I have been using a magnetic NMO mount on my vehicle for about 6 months. I did not like the cord showing so I decided to install a through hole mount in my roof since people are saying it is just overall better to mount this way. I installed it as according to the instructions and when I went to turn the radio on, it would not receive anything. My radio is capable of receiving the NOAA radio channels and I was planning on tuning into the strongest one for my area before I attempted to transmit. I assumed that if I did not set up the antenna correctly. I would damage my radio if I tried to transmit. The interesting part of this is that when I turned the vehicle off, the radio began receiving the NOAA channel very clearly for the 3 seconds it takes for it to turn off. I have no idea what this means. I believe I assembled everything correctly and I checked all of the connections at the radio itself. Any suggestions would be appreciated.
WRTZ361
Top Posters For This Question
12
11
8
6
Popular Days
Oct 29
19
Oct 27
18
Oct 28
13
Oct 30
1
WRYZ926 12 posts
WRTZ361 11 posts
SteveShannon 8 posts
nokones 6 posts
Popular Days
Oct 29 2024
Oct 27 2024
Oct 28 2024
Oct 30 2024
1 post
Popular Posts
nokones
Ask Steve stated, with the multi-meter, you want to check and see if you have continuity from the center pin of the PL259 connector to the center contact of the NMO mount. Your reading should be "zero
WRTZ361
I went out to my car this morning and turned my car on. Turned on the radio and it just worked. I changed nothing since trying it last night and it just started receiving. There is a small amount of n
SteveShannon
I don’t see anything there that makes me cringe. The radio is as good of a GMRS certified radio as you can get. The Midland mount is okay. It’s nice to install because it only requires a 3/8” hole.
51 answers to this question
