WRXU861 Posted April 3 Report Posted April 3 My new base radio arrived earlier this week, and I set it up with a home-made copper pipe J pole and RG 213 coax. I'm able to hear my local repeaters very clearly and have carried on a few conversations across a repeater that's about 30 miles away. Unfortunately, most other operators can't seem to hear me very well. Sometimes, they can, but not always. I've already set my antenna up where it has clear line of sight according to https://www.scadacore.com/tools/rf-path/rf-line-of-sight/, but it could always be higher. I've also made sure I'm using wide band, but my voice seems to be hit and miss over the repeater. If anyone has suggestions about how to make things better, please let me know. -Steve WRXU861 Quote
Hoppyjr Posted April 3 Report Posted April 3 -Move the antenna higher - Use a better antenna - More power- Accept the fact that you get what you get and be happy with that OffRoaderX and SteveShannon 2 Quote
OffRoaderX Posted April 3 Report Posted April 3 3 minutes ago, Hoppyjr said: Accept the fact that you get what you get and be happy with that THIS ^ Quote
BoxCar Posted April 3 Report Posted April 3 I would check the antenna. Use a Nano VNA if possible and check the frequency the antenna resonates at along with the bandwidth. As you stated it's a home brew, its possible it is off frequency. Quote
WRUU653 Posted April 3 Report Posted April 3 7 hours ago, WRXU861 said: . If anyone has suggestions about how to make things better, please let me know. Try higher and better antenna. Go to doughnut shop, get maple bars. Works for me but I’m only five miles from repeater and the doughnut shop is even closer. Pro tip make sure to get what kind the spouse likes if you have one. I may be distracted this morning. Sorry. Doughnuts… SteveShannon and GrouserPad 1 1 Quote
nokones Posted April 3 Report Posted April 3 Get an antenna analyzer and check and see what the center resonance is then check the VSWRs with the radio in-line with the antenna transmission system. Check your station output power with a Load Terminator that measures at 50 ohms. Also, make sure that repeater you're trying to access is either a wideband operation or a narrowband operation and set your station accordingly. WRUU653, SteveShannon and WRNU354 3 Quote
GrouserPad Posted April 3 Report Posted April 3 5 hours ago, Socalgmrs said: You didn’t say what radio/watts your base is but if everything else is working correctly and you really do have line of sight then it’s the junk pole antenna. Line of sight with a 5w hand held at 30miles should come in very clear so with a base and a good antenna like a comet 712efc and even a 15w base station with lmr400 cable 30mile should be a drop in the bucket. What is the output power of a 5 watt ht when it gets to the antenna after traveling 100ft up some rg213? About 1 watt. I’m calling shenanigans lol Quote
WRYZ926 Posted April 3 Report Posted April 3 3 hours ago, GrouserPad said: What is the output power of a 5 watt ht when it gets to the antenna after traveling 100ft up some rg213? About 1 watt. I’m calling shenanigans lol A lot will depend on the gain of the antenna. According to the https://kv5r.com/ham-radio/coax-loss-calculator/; you will get an ERP of 1.9 watts when using a radio with 5 watts output, 100 ft of RG-213, and an antenna with 1 dBd of gain. As you can see the calculated ERP is 1.9 watts Now the ERP will go up as the antenna gain goes up. So if the antenna gain is 2 dBd then the ERP will be 2.4 watts. And if you jump up to a gain of 5 dBd then the ERP will be 4.7 watts One thing to keep in mind is that most antenna manufacturers list the gain in dBi while most loss calculators use dBd. Subtract 2.14 from the dBi value to get the dBd value. The kv5r coax loss calculator is not exact but it is close enough to see what the loss difference is between different types of coax and at different lengths. WRNU354 and GrouserPad 2 Quote
WRUE951 Posted April 3 Report Posted April 3 14 hours ago, WRXU861 said: My new base radio arrived earlier this week, and I set it up with a home-made copper pipe J pole and RG 213 coax. I'm able to hear my local repeaters very clearly and have carried on a few conversations across a repeater that's about 30 miles away. Unfortunately, most other operators can't seem to hear me very well. Sometimes, they can, but not always. I've already set my antenna up where it has clear line of sight according to https://www.scadacore.com/tools/rf-path/rf-line-of-sight/, but it could always be higher. I've also made sure I'm using wide band, but my voice seems to be hit and miss over the repeater. If anyone has suggestions about how to make things better, please let me know. -Steve WRXU861 Copper J-Poles are pretty hard to build for UHF, you must get the precise measurements to a T for the frequencies and they extremely hard to tune SWR's. As others suggested the best way to tune them is via a NANO VNA. I came up with a sliding adjustment gimmick for tuning SWR that works well. Made with cooper compression splices you can get at home depot. WRUU653, WRNU354, WRYZ926 and 1 other 3 1 Quote
WRXU861 Posted April 3 Author Report Posted April 3 That's innovative. I went a different way with the tuning, though and got my right around 1.05. Today, I raised my antenna by about six feet, which greatly improved the situation. Turns out, the line of sight tool shows a green line of sight even if there's some topography in the way. The extra six feet cleared things up. Sometime over the next few weeks, I'm going to move it up another 10 or 15 feet. -Steve SteveShannon and WRUU653 2 Quote
WRXU861 Posted April 3 Author Report Posted April 3 11 hours ago, WRUU653 said: Try higher and better antenna. Go to doughnut shop, get maple bars. Works for me but I’m only five miles from repeater and the doughnut shop is even closer. Pro tip make sure to get what kind the spouse likes if you have one. I may be distracted this morning. Sorry. Doughnuts… The problem was the antenna height. My SWR is really good and I'm using 50 ft of RG213. I moved the antenna up from around 9 feet to around 15 feet. Now, I'm reliably getting through the repeater around 30 miles away. There's a little static, but just enough to remind me that I'm on a radio. WRUU653 and WRUE951 2 Quote
WRUE951 Posted April 4 Report Posted April 4 52 minutes ago, WRXU861 said: The problem was the antenna height. My SWR is really good and I'm using 50 ft of RG213. I moved the antenna up from around 9 feet to around 15 feet. Now, I'm reliably getting through the repeater around 30 miles away. There's a little static, but just enough to remind me that I'm on a radio. J-Poles don't like any type of obstruction around them.. I have talked 90 miles + with my portable setup when mounted out in a wide open area.. But when i get around something like a single treee, it goes to hell like what you are describing. Overall i get pretty good performance from it, defiantly better than a fire stick. I also built a Ladder Lead J-pole, like the Ed Fong version, the copper version seems to work much better. WRXU861 1 Quote
WRUU653 Posted April 4 Report Posted April 4 1 hour ago, WRXU861 said: The problem was the antenna height. My SWR is really good and I'm using 50 ft of RG213. I moved the antenna up from around 9 feet to around 15 feet. Now, I'm reliably getting through the repeater around 30 miles away. There's a little static, but just enough to remind me that I'm on a radio. Outstanding that worked out for you. WRXU861 1 Quote
WRXU861 Posted April 4 Author Report Posted April 4 6 hours ago, WRYZ926 said: A lot will depend on the gain of the antenna. According to the https://kv5r.com/ham-radio/coax-loss-calculator/; you will get an ERP of 1.9 watts when using a radio with 5 watts output, 100 ft of RG-213, and an antenna with 1 dBd of gain. As you can see the calculated ERP is 1.9 watts Now the ERP will go up as the antenna gain goes up. So if the antenna gain is 2 dBd then the ERP will be 2.4 watts. And if you jump up to a gain of 5 dBd then the ERP will be 4.7 watts One thing to keep in mind is that most antenna manufacturers list the gain in dBi while most loss calculators use dBd. Subtract 2.14 from the dBi value to get the dBd value. The kv5r coax loss calculator is not exact but it is close enough to see what the loss difference is between different types of coax and at different lengths. I'm using a 40 watt radio with 50 ft of RG 213. Moving my antenna high enough to get a clear line of sight made all the difference. Turns out, I was misreading the line of sight graph. Now, I can carry on clear conversations with all the repeaters within my local area. WRYZ926 and SteveShannon 2 Quote
WRYZ926 Posted April 4 Report Posted April 4 (edited) 59 minutes ago, WRXU861 said: I'm using a 40 watt radio with 50 ft of RG 213. Moving my antenna high enough to get a clear line of sight made all the difference. Turns out, I was misreading the line of sight graph. Now, I can carry on clear conversations with all the repeaters within my local area. Line of sight does make more of a difference when using VHF and UHF. I'm glad to hear that you are getting into all of the repeaters now. A j pole antenna has zero gain when measured in dBd, which is the same as a dipole antenna. Using the kv5r loss calculator and your specs, you will have an ERP of 21.8 watts. As you see that will still work even though you are losing about half your power output. Switching to 50 feet of LMR400 will only gain you 6.9 more watts on ERP. I would not bother switching out the RG-213 to LMR400 for that little power gain. What will make a difference is going with an antenna with higher gain. But no need to change anything if it is working well for your needs. Edited April 4 by WRYZ926 WRUU653, tcp2525, WRXU861 and 1 other 4 Quote
tcp2525 Posted April 5 Report Posted April 5 On 4/3/2025 at 1:14 AM, Hoppyjr said: - Accept the fact that you get what you get and be happy with that Never accept failure when the power of getting the ultimate base setup is in easy reach. If all the great innovators and inventors throughout history used this mentality they would have simply went to Radio Shack to buy blister pack crap and feel sorry for themselves. Short answer, you're on the right track by learning how to build antennas. Since you have the skills you will be able to perfect your station with a little more research and persistence. WRXU861 and GrouserPad 2 Quote
tcp2525 Posted April 5 Report Posted April 5 On 4/3/2025 at 3:41 PM, WRUE951 said: Copper J-Poles are pretty hard to build for UHF, you must get the precise measurements to a T for the frequencies and they extremely hard to tune SWR's. As others suggested the best way to tune them is via a NANO VNA. I came up with a sliding adjustment gimmick for tuning SWR that works well. Made with cooper compression splices you can get at home depot. Very nice construction and a good idea, and I'm glad you used an N connector instead of an SO-239 for prevent water from getting into your coax. One thing I can never figure out is why do so many people gravitate to copper for VHF/UHF antennas? I used copper to build a 6m 5/8 wave ground plane for my ham station at work 30 years ago. The only reason I used copper was because it was free and, of course, soldering is easy and makes a permanent weather seal. Many years ago, I made a 2m J-pole using 1/4" aluminum rod. Easily made and adjustable. Of course, 3/16th or 1/4" rod would be a better choice for UHF than 1/2" or 3/4" copper pipe, which is 5/8" and 7/8" OD respectively, as it wouldn't so broad-banded reducing what little gain you would have with a perfectly built J-pole. Quote
WRUE951 Posted April 5 Report Posted April 5 1 hour ago, tcp2525 said: Very nice construction and a good idea, and I'm glad you used an N connector instead of an SO-239 for prevent water from getting into your coax. One thing I can never figure out is why do so many people gravitate to copper for VHF/UHF antennas? I used copper to build a 6m 5/8 wave ground plane for my ham station at work 30 years ago. The only reason I used copper was because it was free and, of course, soldering is easy and makes a permanent weather seal. Many years ago, I made a 2m J-pole using 1/4" aluminum rod. Easily made and adjustable. Of course, 3/16th or 1/4" rod would be a better choice for UHF than 1/2" or 3/4" copper pipe, which is 5/8" and 7/8" OD respectively, as it wouldn't so broad-banded reducing what little gain you would have with a perfectly built J-pole. Well, i have built both the ladder lead version and the cooper version..The ladder lead actually cost me more money mostly because, like you say, i had a lot of the copper stuff laying around where i had to buy a mininum of 25' ladder lead to get going. (I actually bought 50') The Cooper was also easier to construct where the ladder version was a little more difficult due to razor cutting the dilelectric but was a lot easier to tune. Putting both versions to test under different scenarios convinced me that the copper versions performed better and not by much. I still use both and keep both with me in my RV for my portable repeater setup. I also experimented with dipoles and mobile antennas and found the J-Pole just worked better for my portable application. Yes, the dipole will out perform the J-pole but my cheap telescoping flag pole wouldn't handle the load in the slightest breeze. SteveShannon and tcp2525 2 Quote
WRXU861 Posted April 15 Author Report Posted April 15 A little update on my station: I switched back and forth between my 40 watt and my 20 watt (actually 15 watts) with nearly zero differences in capability. There's a huge difference between the 5w handheld and the 20w, but very little between the 20w and the 40w. gortex2 and SteveShannon 2 Quote
WRUE951 Posted April 15 Report Posted April 15 43 minutes ago, WRXU861 said: A little update on my station: I switched back and forth between my 40 watt and my 20 watt (actually 15 watts) with nearly zero differences in capability. There's a huge difference between the 5w handheld and the 20w, but very little between the 20w and the 40w. I know on a Maxon radio there is a huge difference between High Power and Lower Power 40/20 watts on a line of site contact roughly 90 miles apart. High Power a breeze, mid power - Gone Quote
