WSFQ673 Posted November 28, 2024 Report Posted November 28, 2024 TdiRadio is selling two (at least) versions of the TD-H3. Is there a significant difference between the two? I know there is a difference in what is included in the package, but it appears to be the same radio. Is the only difference which band is unlocked for Tx? Quote
GMRSJohn Posted November 28, 2024 Report Posted November 28, 2024 Interesting.. I know the H3’s can be both ham and GMRS. I’ve been looking at them recently myself but for strictly GMRS use. TrikeRadio 1 Quote
LeoG Posted November 29, 2024 Report Posted November 29, 2024 Both the same radio. I believe the only difference in the package is what antenna it comes with. GMRS tuned or Ham tuned. Both radios can be changed to either GMRS, Ham or Normal which is unlocked. WSAQ296 and TrikeRadio 2 Quote
WSAQ296 Posted December 7, 2024 Report Posted December 7, 2024 They are effectively the same radio. Depending on how you order depends on the antenna(s) shipped with the unit. Upon powering up, there's a sequence of buttons that can be pressed to change it from gmrs to ham or 'normal' (open to all). I leave mine gmrs, as the whole point is to be able to hand a channelized radio to someone for use, not to accidentally have them dial up some unknown freq. RIPPER238 1 Quote
WRXB215 Posted December 7, 2024 Report Posted December 7, 2024 3 hours ago, WSAQ296 said: not to accidentally have them dial up some unknown freq Who you calling a freak? WRTC928 and SteveShannon 2 Quote
RIPPER238 Posted December 7, 2024 Report Posted December 7, 2024 On 11/28/2024 at 3:45 PM, WSFQ673 said: TdiRadio is selling two (at least) versions of the TD-H3. Is there a significant difference between the two? I know there is a difference in what is included in the package, but it appears to be the same radio. Is the only difference which band is unlocked for Tx? The H3 for GMRS & Ham are effectively the same radio, just comes with different antennas and different initial programing (GMRS-Ham). I have 2 Ham and 1 GMRS and other than a slight power difference they work the same with the current updates. TrikeRadio 1 Quote
WSFI971 Posted December 10, 2024 Report Posted December 10, 2024 On 12/7/2024 at 2:00 PM, RIPPER238 said: The H3 for GMRS & Ham are effectively the same radio, just comes with different antennas and different initial programing (GMRS-Ham). I have 2 Ham and 1 GMRS and other than a slight power difference they work the same with the current updates. What’s the power difference? Quote
RIPPER238 Posted December 10, 2024 Report Posted December 10, 2024 1 hour ago, WSFI971 said: What’s the power difference? My 2 Ham models seem to have more consistent power across all bands where the GMRS model when in Normal does not. Not that its a huge difference, but its there. Could also just be inconsistency for a $30 radio. Quote
WSFM959 Posted March 25 Report Posted March 25 I have both the HAM and GMRS versions, the only difference I've found so far is that the HAM Radio doesn't seem to like working in GMRS repeater mode, as in even with the correct DCS programmed it wont send... It keys up and sends on 467 fine, but i don't get the kick back and it cant be heard on other radios. On standard channels it works fine, it just with repeaters it has problems. Quote
LeoG Posted March 25 Report Posted March 25 There is no difference between the TD-H3 Ham and GMRS radios. When they send you the radio it tuned to the frequency of the band you bought. The radio will come with antennas specific to the radio you bought. HAM will come with antennas tuned for those frequencies and GMRS will come with an antenna tuned for that frequency. It's just the mode you choose to put it in. Most of the H3s I have are HAM versions and I bought a GMRS version and the only difference is the antenna(s) Quote
WSEZ864 Posted March 25 Report Posted March 25 1 hour ago, WSFM959 said: I have both the HAM and GMRS versions, the only difference I've found so far is that the HAM Radio doesn't seem to like working in GMRS repeater mode, as in even with the correct DCS programmed it wont send... It keys up and sends on 467 fine, but i don't get the kick back and it cant be heard on other radios. On standard channels it works fine, it just with repeaters it has problems. Most repeaters are 'tone coded' (CTCSS) and not DCS. Double check your repeater's requirements. Quote
marcspaz Posted March 25 Report Posted March 25 Actually, if you look at RepeaterBook and MyGMRS public listings, you will see that use of CTCSS grossly outweighs DCS. Raybestos, WSEZ864, WRUU653 and 2 others 3 2 Quote
Jaay Posted March 25 Report Posted March 25 On 11/28/2024 at 2:45 PM, WSFQ673 said: TdiRadio is selling two (at least) versions of the TD-H3. Is there a significant difference between the two? I know there is a difference in what is included in the package, but it appears to be the same radio. Is the only difference which band is unlocked for Tx? The TID- H3 Plus has some added Bluetooth features the previous model apparently didn't have, but that's all I've read so far. Quote
BoxCar Posted March 25 Report Posted March 25 10 hours ago, Socalgmrs said: What is a repeater kick back? Never heard of that and I use repeaters every day. Second I’m betting your tones are. It correct or your not close enough to the repeater. You wo t be heard on other radios u less the repeater gets your transmission. Nana NoNo hasn't heard of a term describing squelch tail? Oh, the horrors...... WRUU653 1 Quote
WSFM959 Posted March 26 Report Posted March 26 Kickback, Handshake, Squelch Tail = Response from the repeater in my language, sorry, i'm a Brit living in the US. Oh and all of our local repeaters use DCS. Everything is set up the same on both radios, but the GMRS version gets the signal out and i get a response, the Ham radio set to GMRS mode doesn't. Quote
WSFM959 Posted March 26 Report Posted March 26 Oh to add, both radios work fine in simplex mode, GMRS to HAM versions Set to GMRS mode, I can send and receive on both. It's when I go to Duplex (repeater mode) the HAM version set to GMRS mode just will not transmit. Ive even had my SDR set to the channel, monitoring it... and I get nothing. I would like to invite others with both versions to try, IMHO there is a very subtle difference between the two versions, which was in response to the initial question. Quote
WRTC928 Posted March 26 Report Posted March 26 On 3/24/2025 at 9:53 PM, marcspaz said: Actually, if you look at RepeaterBook and MyGMRS public listings, you will see that use of CTCSS grossly outweighs DCS. I have noticed that. I assumed it's just a matter of habit. Of course, repeaters that have been up for a long time aren't likely to change from CTCSS to DCS, but AFAIK, there's no significant advantage of one over the other and any radio built in the last 10 years is probably capable of both. Repeaters installed recently certainly could use DCS, but apparently most of them still use CTCSS. marcspaz 1 Quote
WSFM959 Posted March 26 Report Posted March 26 Well on further research, i noticed there was another post regarding the H3 not opening repeaters, It would be interesting to see how many H3's were bought as the HAM variants Quote
TrikeRadio Posted March 26 Report Posted March 26 4 hours ago, WSFM959 said: Well on further research, i noticed there was another post regarding the H3 not opening repeaters, It would be interesting to see how many H3's were bought as the HAM variants The "Ham version" and the "GMRS version" are EXACTLY the same radio. They only sell them as Ham or GMRS so as to include appropriately tuned antennas with them (which you can replace with anything anyway). either "Ham" or "GMRS" radios can be switched into either Ham or GMRS or "Normal" (unlocked) modes and then will obey rules for Ham or GMRS as far as transmit power levels and allowed frequencies for transmitting. GMRS will also adhere to the +5 offset for repeaters that are setup properly (at least under channel 55 it seems) WSEN940 1 Quote
