WRPT980 Posted April 10 Report Posted April 10 Is it ok to put a gmrs yagi antenna on a metal mast. I think not. Maybe on the last 5 foot of mast I could put a heavy closet rod and or pvc? Quote
0 WSAM454 Posted April 10 Report Posted April 10 Since the GMRS yagi is mounted vertically (vertically polarized), it could be a problem if the mast was in the middle of the antenna, but most of the GMRS yagis I have seen are mounted from the rear, so the metal mast should not be a problem, since most likely there is enough spacing between the first element and the mast mounting area. WRPT980 1 Quote
0 WRWE456 Posted April 10 Report Posted April 10 50 minutes ago, WRPT980 said: Is it ok to put a gmrs yagi antenna on a metal mast. I do not think it is a problem. There was no mention of that in the instructions for my Arrow Antenna's Yagi. Mine is mounted to a steel mast and I have not has any issues. WRPT980 1 Quote
0 SteveShannon Posted April 10 Report Posted April 10 1 hour ago, WRPT980 said: Is it ok to put a gmrs yagi antenna on a metal mast. I think not. Maybe on the last 5 foot of mast I could put a heavy closet rod and or pvc? Yes; it’s just fine to put a Yagi on a metal mast. WRPT980 and WRYZ926 2 Quote
0 back4more70 Posted April 10 Report Posted April 10 1 hour ago, WRPT980 said: Is it ok to put a gmrs yagi antenna on a metal mast. I'm fine with it WRPT980 and WRXB215 1 1 Quote
0 WSBZ540 Posted April 10 Report Posted April 10 If you can tune the yagi, it might help a little to tune when it's on the mast, but it's not going to cause death an destruction if you don't. I generally side mount my yagis 16-24" away. But I also run them in some kind of pairing to keep my mast in balance. WRPT980 1 Quote
0 WRYZ926 Posted April 10 Report Posted April 10 HF, VHF, and UHF amateur band Yagi's get put onto metal masts all the time. It shouldn't be an issue. Quote
WRPT980
6 answers to this question
