GMRS REPEATER Question
Hello,
I am BRAND NEW to GMRS Communications. I am trying to connect to my first repeater, a local repeater in Los Angels (Sierra Repeater). I am using ODMaster to program channel 33 to to the information found on this page: https://mygmrs.com/repeater/7804
Are these the correct settings on ODMaster?
Channel: 33
RX Frequency: 462.550
TX Frequency: 462.550
Frequency Hop: OFF
DEC: OFF
ENC: OFF
TX Power: High
W-N: W
Busy Lock: OFF
SCAN_ADD: OFF
PTT ID: OFF
Scramble: OFF
Thank you in advance in helping me understand repeaters.
Richard
14 answers to this question
What radio are you programming?   Is it a gmrs radio?  If it is I’d bet channel 30 is already set up with the proper off set?
25 minutes ago, WRXM210 said:
Hello,
Channel: 33
Frequency Hop: OFF
DEC: OFF
ENC: OFF
TX Power: High
W-N: W
Busy Lock: OFF
SCAN_ADD: OFF
PTT ID: OFF
Scramble: OFF
Richard
Did you ask the owner for the tones.  You haven’t listed them and they are not public. And yes the transmit needs to be 467.550
7 minutes ago, gortex2 said:
TX needs to be 476.550. You will also need to get the input tones from the repeater owner by requesting access.
Thank you for the response. I did request access from the owner, but haven't yet heard back.
Why is TX 476.55? I'm sure there's a simple answer, but the TX isn't listed on the repeater info (https://mygmrs.com/repeater/7804)
Again, thanks for your time and helping me understand.
Richard
It’s 467.550 he made a typo.  Repeaters always listen on 467.xxx and transmit on 462.xxx.   All gmrs repeaters should have an +5.000 off set.  Unless it’s a simplex repeater but I don’t think it is.   And you will need the input tone from the owner or you won’t open the repeater.
Ah, got it! Thank you for the clarification!
I tried to change the TX frequency to 467.55, but when I save it, it reverts back to the same frequency as RX frequency in OD Master. Any thoughts as to why it won't accept another frequency in this slot?
Are you programming in the proper offset for the repeater channel? The offset should be set to a + 5 MHz.
Richard
And you probably won't. Most of the repeater owners in the LA area that have their tones unlisted with permission required have a habit of not responding.
You might not be on a repeater channel.  1-22 are simplex channels, which transmit on the same frequency they receive. But there are eight repeater channels which allow the repeater to transmit while simultaneously receiving.  Doing both at the same time is called Duplex. Different manufacturers denote those channels differently.  Some continue the numbering scheme and refer to them as channels 23-30, others repeat the 15-22 numbers but prepend or append RP to the channel, like 15RP, to indicate that they are repeater channels.
Repeaters receive on the 467 MHz main frequencies and transmit at exactly the same time on the 462 MHz main channels. That’s referred to as an offset and it is generally exactly 5.000 MHz for UHF channels (in ham radio also). They need an offset to be able to transmit while receiving. So, in your radio there should be eight repeater channels which are programmed to receive on exactly the same 462.xxx frequencies as 15-22, but which transmit on the main 467.xxx frequencies, where xxx is typically the same for both.  You need to use one of those.
I totally agree that's what I read in owners manual for all six of my owners manual
It sounds like you are using the app.  I had the same problem. I use the web based ODmaster. You can use the “add frequency plan” and it will have everything correct. I uploaded it it my TD H3 and it was happy happy. https://web.odmaster.net
TX should be 467.550, along with whatever tone it requires.
