WSEQ823 Posted September 20, 2024 Report Posted September 20, 2024 I have been looking for the input Freq for the repeters around me but I dont see any listed, so how do I determine what the on put freq are? Quote
0 Rulander Posted September 20, 2024 Report Posted September 20, 2024 I'm new to this a bit, but I believe that if there is only an output freq listed, then the input will be the same. I usually just add the TX freq and call it good. WRVR303 1 Quote
0 BoxCar Posted September 20, 2024 Report Posted September 20, 2024 Repeaters are normally listed by their output frequency, you receive channel. Repeater channels set in your radio have the correct output channel (5 MHz higher) coded into the channel selected. Repeater input frequencies are all at 467 MHz while all the other channels are 462 MHz. WRXB215 and WRUU653 2 Quote
0 Rulander Posted September 20, 2024 Report Posted September 20, 2024 4 minutes ago, BoxCar said: Repeaters are normally listed by their output frequency, you receive channel. Repeater channels set in your radio have the correct output channel (5 MHz higher) coded into the channel selected. Repeater input frequencies are all at 467 MHz while all the other channels are 462 MHz. I believe that is the answer he was looking for. I was thinking tone was what he was asking. There goes my newb-ness showing Quote
0 WRXL702 Posted September 20, 2024 Report Posted September 20, 2024 The Input Frequencies On Any GMRS Repeater Station Will Be + (plus) 5 MHz From The Receive Frequency. This Is Referred To As The + 5 MHz Offset. Example - A 462.550 GMRS Repeater Frequency Will Need Your Radio To Transmit On 467.550 To A Repeater. Any applicable CTCSS Or DCS Tones For Access Will Also Be Required. The Repeater Then Re-transmits On The 462.550 Frequency To All CTCSS / DCS Receiving Radios. Quote
0 Guest Posted September 20, 2024 Report Posted September 20, 2024 Always plus 5.0 if your using a gmrs radio this is pre set Quote
0 dosw Posted September 20, 2024 Report Posted September 20, 2024 You shouldn't have to specify an input frequency for the repeater, you should set your radio up with the output frequency: 462.xxxx, the offset: +5MHz, and the tx/rx tones. RX tone is not as important except that it will help you reject hearing kiddies playing walkie talkie. What radio are you setting up, and what software are you using to do it? Quote
0 OffRoaderX Posted September 20, 2024 Report Posted September 20, 2024 The easy answer: OUTPUT always starts with 462 INPUT always starts with 467 Everything after the . is always the same. Example: Output of 462.575 would have an input of 467.575 Quote
0 BoxCar Posted September 21, 2024 Report Posted September 21, 2024 4 hours ago, OffRoaderX said: The easy answer: OUTPUT always starts with 462 INPUT always starts with 467 Everything after the . is always the same. Example: Output of 462.575 would have an input of 467.575 High out, low in is easier to remember. Quote
0 nokones Posted September 21, 2024 Report Posted September 21, 2024 9 hours ago, BoxCar said: High out, low in is easier to remember. Huh? I hope you are referring to the mobile device meaning high up (up link) (transmitting) to the repeater and low (down link) (receiving) down from the repeater. WRYZ926 and SteveShannon 2 Quote
WSEQ823
9 answers to this question
