WRPL700 Posted April 7, 2025 Posted April 7, 2025 So this weekend was the first time I had really interacted with folks doing POTA. Generally speaking, they were coming in here to Delaware at 5-7 on the S-meter, with periods of QSB. Which is understandable as they were probably operating at around 10-20 watts, I would guess. I had about 20 QSOs with them. BTW, my rig is 20 watts. My question pertains to "Activating". What does that even mean? What are they "activating"? Thanks in advance. Jaay 1 Quote
SteveShannon Posted April 7, 2025 Posted April 7, 2025 19 minutes ago, WRPL700 said: So this weekend was the first time I had really interacted with folks doing POTA. Generally speaking, they were coming in here to Delaware at 5-7 on the S-meter, with periods of QSB. Which is understandable as they were probably operating at around 10-20 watts, I would guess. I had about 20 QSOs with them. BTW, my rig is 20 watts. My question pertains to "Activating". What does that even mean? What are they "activating"? Thanks in advance. They are activating a park. If they receive a certain number of contacts (10) while operating from that park they have activated it. It’s all spelled out on POTA.app. https://docs.pota.app A successful activation requires a minimum of 10 QSOs from a park in the designated list within a single UTC day (Zulu day). Courteous activators will still submit logs for unsuccessful activations to ensure their hunters get credit for the QSOs. Multiple activities at the same park in the same state/province/entity and the same UTC day count as a single activation, provided that the ten or more QSOs combined were made. WSEZ864, WRXB215, WRYZ926 and 1 other 3 1 Quote
WRYZ926 Posted April 7, 2025 Posted April 7, 2025 Here is the main website for Parks On The Air: https://parksontheair.com POTA can be fun and it's good practice for just in case situations where you might have to go mobile/portable in real life emergencies. Some guys will use 100 watt HF radios for POTA while others will use 20 watt radios and some will only use QRP radios (10 watts or less). I use a Xiegu G90 20 watt radio and do have the Xiegu 100 watt amp that I can use if I want or need to. My brother likes hauling his Icom IC-7300 with him. Other guys in our club use QRP radios only. And I have also seen guys use 400 + watt amps for POTA. But the bigger the amp the bigger the batteries you need to run everything. Portable quarter wave antennas with telescoping whips and wire end fed half wave antennas are probably the most popular antennas for POTA. You will see some use a telescoping mast for their EFHW antennas while others just throw one end up into a tree. Different parks have different rules on that. Then there is also SOTA - Summits On The Air and IOTA - Islands On The Air. The SOTA guys pretty much all use QRP radios. WRUU653 1 Quote
SteveShannon Posted April 7, 2025 Posted April 7, 2025 32 minutes ago, WRYZ926 said: Here is the main website for Parks On The Air: https://parksontheair.com POTA can be fun and it's good practice for just in case situations where you might have to go mobile/portable in real life emergencies. Some guys will use 100 watt HF radios for POTA while others will use 20 watt radios and some will only use QRP radios (10 watts or less). I use a Xiegu G90 20 watt radio and do have the Xiegu 100 watt amp that I can use if I want or need to. My brother likes hauling his Icom IC-7300 with him. Other guys in our club use QRP radios only. And I have also seen guys use 400 + watt amps for POTA. But the bigger the amp the bigger the batteries are that you need to run everything. Portable quart wave antennas with telescoping whips and wire end fed half wave antennas are probably the most popular antennas for POTA. You will see some use a telescoping mast for their EFHW antennas while others just throw one end up into a tree. Different parks have different rules on that. Then there is also SOTA - Summits On The Air and IOTA - Islands On The Air. The SOTA guys pretty much all use QRP radios. And Walmarts on the air! GrouserPad, WRYZ926 and TNFrank 3 Quote
WRYZ926 Posted April 7, 2025 Posted April 7, 2025 8 minutes ago, SteveShannon said: And Walmarts on the air! About the only time I use MURS is when I want to be ornery and mess with the Walmart workers by sending them on wild goose chases for spills in different isles. Northcutt114 1 Quote
amaff Posted April 7, 2025 Posted April 7, 2025 21 minutes ago, WRYZ926 said: About the only time I use MURS is when I want to be ornery and mess with the Walmart workers by sending them on wild goose chases for spills in different isles. I'm really hoping that's a joke. WSGL775 1 Quote
SteveShannon Posted April 7, 2025 Posted April 7, 2025 26 minutes ago, WRYZ926 said: About the only time I use MURS is when I want to be ornery and mess with the Walmart workers by sending them on wild goose chases for spills in different isles. No, there’s actually an event called “Walmart Parking Lots On The Air” where people operate from Walmart parking lots as a way of introducing people to ham radio. https://wmplota.org/ GrouserPad 1 Quote
WRYZ926 Posted April 7, 2025 Posted April 7, 2025 9 minutes ago, amaff said: I'm really hoping that's a joke. Yes is it only a joke, most of the time. I will mess with friends on occasion that work at Walmart. SteveShannon 1 Quote
WRYZ926 Posted April 7, 2025 Posted April 7, 2025 3 minutes ago, SteveShannon said: No, there’s actually an event called “Walmart Parking Lots On The Air” where people operate from Walmart parking lots as a way of introducing people to ham radio. https://wmplota.org/ Yes I am aware of that. I've seen clubs setup in Walmart parking lots during summer field day for the public exposure too. SteveShannon 1 Quote
Jaay Posted April 7, 2025 Posted April 7, 2025 2 hours ago, WRPL700 said: So this weekend was the first time I had really interacted with folks doing POTA. Generally speaking, they were coming in here to Delaware at 5-7 on the S-meter, with periods of QSB. Which is understandable as they were probably operating at around 10-20 watts, I would guess. I had about 20 QSOs with them. BTW, my rig is 20 watts. My question pertains to "Activating". What does that even mean? What are they "activating"? Thanks in advance. Activating a known state or Federal Park in the US, that's already recognized as a POTA site. SteveShannon 1 Quote
WRPL700 Posted April 8, 2025 Author Posted April 8, 2025 20 hours ago, WRYZ926 said: I use a Xiegu G90 20 watt radio and do have the Xiegu 100 watt amp that I can use if I want or need to. I have a Xiegu G90 as well. I have been totally surprised by the performance of this little radio, although my antenna may have something to do with it too (Two Shark 20M hamsticks in a Procomm DP4MFPL dipole mount at 30'). Quote
WRYZ926 Posted April 8, 2025 Posted April 8, 2025 1 hour ago, WRPL700 said: I have a Xiegu G90 as well. I have been totally surprised by the performance of this little radio, although my antenna may have something to do with it too (Two Shark 20M hamsticks in a Procomm DP4MFPL dipole mount at 30'). Resonant antennas are always going to be more efficient and work better. The G90 can easily tune all kinds of metal objects such as shopping carts, metal bleachers, chainlink fence, etc. But I would rather not have to even use the tuner if I don't have to. Using resonant and efficient antennas are more important when running QRP at 5 to 10 watts and is a big help even when running 20 watts. I have worked stations with my G90 and a resonant antenna where others using 100 watts and an external tuner could not. SteveShannon, WRUU653 and AdmiralCochrane 3 Quote
WRUU653 Posted April 9, 2025 Posted April 9, 2025 On 4/7/2025 at 8:43 AM, SteveShannon said: No, there’s actually an event called “Walmart Parking Lots On The Air” where people operate from Walmart parking lots as a way of introducing people to ham radio. https://wmplota.org/ What about Target? “Transmitting In Target Stores” FishinGary, GrouserPad, tweiss3 and 2 others 5 Quote
tweiss3 Posted April 9, 2025 Posted April 9, 2025 I'm a fan of distance contacts on 80m while doing 70 down the highway. I don't really ever have time to sit longer than 15 minutes. Quote
GrouserPad Posted April 10, 2025 Posted April 10, 2025 I prefer to activate car alarms with a 1000 watt transistorized spurious RF master blaster on 11 meters. I kid I kid it’s just a joke chill FishinGary, Jaay and WRYZ926 1 2 Quote
WRYZ926 Posted April 10, 2025 Posted April 10, 2025 3 hours ago, GrouserPad said: I prefer to activate car alarms with a 1000 watt transistorized spurious RF master blaster on 11 meters. I kid I kid it’s just a joke chill A friend would scramble everyone's TVs on the block when he would fire up his CB and amp in his truck when we were in high school. The neighbors loved him for that I live in a small rural town of 1100 people ( I think they counted chickens and cows to get to 1100) with several of us having our amateur licenses. We try not to use any amps when working HF so we don't overload everyone else's radios. One is 500 yards away from me and two are 300 yards away. I had to get on one of them when he decided to run a 165 watt VHF amp during a net. He was overloading my Icom dual band radio all across the 2m band. WRPL700, GrouserPad and SteveShannon 3 Quote
TNFrank Posted August 10, 2025 Posted August 10, 2025 This sounds like fun. I wonder how a 2M 1/2 wave antenna (39"?)on a tripod hooked into one of my 11W HTs would work? Quote
BoxCar Posted August 10, 2025 Posted August 10, 2025 Tie a string to the tip and hoist it into a tree. You'll be surprised. You'll need to look at the POTA website and tell people what frequency you'll be on and when so hunters can find you. { Quote
WRYS709 Posted August 10, 2025 Posted August 10, 2025 30 minutes ago, TNFrank said: This sounds like fun. I wonder how a 2M 1/2 wave antenna (39"?)on a tripod hooked into one of my 11W HTs would work? Although they are hard to find today and require a bit more strength to hold steady, the 2 meter 5/8ths telescoping antennas offer me quite a bit of “more fars” when I operate HT portable. Quote
TNFrank Posted August 10, 2025 Posted August 10, 2025 I'm thinking of something like this: https://www.amazon.com/Dual-Band-Antenna-2m-70cm/dp/B08YWHTHC3 Hooked up with 20-25' of this: https://www.amazon.com/XRDS-RF-Coax-Cable-Coaxial/dp/B0DMNZ9FPJ And this: https://www.amazon.com/Antenna-Adapter-Coaxial-Handheld-Kenwood/dp/B08BCSYDN3 On a tripod I have. Quote
SteveShannon Posted August 10, 2025 Posted August 10, 2025 39 minutes ago, TNFrank said: Hooked up with 20-25' of this: https://www.amazon.com/XRDS-RF-Coax-Cable-Coaxial/dp/B0DMNZ9FPJ Be sure you do the math to figure out the losses in 25 feet of RG8x for the highest frequencies you intend to use. It could be substantial. RG8x is fine for HF, but lossy for 70 cm. WRXB215 1 Quote
TNFrank Posted August 10, 2025 Posted August 10, 2025 46 minutes ago, SteveShannon said: Be sure you do the math to figure out the losses in 25 feet of RG8x for the highest frequencies you intend to use. It could be substantial. RG8x is fine for HF, but lossy for 70 cm. What about 2M? I was under the impression that RG8x gave less signal loss across all frequencies. I'm still learning this stuff though. What would be better then, RG58? Also, I know shorter is better but I wanted enough length to get the antenna out and away from any tables I'd be sitting at. Quote
BoxCar Posted August 10, 2025 Posted August 10, 2025 I use this antenna when out and about with my tripod. Diamond Antenna X30A Dual-Band Base/Repeater Antenna and the radials provide the ground plane. https://www.amazon.com/Diamond-X30A-Dualband-Repeater-Connector/dp/B07MHRQLPZ/ref=sr_1_5?content-id=amzn1.sym.2e97d935-d5f5-4935-88bd-cb6d2a136d95%3Aamzn1.sym.2e97d935-d5f5-4935-88bd-cb6d2a136d95&dib=eyJ2IjoiMSJ9.9gr60MfiQ3rLkc-wuJNMNsh33FjzOsgb6_kDN23UovpO84RiADkVij7Md6Fv47tNcLcJNjp-c4i5G-4uo1hEL2b-bhsv6nco4SXPn2xhepbzgHC6VBbzgKt_ZYcFjVUZjo8tG_NymETIRSjyYYSjTFj6AIRvzv8ZPAjfLkMrF9KB-xE8FVHry9zLDv2J-uj3csGAdtdO7i1kL0mnVSxNI3d31Vzoj4ArC2kUyvEK200.daQJzEPpZIEL2NL220nwEeuxkzht5SriXV6_v_o6Z_I&dib_tag=se&keywords=diamond+antenna&pd_rd_r=3a490f52-44c2-4485-b72b-f7ce79001c9f&pd_rd_w=QoDRC&pd_rd_wg=tnwf7&qid=1754868332&sr=8-5 Quote
BoxCar Posted August 10, 2025 Posted August 10, 2025 You probably should use this coax from Gigaparts: ABR400-Ultra Flex 18ft RG8 Coax Jumper w/ PL259 Ends 25400F-PL-18 $72.95 Quote
hxpx Posted August 10, 2025 Posted August 10, 2025 37 minutes ago, TNFrank said: What about 2M? I was under the impression that RG8x gave less signal loss across all frequencies. I'm still learning this stuff though. What would be better then, RG58? Also, I know shorter is better but I wanted enough length to get the antenna out and away from any tables I'd be sitting at. This is what I've been using trying to figure out how much loss I'm going to deal with running a line out to my backyard: KV5R Coax Loss Calculator 144mhz with 25' of RG8X is probably going to be about a ~21% loss. 450mhz drops down to 38% loss. I actually don't know of anything short of like LMR-400 that doesn't have high loss with VHF/UHF, but now you're getting into stuff that's almost three bucks a foot. Edit: I have no idea where my mag mount base went, but I'm pretty sure it uses a 16' RG8X line and even with the loss, like 4W at 450mhz out on my porch is WAY better than 5W in this RF dead spot I've created in my office with all the monitors, computers, and metal peg boards. You may not notice the loss with a short run. TNFrank 1 Quote
