VETCOMMS Posted December 24, 2024 Report Posted December 24, 2024 I'm starting to find interest in this radio as it's DMR and analog tri band. Does anyone have this radio? Could it be used with an LMR license to transmit using AES256? Just hoping to learn from those with experience using this radio. Quote
BoxCar Posted December 25, 2024 Report Posted December 25, 2024 You'll need to check the FCC registration to see if it has Part 90 approval. l know the D878 is both Part 90 and 97.1 Quote
AdmiralCochrane Posted December 25, 2024 Report Posted December 25, 2024 578 is my everyday radio, but I generally just use it on 2m VETCOMMS 1 Quote
VETCOMMS Posted December 25, 2024 Author Report Posted December 25, 2024 How is it to program for both analog and digital? Is the cps confusing? I've read you have to unlock it when you get it? Do you use the vehicle Bluetooth with it or that separate Bluetooth device and store the radio remotely? Quote
AdmiralCochrane Posted December 26, 2024 Report Posted December 26, 2024 I found the Bluetooth feature too distracting for me to safely use and went back to just using the mic. It has been more than a year since I stopped using the Bluetooth and I think the problem was delayed reaction time and the amount of planning you had to do to use it for each transmission. You still have to have the radio where you can reach it, the Bluetooth basically only makes the mic itself hands free. The Bluetooth was easy to set up and program. APRS took a little more time to set up. Programming is pretty straight forward, identical to many other mobile radios. Chirp plays well with Anytones. Like just about every other radio sold in the US, if you want to transmit outside of ham bands, you must select an alternate control configuration (I think there are 8 choices). VETCOMMS 1 Quote
WSEF273 Posted May 10 Report Posted May 10 Had to do a factory reset now the channel set under settings is gone. Any tips? Quote
OffRoaderX Posted May 10 Report Posted May 10 30 minutes ago, WSEF273 said: Had to do a factory reset now the channel set under settings is gone. Any tips? I'll give you TWO tips! always back-up your channel set before doing a factory reset dont run with scissors WRXB215, SteveShannon, WRYZ926 and 1 other 2 2 Quote
WRYZ926 Posted May 10 Report Posted May 10 5 hours ago, OffRoaderX said: I'll give you TWO tips! always back-up your channel set before doing a factory reset dont run with scissors Two very important tips to always remember. SteveShannon 1 Quote
