 2024 20 minutes ago, WSBB368 said: So I received my radio on Saturday and yes it’s a lot took me the whole day to figure it out but I have it set up now and have a somewhat good understanding of how to program it. You definitely need a hotspot to connect to the internet to use talk groups. I am just barely close enough to a repeater but the socal and California talk groups are pretty much dead. Someone will chime in every now and then but that’s about it. Gonna play with it some more today and see if maybe I’m doing something wrong Sent from my iPhone using Tapatalk My biggest problem with DMR is the ever changing repeater settings. Identifying new talkgroups, deleting old talkgroups, changes in which network the repeater belongs to etc. I think I have a radio setup then a few weeks/months later it's all in the crapper and I have to update the zone for that repeater. PIA. DMR is nice, but the frequent changes aren't, and trying to find the current info is a crap-shoot. This repeater example is one of the more messy and busy systems I've seen. N8NOE.pdf Quote
SteveShannon Posted March 25, 2024 Report Posted March 25, 2024 33 minutes ago, WSBB368 said: So I received my radio on Saturday and yes it’s a lot took me the whole day to figure it out but I have it set up now and have a somewhat good understanding of how to program it. You definitely need a hotspot to connect to the internet to use talk groups. I am just barely close enough to a repeater but the socal and California talk groups are pretty much dead. Someone will chime in every now and then but that’s about it. Gonna play with it some more today and see if maybe I’m doing something wrong Sent from my iPhone using Tapatalk Anywhere there’s a DMR repeater, you should be able to save a channel to join talk groups in that network such as TG 93, USA-Wide on the Brandmeister network. You take everybody on the repeater with you though. Quote
WSBB368 Posted March 25, 2024 Report Posted March 25, 2024 Anywhere there’s a DMR repeater, you should be able to save a channel to join talk groups in that network such as TG 93, USA-Wide on the Brandmeister network. You take everybody on the repeater with you though. I think my problem is I’m too far from the closest dmr repeater to me. I’m going to drive closer and see if that helps Sent from my iPhone using Tapatalk SteveShannon 1 Quote
WRYS709 Posted March 25, 2024 Report Posted March 25, 2024 4 hours ago, WSBB368 said: So I received my radio on Saturday and yes it’s a lot took me the whole day to figure it out but I have it set up now and have a somewhat good understanding of how to program it. You definitely need a hotspot to connect to the internet to use talk groups. I am just barely close enough to a repeater but the socal and California talk groups are pretty much dead. Someone will chime in every now and then but that’s about it. Gonna play with it some more today and see if maybe I’m doing something wrong 2 hours ago, WSBB368 said: I think my problem is I’m too far from the closest dmr repeater to me. I’m going to drive closer and see if that helps Craig: The PAPA System has interconnected DMR repeaters all over SoCAL, including your area; Check their listings here. You can register as a Guest User for a free 45 day trial and then join if you like. Watch and listen to worldwide DMR activity on the Brandmeister Hoseline in real time. Then you can add interesting TalkGroups to your Anytone and go live. NOTE: How did such a discussion of ham radio dmr get into the GMRS subtopic? WRUU653 and WSBB368 2 Quote
Lscott Posted March 25, 2024 Report Posted March 25, 2024 25 minutes ago, WRYS709 said: NOTE: How did such a discussion of ham radio dmr get into the GMRS subtopic? Quote
SteveShannon Posted March 25, 2024 Report Posted March 25, 2024 2 hours ago, WSBB368 said: I think my problem is I’m too far from the closest dmr repeater to me. I’m going to drive closer and see if that helps Sent from my iPhone using Tapatalk If you look at the Brandmeister dashboard you can see if your signal is being received and what strength. Once you know, then you can configure a channel to the Parrot talkgroup and you’ll be able to hear what you sound like. Quote
WSBB368 Posted March 25, 2024 Report Posted March 25, 2024 1 hour ago, WRYS709 said: Craig: The PAPA System has interconnected DMR repeaters all over SoCAL, including your area; Check their listings here. You can register as a Guest User for a free 45 day trial and then join if you like. Watch and listen to worldwide DMR activity on the Brandmeister Hoseline in real time. Then you can add interesting TalkGroups to your Anytone and go live. NOTE: How did such a discussion of ham radio dmr get into the GMRS subtopic? AHHH AI6BX is the repeater im trying to use. Repeater book shows it as open so I didnt realize i needed to pay for use. That would explain why im not hearing anything. Quote
WSBB368 Posted March 25, 2024 Report Posted March 25, 2024 2 hours ago, Sshannon said: If you look at the Brandmeister dashboard you can see if your signal is being received and what strength. Once you know, then you can configure a channel to the Parrot talkgroup and you’ll be able to hear what you sound like. Yep defiantly hitting it, didnt know it was a paid repeater so will need to see if its worth the yearly price. Quote
SteveShannon Posted March 25, 2024 Report Posted March 25, 2024 17 minutes ago, WSBB368 said: Yep defiantly hitting it, didnt know it was a paid repeater so will need to see if its worth the yearly price. Paid repeater? All ham radio clubs encourage membership and gleefully accept donations. We might have a difficult time paying for all that goes into the expenses associated with repeaters otherwise. Im not a Papa member and I certainly can’t speak for them but I suspect that if you donate what you can they’ll not mind you using the repeaters. WSBB368 1 Quote
