LeoG Posted September 22, 2024 Author Report Posted September 22, 2024 Pretty sure I won't be able to help myself about reporting what ends up happening with my system. I'm hoping that getting above the trees is one of my main issues. If I had patience I would wait for winter to come in and all the leaves on the tree to be on the ground. If my signal at the house and elsewhere improved then I would know for a fact that one of the more prominent issues I'm dealing with. I know in the direction without trees I have a good signal 6 miles away. Which of course isn't that far, but the hilly areas I live around are somewhat insurmountable issues that can't be worked around other than height. Quote
LeoG Posted September 22, 2024 Author Report Posted September 22, 2024 On 9/19/2024 at 12:22 AM, SteveShannon said: Max is 9.78 dB (assuming dBi) at theta = 90°, horizontal. That’s the blue horizontal line to the right, and it’s 9.77 dB along the green horizontal line to the left (theta = -90°). The red lines are about angles above and below horizontal. Theta is the angle along the circle. So at theta = 84° (which is the upper red line in the diagram) the gain is 5.74 dB. That’s 6° above horizontal. At theta = 95° (the lower red line) the gain is 6.77 dB. Everywhere within the 11° angle between theta = 84° to theta = 95° has gain greater than 5.74 up to 9.78 and back down to 6.77. Steve, I wonder if we could discuss the diagram further. I assume this is a view of the horizontal. the 90º being the ground or parallel to the ground. The circle around it in degrees are 0º being up towards the sky and 180º being down to the ground. I see 90 and -90º being front and rear, but in an "omnidirectional" antenna it shouldn't really matter. Obviously there was a .01dB difference at 90º but that's moot in real life and only exists in a lab. What I want to understand are the shapes of the lobes. I also see the concentric circles going inward there are also numbers which I assume are decibel ratings going from 0 from the outside circle to -40 on the inside circle. The look like they are spaced with an algorithmic strength. So how are the lobes equated to distance from the central point which is the antenna? And why are the 0 through -40 numbers in that arrangement and not reversed? As the distance from the center goes out further I would assume the signal gets weaker. I assume I'm getting confused because this is a gain diagram and not a power diagram. I would really like to understand how to read this as well as you do. Quote
SteveShannon Posted September 22, 2024 Report Posted September 22, 2024 17 minutes ago, LeoG said: Steve, I wonder if we could discuss the diagram further. I assume this is a view of the horizontal. the 90º being the ground or parallel to the ground. The circle around it in degrees are 0º being up towards the sky and 180º being down to the ground. I see 90 and -90º being front and rear, but in an "omnidirectional" antenna it shouldn't really matter. Obviously there was a .01dB difference at 90º but that's moot in real life and only exists in a lab. What I want to understand are the shapes of the lobes. I also see the concentric circles going inward there are also numbers which I assume are decibel ratings going from 0 from the outside circle to -40 on the inside circle. The look like they are spaced with an algorithmic strength. So how are the lobes equated to distance from the central point which is the antenna? And why are the 0 through -40 numbers in that arrangement and not reversed? As the distance from the center goes out further I would assume the signal gets weaker. I assume I'm getting confused because this is a gain diagram and not a power diagram. I would really like to understand how to read this as well as you do. Sure! And trust me on this, I’m no expert on reading this either! You’re exactly right, this shows gain, (no relationship to the distance the signal might carry!) with the outermost ring being the reference based on the maximum signal strength. That’s all it means. We all look at these and wonder what they have to do with distance, but that the way to torture yourself. Just so I can look at it easily while talking about it: Those lobes are actually what has either been simulated or measured. Whoever put this together found the direction of max gain and measured the strength of the signal in that direction. Then, in other directions they measure the signal strength and compare the max against the strength in that direction to determine how many dB down the signal is in any other direction. The blue lines showing the lobes simply indicates the loss of signal strength with the smallest lobes showing greater loss. So, for instance, there’s a lobe nearly centered on the 60° angle. The intersection of the outermost extreme of the lobe falls between the -10 dB and -20 dB circles, but I would estimate between -16 and -17 dB. So that simply tells us that at that angle, the measurement of signal strength was about 16 or 17 dB weaker than the maximum signal. Note that directly above and below (0° and 180°) there is no blue. That means there’s a point above and below where there was no signal, a null reading on the field strength meter. That null actually appears to subtend an angle about 10° right and left of vertical. That’s why placing a repeater on your roof and trying to hit it with another radio that happens to be within that “cone of silence” could be really frustrating. You’re within eyesight of the antenna, looking straight up at it, but you’re in a dead spot. Jist as a comment, the lobes are not symmetrical with respect to the horizontal axis. That’s probably because of the proximity to the ground. As you move the antenna up, the lobes below the horizontal axis will become more and more like the upper ones. Sometimes, whe people want to have their signals go skyward, they actually lower their antennas. I’ve got to go to bed, but I’ll check in the morning to see if I made things worse. Quote
piggin Posted September 22, 2024 Report Posted September 22, 2024 34 minutes ago, LeoG said: Pretty sure I won't be able to help myself about reporting what ends up happening with my system. I'm hoping that getting above the trees is one of my main issues. If I had patience I would wait for winter to come in and all the leaves on the tree to be on the ground. If my signal at the house and elsewhere improved then I would know for a fact that one of the more prominent issues I'm dealing with. I know in the direction without trees I have a good signal 6 miles away. Which of course isn't that far, but the hilly areas I live around are somewhat insurmountable issues that can't be worked around other than height. I am looking forward to the leaves being down here too. I am very happy with my system working better as the leaves fall. Winter is wonderful here on UHF. The only downside is ducting is much poorer in the winter VS fall and the spring. As it is, I am pretty happy with my current antennas. Quote
LeoG Posted September 22, 2024 Author Report Posted September 22, 2024 7 hours ago, SteveShannon said: Sure! And trust me on this, I’m no expert on reading this either! You’re exactly right, this shows gain, (no relationship to the distance the signal might carry!) with the outermost ring being the reference based on the maximum signal strength. That’s all it means. We all look at these and wonder what they have to do with distance, but that the way to torture yourself. Just so I can look at it easily while talking about it: Those lobes are actually what has either been simulated or measured. Whoever put this together found the direction of max gain and measured the strength of the signal in that direction. Then, in other directions they measure the signal strength and compare the max against the strength in that direction to determine how many dB down the signal is in any other direction. The blue lines showing the lobes simply indicates the loss of signal strength with the smallest lobes showing greater loss. So, for instance, there’s a lobe nearly centered on the 60° angle. The intersection of the outermost extreme of the lobe falls between the -10 dB and -20 dB circles, but I would estimate between -16 and -17 dB. So that simply tells us that at that angle, the measurement of signal strength was about 16 or 17 dB weaker than the maximum signal. Note that directly above and below (0° and 180°) there is no blue. That means there’s a point above and below where there was no signal, a null reading on the field strength meter. That null actually appears to subtend an angle about 10° right and left of vertical. That’s why placing a repeater on your roof and trying to hit it with another radio that happens to be within that “cone of silence” could be really frustrating. You’re within eyesight of the antenna, looking straight up at it, but you’re in a dead spot. Jist as a comment, the lobes are not symmetrical with respect to the horizontal axis. That’s probably because of the proximity to the ground. As you move the antenna up, the lobes below the horizontal axis will become more and more like the upper ones. Sometimes, whe people want to have their signals go skyward, they actually lower their antennas. I’ve got to go to bed, but I’ll check in the morning to see if I made things worse. I think a lot of my problem is this is a graph of gain and not power. And your explanation of the concentric circles makes more sense to me because the outer circle is of max gain and as you go inward you are subtracting dB gain as compared to the outer circle of max gain. With my current antenna, I have no diagram of gain and I don't have an issue with trying to hit the repeater whilst under the antenna. I have my HT on low power and I'm using a stubby antenna. Although I have heard crackling in my signal which I though of as strange because of my proximity closeness to the antenna but it is likely I'm in the dead spot and my signal is superficially getting to the antenna only because of the brute strength of the signal by being so nearby. So if someone was making this graph they would need to have a constant power radiating signal and they would move it around the antenna in a 360º spherical pattern while taking measurements at each azimuth point and recording the strength of the signal and then find the strongest and weakest signals and determine the logarithmic strength between the high and low and then plot it on the graph. Not sure if they need to do a spherical measurement or just a simplistic 2D simple circle going around the antenna in a vertical pattern. Quote
SteveShannon Posted September 22, 2024 Report Posted September 22, 2024 57 minutes ago, LeoG said: I think a lot of my problem is this is a graph of gain and not power. And your explanation of the concentric circles makes more sense to me because the outer circle is of max gain and as you go inward you are subtracting dB gain as compared to the outer circle of max gain. With my current antenna, I have no diagram of gain and I don't have an issue with trying to hit the repeater whilst under the antenna. I have my HT on low power and I'm using a stubby antenna. Although I have heard crackling in my signal which I though of as strange because of my proximity closeness to the antenna but it is likely I'm in the dead spot and my signal is superficially getting to the antenna only because of the brute strength of the signal by being so nearby. So if someone was making this graph they would need to have a constant power radiating signal and they would move it around the antenna in a 360º spherical pattern while taking measurements at each azimuth point and recording the strength of the signal and then find the strongest and weakest signals and determine the logarithmic strength between the high and low and then plot it on the graph. Not sure if they need to do a spherical measurement or just a simplistic 2D simple circle going around the antenna in a vertical pattern. Yes, or simply transmit a constant signal from the antenna and move a field strength detector around it. Most antennas don’t have a complete null above and below. That’s characteristic of a high gain antenna. In fact, multiple lobes like you see in that chart are characteristic of high gain antennas. If you look at the charts for a low gain antenna, such as a vertical dipole you’ll see two graphs, one from the side and one from above. The graph from above (called azimuth in this image) looks like a fairly smooth circle, showing that the signal strength is approximately even in all directions. Taken from the side (elevation) the signal strength of a dipole looks like a squashed figure eight. The three dimensional colored image helps understand that the squashed figure eight is swept or rotated around the z axis. The vertical dipole forms the z axis. By the way, while looking for these images I found this description on how to understand antenna graphs. I haven’t read it yet, but it appears to explain a lot of different aspects. https://gristleking.com/all-about-antennas-radiation-patterns/comment-page-1/ AdmiralCochrane, BoxCar and LeoG 2 1 Quote
LeoG Posted September 26, 2024 Author Report Posted September 26, 2024 Well it came in. The packaging freaked me out a bit. It said 70cm which I know is 440MHz, but it also had a "C" sticker put on the end of the original printed label. I wrote Jim and he assured me it was the correct antenna and said it came that way from the manufacturer. After I got a response from Jim from Chatt Radio I noticed the antenna had a sticker on it saying it was indeed the CA-712EFC antenna On top of that the stated 9.0dBi gain listed on all the websites I've seen but the gain is listed on the package and in the literature as 9.8dBi gain. Not much of a boost. But going from 7.2 to 9.0 vs 7.2 to 9.8 is 1.8 change vs 2.6 additional gain. Nice. GrouserPad 1 Quote
LeoG Posted January 17 Author Report Posted January 17 Ok I came back to this radiation pattern and I think I'm understanding it a bit more. Basically you need to think of it as angle and not distance. So if you put the antenna at 20' and another antenna a mile away still at 20' then the gain is 9.77+/-. If you have that antenna on a mountain top at 400' and the same receive antenna at 20' the angle is going to be much greater and you follow that angle on the graph and where it connects with the blue line is the gain that you will have. Power received will be determined by the square of the distance. So from my shop to my house the angle is 0.52º so that keeps the gain pretty close to max. Probably drops it by .5db or something like that. Hard to even see it with the fat lines and the resolution of the graph. SteveShannon 1 Quote
LeoG Posted April 13 Author Report Posted April 13 OK, still waiting to get this antenna up for my repeater, but I've bought a second one for the house. I had a water infiltration issue in my coax and need to replace that. Since I borrow a bucket truck to get up there I am also replacing the current antenna with the 712EFC. What I'd like to know deals with waterproofing the system because I don't plan on going through this again. The 712 is a two pc antenna and it has a screw type grommet system to join the antennas. This is a possible water infiltration point. I got some marine type heat shrink tubing (1.5") and plan on wrapping the joint with 3M rubber splice tape that was recommended here someplace. And then cover that with the heat shrink tubing. It has an adhesive in it to seal everything off. On the top of the antenna is a cap, I plan on sealing this too just in case. Just want to make sure doing this won't affect the SWR or performance of the antenna. I don't think it should but I figured I'd ask anyway. I plan on wrapping the N connectors with the 3M and the heatshrink tubing also at all my connections at the antenna and the lightning arrester. GrouserPad 1 Quote
WRYZ926 Posted April 13 Report Posted April 13 Wrapping the connections won't have any effect on the SWR. I wrapped the joint on my CA-712EFC along with the coax connection with Scotch 33 tape a layer of self fusing rubber tape and then another layer of Scotch 33. I tested the SWR before and after wrapping things and didn't notice any difference. Using marine grade heat shrink will work fine too. It's just harder to remove if needed. I use marine grade heat shrink to cover my clamp. on ferrite beads that I use for common mode chokes on the coax near the antenna connections. The main reason I put a layer of Scotch 33 on first is it is easier to get that off of the coax connectors compared to the self fusing rubber tape. And I always seal the joints on the Comet antennas I have even though they do have rubber gaskets. It's better to be safe than sorry. SteveShannon 1 Quote
LeoG Posted April 13 Author Report Posted April 13 39 minutes ago, WRYZ926 said: Wrapping the connections won't have any effect on the SWR. I wrapped the joint on my CA-712EFC along with the coax connection with Scotch 33 tape a layer of self fusing rubber tape and then another layer of Scotch 33. I tested the SWR before and after wrapping things and didn't notice any difference. Using marine grade heat shrink will work fine too. It's just harder to remove if needed. I use marine grade heat shrink to cover my clamp. on ferrite beads that I use for common mode chokes on the coax near the antenna connections. The main reason I put a layer of Scotch 33 on first is it is easier to get that off of the coax connectors compared to the self fusing rubber tape. And I always seal the joints on the Comet antennas I have even though they do have rubber gaskets. It's better to be safe than sorry. Ya, that's the reason I'm putting the tape on then the heat shrink. If for some reason I need to get in there the heat shrink glue is going to be adhered to above and below the joint and glued to the tape which is removable but still protected by the heat shrink. Are you saying the self fusing tape will stick hard to the antenna and connector points? I am using 3M Temflex 2155. Quote
WRYZ926 Posted April 13 Report Posted April 13 4 minutes ago, LeoG said: Are you saying the self fusing tape will stick hard to the antenna and connector points? I am using 3M Temflex 2155. The self fusing rubber tape definitely leaves more glue residue on the surface when removed compared to electrical tape. Here is a good video about wrapping connections. The RIGHT Way to Seal Coax – Lasts for YEARS! LeoG and SteveShannon 1 1 Quote
WSFF627 Posted April 17 Report Posted April 17 I'm wondering what coax your using. I'd recommend 7/8 heliax or similar due to the length involved. You can often find some good used cable from radio shops that they have removed from service on a commercial site. Also run a jumper from the main feedline to the antenna to allow for movement between the two in order to take stress off the connectors. A loose connection will cause desense and drive you nuts. I'd also recommend a RX preamp from Advanced Receiver. I have a handful of them and they make a big difference. To your comment about getting above the trees, your right on point there, just getting above the tree line will make a big positive improvement. Also, ground the coax toward the lower end of the tower above where it bends to go into your repeater location and take the ground straight down towards the ground to a proper ground rod. The lightning arrestor should be located just outside the building. Repeater Builder has a section on Motorola site standards that is helpful. Here is a site you can model your coverage on https://www.ve2dbe.com/english1.html Quote
LeoG Posted April 17 Author Report Posted April 17 I'll only be using 1/2" Heliax for my transmission line. For me the cost difference for the dB gain isn't worth it on a 80 foot run to upgrade to 7/8" (1.18dB vs 0.65dB 32 vs 36 watts at the antenna in my situation). And there's no way I'd want to take the chance of getting used coax they may or may not be compromised from the weather. This isn't an area repeater, it's for my family for use in town and maybe farther out if the radio Gods permit it. I don't have nearly enough height to get real distance out of it. I don't expect much more than 10-12 miles in my terrain. Quote
tcp2525 Posted April 17 Report Posted April 17 5 hours ago, WSFF627 said: I'm wondering what coax your using. I'd recommend 7/8 heliax or similar due to the length involved. You can often find some good used cable from radio shops that they have removed from service on a commercial site. Also run a jumper from the main feedline to the antenna to allow for movement between the two in order to take stress off the connectors. A loose connection will cause desense and drive you nuts. I'd also recommend a RX preamp from Advanced Receiver. I have a handful of them and they make a big difference. To your comment about getting above the trees, your right on point there, just getting above the tree line will make a big positive improvement. Also, ground the coax toward the lower end of the tower above where it bends to go into your repeater location and take the ground straight down towards the ground to a proper ground rod. The lightning arrestor should be located just outside the building. Repeater Builder has a section on Motorola site standards that is helpful. Here is a site you can model your coverage on https://www.ve2dbe.com/english1.html Do I believe my eyes? Someone that actually nows their stuff. Using anything other than LMR-400 is totally taboo from what you read on this forum. Did I tell you that it's totally and utterly foolish and breaks every terrestrial and celestial boundary of human stupidity to use anything other than Heilax for UHF. WSFF627 1 Quote
tcp2525 Posted April 17 Report Posted April 17 2 hours ago, LeoG said: I'll only be using 1/2" Heliax for my transmission line. For me the cost difference for the dB gain isn't worth it on a 80 foot run to upgrade to 7/8" (1.18dB vs 0.65dB 32 vs 36 watts at the antenna in my situation). And there's no way I'd want to take the chance of getting used coax they may or may not be compromised from the weather. This isn't an area repeater, it's for my family for use in town and maybe farther out if the radio Gods permit it. I don't have nearly enough height to get real distance out of it. I don't expect much more than 10-12 miles in my terrain. Good choice on the 1/2". Should you ever want to upgrade to 7/8" new reel ends can be had for $1.00 a foot if you know where to look for it. Quote
WRYZ926 Posted April 17 Report Posted April 17 Just my opinion. I feel that LMR400 is mostly recommended because people don't want to spend the money on Heliax. GMRS users can be as tight as amateur radio operators when it comes to spending money. It really boils down to using the best that you can afford. And for most, LMR400 and equivalent is good enough. I will agree that Heliax is definitely better, especially for repeater use. We use 7/8" Heliax for our GMRS repeater with the antenna at 400 feet above ground. 1 1/4" Heliax would perform better but the 7/8" was free. gortex2, tcp2525 and WRUU653 3 Quote
