WSGN548 joined the community
I realize this is an eight month old post, but there’s actually a thread just for this question:
Using The Correct Tools For The Job Are Always Essential!!
WSHH887 replied to tcp2525's topic in General Discussion
Even the best professionals can make mistakes. One that comes to mind was a journeyman electrician who was installing a back of batteries as part of a large UPS system. He somehow became part of the circuit. Lived but never worked again. Sad part about this was though it was through his own failure he sued and won. Bleeding hearts will side with the electrician. But it ended up making the company owner decided to retire. It ended up costing about 30 people their jobs. And destroyed a great company that was pretty well respected. - Today
What is going on with the FCC ULS and CORES?
SteveShannon replied to 73blazer's topic in General Discussion
Did you get to the page where it sends you a six digit number or did you not even get that far? -
Sorry, I have no idea and I don’t know if any mygmrs members are near there.
So you are admitting to being an old curmudgeon? Just kidding with you.
RIPPER238 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
WRQH555 joined the community
WRUE951 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
WRUE951 reacted to a post in a topic: OK, I have this problem...
WRDF473 joined the community
SteveShannon reacted to a post in a topic: OK, I have this problem...
That is extremely possible for me at my age.
Here is an excerpt from the Missouri law. While they do not specifically mention GMRS, they do state that amateur radio and CB is exempt. One could argue that if CB and amateur radios are exempt then so is GMRS. Now I sure would not trie to program a radio while driving. Here is the link for the actual state statute: https://revisor.mo.gov/main/OneSection.aspx?section=304.822
WRUU653 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
cecarnicom joined the community
Looks like an alternative to the Midland MXT575 but the same limitations with a better screen.
Pennsylvania also has an exception, unfortunately the way it is written, it applies to licensed Amateur Radio operators, which is by definition, according to the FCC, not GMRS, but HAM. People tried to get them to correct this, but they didn't.
Missouri just enacted a hands free law at the beginning of the year. And they specifically state that amateur radio operators are exempt from the new law. Though no one should be driving distracted. Radios with everything built into the hand mic do have their place and use. A lot of newer vehicles just don't have the room to mount a complete radio or even a good spot for a remote head unit. And there is the factor of wanting to stay discrete with one's radios. These types of radios are not for everyone, but that is okay, variety is the spice of life.
PRadio reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
I use a Tera GMRS/MURS radio to monitor the local police radio, so some will appreciate the ability. The main benefit I see is the ability to remote mount the unit in small vehicles like mine. The other is the bluetooth ability since in some states, mone included, the hands free laws apply to GMRS. The way my state wrote the newest regulations exempts licensed amateur radio users, but that related to HAM and not GMRS. It was badly written unfortunately, so GMRS requires hands free.
WRYZ926 replied to tcp2525's topic in General Discussion
The same goes for capacitors too. Some of the machines I use to work on had banks of 24 to 36 capacitors that were bigger than a soda can. I forgot the actual farad rating for those but it was in the KF range. -
You aren't everyone. In some states you can no longer use a radio without a hands free setup, so this radio addresses that issue. The ability to use a phone app to program the radio via bluetooth is also a nice feature. You no longer have to hook the radio up to a computer to program advanced features. Not a bad thing. I have numerous computers, but hate Windows, so I generally run Linux, one programming application I need doesn't run under Linux...yet, I am still trying. As a result, I run Windows on a Mac under a virtual machine for that application. This radio will fill the need for many people, probably not you, but once again, contrary to unpopular belief, you aren't the only one buying radios.
Hchavez joined the community
We are using air dielectric hardline.
Nitrogen Is Used On An Air Dielectric Coaxial Cable To Keep The Cable Slightly Pressurized & Reduce The Chance Of Moisture Infiltration. It Is Never Required For Any Purpose Or Use On Foam Type Dielectric Hardline.
I was just going to mention finding out that just because an old B&W TV was unplugged doesn't mean it can't bite. There are just places you shouldn't put a screwdriver. -
The guys that installed our 7/8" and 1 1/4" Heliax purged and filled the coax with nitrogen. That has been years ago so no idea if the nitrogen is still in the coax or not.
You mean pull a vacuum....
Same here. I find I grab my RigExpert Stick Pro most of the time. A good antenna analyzer is definitely more expensive. I do find that the Stick Pro does most of what I need and I hardly use my NanoVNA anymore. There is a bit of learning curve with the NanVNA's but there are plenty of YouTube videos about how to use them.
vzqhsg started following Repeater Near Eureka WQZH452
I was looking on the map today and don't see the above repeater. If I remember correctly it was just south of Eureka. I also had a second repeater listed that had the same name, but a freq. of 462.725. Did this get taken down, storm damage? I showed on listed on Pinkham Mt., the other on Black Butte. Thanks, Dave
Make sure you pressurize and ground it
I picked up one of those mini Spectrum Analyzers. Interesting device, seems to work o.k.
I actually asked that about the Heliax cables because the center conductor was hollow. Turns out it's a weight and flexibility thing.
I had the coax assemble made by buytwowayradio and they looked like quality connectors. I got my Heliax coax assemble from theantennafarm. The only difference in the installation is I asked for shrinkwrap on the Heliax. Not sure if it was an option on the 239. Much better of a quality connector than in my younger CB days.
I have not used any radio tube amp but have used and repaired a few guitar/bass tube amps. The one machine shop was still using a larger surface grinder that was used tubes. So I have some experience working with them. Our club's VEC has an old 2000 watt tube amp that came out of the local AM radio station decades ago. We keep teasing him by asking when he is going to install that in his pickup truck. The amp is out the same size as a small 18 cubic inch refrigerator I remember working on the old TVs as a kid. one of my uncles owned a TV repair shop.
