WRTC928 Posted January 8, 2025 Posted January 8, 2025 A few months ago, I bought a CB radio for my truck after decades of being off the air. Since September 2021 (IIRC) CBs can use FM mode, and this one has that capability. To my surprise, it also has the capability to use "privacy" (a misnomer, but whatever) tones. So, it's now a radio that transmits in FM mode on a free, channelized service, in essence just like FRS. Unlike FRS, however, it can operate at 4 watts, is allowed to have external antennas, and has 40 channels instead of 22. There's no technical reason why FRS would be a better choice for family/friends traveling together or camping/whatever. The main impediment to widespread adoption of FM CB for "family" communication, as I see it, is the cost of entry. CB radios can be had fairly cheaply, but not as cheaply as the "bubble pack" FRS radios. Is there any chance that FM CB could eventually take a significant portion of the FRS market? (Full disclosure -- I don't really care, I'm just curious.) Quote
OffRoaderX Posted January 8, 2025 Posted January 8, 2025 There is at least one technical reason why FRS would be a better choice: You can get way (wayyyy) more fars-per-inch of the antenna with an FRS than a hand-held CB.. a 5-inch antenna an on FRS radio can get you 10miles in excellent conditions, ~1/2 mile in decent/poor conditions. For those same farz on CB, you would need a 25-inch (just a guess, but much larger, you get the point) antenna on the radio, making a hand-held very unwieldy and a potential deadly eye-poking menace. TrikeRadio, Elmo777, Blaise and 4 others 6 1 Quote
Lscott Posted January 8, 2025 Posted January 8, 2025 29 minutes ago, WRTC928 said: There's no technical reason why FRS would be a better choice for family/friends traveling together or camping/whatever. Except for the ridiculously huge antennas to get any kind of reasonable range out of a portable radio. Somehow a 102 inch quarter wave whip antenna on a hand held radio doesn't sound very convenient. Not to mention the size of the required ground plane to go with it. At FRS/GMRS frequencies a quarter wave antenna is about 6 inches long. The metal chassis of your hand held radio is about that size making for a reasonable ground plane. Quote
WRTC928 Posted January 8, 2025 Author Posted January 8, 2025 Hmmm... Those are good points. I hadn't thought about the length of the antenna. It's less of an issue on a vehicle, but then it's a lot less convenient because you can't get out of the vehicle and take it with you. The best compromise between portability and power is still GMRS, and even without the antenna issue, FM CB wouldn't be a better option than GMRS due to its power limitations. Eh. It was just a thought exercise. Quote
marcspaz Posted January 8, 2025 Posted January 8, 2025 I'm going to close my post out with something that will piss some people off, and others will say I don't know what I am talking about... so if you don't want to read all of the post, you may want to skip to the END. The reason CB went to the wayside isn't known for sure, but I have a few ideas. Modulation type isn't one of them. I think there is zero chance of CB replacing FRS. I don't think it could even take a significant part of the market, and I will explain why. First, people get extremely frustrated because their mobile CB radio performs so poorly, with regard to range. As mentioned above, that is almost always due to the antenna. The primary problem is, the average DIY person doesn't poses the tools or skills to properly install a CB and antenna, nor verify if it is working correctly. This wasn't always the case, but somewhere in time, this common knowledge kind of vanished, leading people to think they can just bolt on the antenna and life is good. Then, there is the size of the antenna. The shortest proper length for a CB antenna is 104 inches. That's not a type-o... that is over eight and a half feet. Not everyone is willing to put an antenna that big on their vehicle. So, you see everyone using a compromised antenna... like the 4' and even 3' firestik antennas. I own a 4 footer and a 1 footer, but I know they are only going to work for a mile or less. FRS is at a frequency that only requires a 6" antenna, and the installation is way, way more forgiving. Just by it's nature, its not common to incorrectly install an FRS antenna. And when manufacturers put even shorter antennas on them, say a 3", it's no where near the compromise made in CB with a 3' antenna. So, you take a radio and antenna that doesn't install correctly easily and complicate that install with an antenna that more resembles a dummy load than an antenna, and yeah, the performance is gonna suck. Creating an even smaller, overpriced version in a handheld doesn't sound like a good time, either. Now, there is also another issue to deal with. While there are FM CB radios available, FM quality on CB is no where near the audio quality of FRS. FRS radio uses a lot more bandwidth, which means the signal can carry more data, aka higher fidelity audio. Many people will prefer FRS just because it sounds better. END Now to upset some people... I believe that a properly installed mobile CB and antenna or a quality CB handheld will outperform an FRS radio 100% of the time. I also believe that a properly installed mobile CB and antenna AND a quality CB handheld will outperform their counterpart in GMRS radio a vast majority of the time, when it comes to P2P comms. The two top reasons why GMRS has made it to the top of the pile is due to repeaters and the frequency used is ideal for heavily wooded and dense urban areas. While generally, I believe CB is superior in many cases, it seems that US radio use in dense woods and cities are the most common use cases... hence GMRS (and FRS) win over mobile and handheld CB. Lscott, WRTC928, dosw and 8 others 10 1 Quote
WRTC928 Posted January 8, 2025 Author Posted January 8, 2025 See? Even if you ask a stupid question, you can learn something. HHD1 and marcspaz 1 1 Quote
SteveShannon Posted January 8, 2025 Posted January 8, 2025 4 minutes ago, WRTC928 said: See? Even if you ask a stupid question, you can learn something. It wasn’t a stupid question. FishinGary, marcspaz, WRUU653 and 3 others 6 Quote
WRYS709 Posted January 8, 2025 Posted January 8, 2025 3 hours ago, WRTC928 said: A few months ago, I bought a CB radio for my truck after decades of being off the air. Since September 2021 (IIRC) CBs can use FM mode, and this one has that capability. To my surprise, it also has the capability to use "privacy" (a misnomer, but whatever) tones. So, it's now a radio that transmits in FM mode on a free, channelized service, in essence just like FRS. Unlike FRS, however, it can operate at 4 watts, is allowed to have external antennas, and has 40 channels instead of 22. There's no technical reason why FRS would be a better choice for family/friends traveling together or camping/whatever. The main impediment to widespread adoption of FM CB for "family" communication, as I see it, is the cost of entry. CB radios can be had fairly cheaply, but not as cheaply as the "bubble pack" FRS radios. Is there any chance that FM CB could eventually take a significant portion of the FRS market? (Full disclosure -- I don't really care, I'm just curious.) Yes! And with the 11 year solar sun cycle at its Maximum, enjoy DX when the band opens! Quote
Davichko5650 Posted January 8, 2025 Posted January 8, 2025 2 hours ago, marcspaz said: I'm going to close my post out with something that will piss some people off, and others will say I don't know what I am talking about... so if you don't want to read all of the post, you may want to skip to the END. The reason CB went to the wayside isn't known for sure, but I have a few ideas. Modulation type isn't one of them. I think there is zero chance of CB replacing FRS. I don't think it could even take a significant part of the market, and I will explain why. Two-way radio for the non-hobbyist or dedicated user seems to be a fad item, As the CB boom of the mid 70's came and went, it has died down; a small resurgence is occurring in that service as seen by the plethora of YT videos and FB groups. But F/GMRS is the current go to in the radio fad world. Prepper driven to some extent, but also the mass availiblity of the units (both FR and GMR) and the ease of use has made it the radio du jour! marcspaz and WRTC928 2 Quote
Lscott Posted January 9, 2025 Posted January 9, 2025 On 1/8/2025 at 5:00 PM, Davichko5650 said: Two-way radio for the non-hobbyist or dedicated user seems to be a fad item, As the CB boom of the mid 70's came and went, it has died down; a small resurgence is occurring in that service as seen by the plethora of YT videos and FB groups. But F/GMRS is the current go to in the radio fad world. Prepper driven to some extent, but also the mass availiblity of the units (both FR and GMR) and the ease of use has made it the radio du jour! It helps a lot when the GMRS radios are small enough to fit in your pocket. The huge silver telescope antenna on a hand held CB looks like some kind of exotic taser weapon to non technical people. Just holding on to the end of the antenna and swinging it around makes for a reasonably useful club too. AdmiralCochrane, SteveShannon, WRTC928 and 2 others 1 4 Quote
LeoG Posted January 10, 2025 Posted January 10, 2025 On 1/8/2025 at 2:58 PM, marcspaz said: Now to upset some people... I believe that a properly installed mobile CB and antenna or a quality CB handheld will outperform an FRS radio 100% of the time. I also believe that a properly installed mobile CB and antenna AND a quality CB handheld will outperform their counterpart in GMRS radio a vast majority of the time, when it comes to P2P comms. The two top reasons why GMRS has made it to the top of the pile is due to repeaters and the frequency used is ideal for heavily wooded and dense urban areas. While generally, I believe CB is superior in many cases, it seems that US radio use in dense woods and cities are the most common use cases... hence GMRS (and FRS) win over mobile and handheld CB. Are you saying 462MHz will penetrate woods better than 27MHz. Because GMRS does pretty poor in wooded areas by my experience, especially in leafy woods WRXB215 1 Quote
SteveShannon Posted January 10, 2025 Posted January 10, 2025 27 minutes ago, LeoG said: Are you saying 462MHz will penetrate woods better than 27MHz. Because GMRS does pretty poor in wooded areas by my experience, especially in leafy woods My understanding is that UHF is better at penetrating dry structures than HF or VHF (which is why cell phones work in buildings), but it’s worse at penetrating water or water bearing vegetation, which is why leafy trees affect it. Ian and DominoDog 2 Quote
marcspaz Posted January 10, 2025 Posted January 10, 2025 1 hour ago, LeoG said: Are you saying 462MHz will penetrate woods better than 27MHz. Because GMRS does pretty poor in wooded areas by my experience, especially in leafy woods I understand what the science says, but real-world, yes. I spend a tremendous amount of time out in the woods while 4-wheeling, and FRS HTs have always out performed stock CB radios... like 100% of the time. GMRS radios running 20w+ usually outperform modded/peaked CBs around the same power. Again, we are talking about an overwhelming number of CB users with poor-bad installation, poor antenna selection, etc. There was one CBer I wheeled with who was the tail vehicle on a 12 vehicle group, who's radio was so bad that I could see him in my rear-view, but couldn't hear him on the radio. I don't have any experience out in the woods with people who had good radios. gortex2 1 Quote
nokones Posted January 10, 2025 Posted January 10, 2025 I did some comparison testing measuring distances between FRS being operated inside of a vehicle and the CB Radio in both the AM and FM modes. The test was conducted on relatively flat desert terrain essentially nothing but giggley weeds and pucker bushes between the two test points at various distances. The FRS radio was operated on a two-watt channel and the maximum distance was just shy of a half-mile. The CB Radios were using 5-foot Tuneable Firestiks and the maximum distance was 2 1/4 miles in the AM mode and 3 1/2 miles in the FM mode. At the 3 1/2 mile test point and just for giggles, a 60-watt CB amplifier was turned on which barely put out 45 watts, and there was very little difference in the signal and audio qualities in the AM mode. The FM mode was not tested with the amplifier since it was not FM capable. Personally, I think the FM CB Radio could have potential use for Trail Comm. Lscott and WRTC928 2 Quote
LeoG Posted January 10, 2025 Posted January 10, 2025 Doesn't seem like a comparison that fair. Using a 2 watt UHF with an integrated antenna inside a vehicle against a 4 watt CB with an external antenna. Hardly apples to apples. More like apples to fish sticks. Most UHF HTs claim 5 watts but put out more like 4. So if you put a GMRS on a small external antenna it would be much more of a fair comparison. Quote
SteveShannon Posted January 10, 2025 Posted January 10, 2025 11 minutes ago, LeoG said: Doesn't seem like a comparison that fair. Using a 2 watt UHF with an integrated antenna inside a vehicle against a 4 watt CB with an external antenna. Hardly apples to apples. More like apples to fish sticks. Most UHF HTs claim 5 watts but put out more like 4. So if you put a GMRS on a small external antenna it would be much more of a fair comparison. Yes, a 5 watt GMRS handheld and external antenna is more comparable in capabilities and performance to CB, but the question raised by this thread was specifically about FRS versus CB. TNFrank and WRTC928 2 Quote
LeoG Posted January 10, 2025 Posted January 10, 2025 Well then use a CB walkie talkie inside the cab. Almost any external antenna will beat the tar out of an antenna inside a vehicle. Quote
SteveShannon Posted January 10, 2025 Posted January 10, 2025 4 minutes ago, LeoG said: Well then use a CB walkie talkie inside the cab. Almost any external antenna will beat the tar out of an antenna inside a vehicle. Why? If the goal is an honest comparison of the potential of two different services, why constrain one in such a way that it cannot achieve its potential? Quote
radiozip Posted January 10, 2025 Posted January 10, 2025 Before the coffee hit I thought the 5ft CB antenna was used INSIDE the cab! Hopefully the vehicle had a sunroof WRUU653 1 Quote
marcspaz Posted January 10, 2025 Posted January 10, 2025 30 minutes ago, LeoG said: Well then use a CB walkie talkie inside the cab. Almost any external antenna will beat the tar out of an antenna inside a vehicle. Obviously this doesn't speak to everyone's use case... but my experience is based on Jeeps and ATV/UTV use. So, my results could be anecdotal. While offroad most Jeeps have non-coductive tops or no top at all, windows rolled down or no doors at all, some ATVs/UTVs don't have windows, etc. So there is no interference to an HT inside the vehicle. Again, science aside, im just looking at my real-world experience and the use cases my family and friends have, to draw an opinion, if that make sense. Quote
WRUE951 Posted January 10, 2025 Posted January 10, 2025 I till have my Galaxy and every once in awhile and most recently i've broke out the 'ole beauty' in my truck and had some fun taking across the country.. Skip is coming back and its only going to get better and better. Don't be surprised when CB makes a big come back.. It won't kill GMRS but will be a fun supplement. Quote
LeoG Posted January 10, 2025 Posted January 10, 2025 Didn't think about that. I'm always in a full metal surround truck. marcspaz 1 Quote
LeoG Posted January 10, 2025 Posted January 10, 2025 1 minute ago, WRUE951 said: I till have my Galaxy and every once in awhile and most recently i've broke out the 'ole beauty' in my truck and had some fun taking across the country.. Skip is coming back and its only going to get better and better. Don't be surprised when CB makes a big come back.. It won't kill GMRS but will be a fun supplement. Rather the hoards go to CB and leave the GMRS frequencies open. Quote
WRCR724 Posted January 10, 2025 Posted January 10, 2025 20 minutes ago, LeoG said: Rather the hoards go to CB and leave the GMRS frequencies open. Are the GMRS frequencies that crowded in your area? Quote
