I don't care for any repeater doing that. We are going to use an Arcom RC-210 controller for our GMRS and 70cm repeaters. We are going to set the controller to ID every 15 minutes but ONLY when there is actually people using the repeater. I just finished assembling the RC-210 board and am waiting on the case and real time clock. Then it will be time to program it. And we will definitely have the repeater ID since it is open to the public.
We used them recently with three RVs on a road trip. Sure beats trying to set up a conference call or a group text.
Hey, how'd you know I'm in my underwear?
WRYZ926 reacted to an answer to a question: Re: Newly Purchased ICOM FR4000
WRYZ926 reacted to a post in a topic: Deregulation; here’s your opportunity to make a difference!
WRTM417 joined the community
Radioguy7268 reacted to an answer to a question: Two Repeaters, 10 miles apart, will this work?
WRTC928 reacted to a post in a topic: Could FM CB supplant FRS?
WRTC928 reacted to a post in a topic: Moving experience
WRTC928 reacted to a post in a topic: Comet 712EFC -- no ground plane radials
Personally, i think the guy's id'ing every 15 mins on the hour is no different than a dog pissing on tires.
You mean "radio dorks in thier underwear in thier parents basement"
Jaay reacted to a post in a topic: Moving experience
A.K.A. "Anonymous People"
SteveShannon reacted to an answer to a question: Re: Newly Purchased ICOM FR4000
SteveShannon reacted to a post in a topic: Moving experience
I highly suggest a quick phone call to Comet, they are very friendly and will answer your question. My guess is use it if it makes you sleep better at night.
Part 95.1751 (c) Any GMRS repeater station is not required to transmit station identification IF: (1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section.
Jaay replied to SteveShannon's topic in FCC Rules Discussion
They do that at the local nursing home close to me. I thought about noting the names used, and Calling their Admin and reminding them of the Hippa Rules. Maybe their use on Gmrs would go away. -
Nothing wrong with talking to Other operators either ... Your so-called "Strangers"!
Yes. For sure. Skiing, biking, camping, and moving. We get a lot of good use out of them.
WSIG348 joined the community
Great to hear. That’s what it’s for. I would not have figured you would have needed or wanted to use repeaters since it wasn’t a place you lived, worked or played. Gmrs is a tool. Gmrs is Not a way to meet strangers.
WSIA224 joined the community
My wife and I are making an interstate move and it was great to have a radio in a Penske truck and one of our cars. In addition, we have two handheld radios. That made backing up the truck with a car carrier so much easier! She could direct me when I backed out of our original home. Along the way, she could pull behind me and let me know if there were any trailer stability issues at higher speeds. After a few hours, I had my wife drive the speed limit while I drove at a slower rate (trailer limit). We had some awesome range in Eastern Oregon. We had great range as she pulled away. Our radios have repeater capabilities but we kept them on a simplex channel. We said our goodbyes as she pulled away from the line of site. A few hours later, I caught up at the hotel. We have been long users of GMRS, and the service was awesome for the move. we hope that others get great use out of GMRS.
WRKC935 replied to SteveShannon's topic in FCC Rules Discussion
Folks need to get past this idea of 'more channels / frequencies' on GMRS. Out of everything that someone might want to change about GMRS, that's the one that's least likely to happen. The biggest issue is GMRS in is the LMR allocation for frequencies. We have commercial two-way above and below us. There are no more frequencies to be allocated to the service. And adding repeater pairs from the FRS frequencies really ain't gonna fly either because the interference issues that will be created by the bubble pack radios on those frequencies. Not to mention it would make all the current part 95 radios that aren't able to be flashed to add those repeater channels and make them obsolete. Which is what happened when CB was modified to have 40 channels from the original 23. While I don't like the idea of DMR or other digital modulation schemes being used on GMRS due to the issues that will create, it's a better and more reasonable option than getting more frequency allocation. They are NOT going to kick commercial users off their frequencies to give us more channels. -
i might be wrong. check this threat on another site: https://forums.radioreference.com/threads/icom-ic-fr4000-cw-id-help.443905/
I don't think you can set it on a interval timer. Kenwood's can be set that way.. Its probly better to set it for traffic only anyway
If they do, there's nothing about it in the instructions that came with the antenna. It seems like a good idea, though.
Have you tried contacting ICOM? Their phone support is very good.
Why do you need it to I’d. FCC doesn’t require it. None of the 20 local repeaters I have around me ID
I also have this repeater and by timer, i can not get it to ID to save my life. I've followed all instructions to the T and it will still only ID on TOT but not on timer. RepeaterID makes a general purpose CWID transmitter that simply hooks to the Kenwood port of an HT and the other into the ID device. from there it xmits the CWID from the HT that is progg'd to the repeater. it works 100% and i dont worry about this repeater ID'ing. I dont work for, or are affiliated with RepeaterID, just wanna help, i know the frustration.
An elementary school less than a mile from me uses FRS or GMRS (probaby only FRS but can't tell) for the teachers and administrative staff to communicate. I have heard some students names used and teachers names, but thy don't seem to share any real private info other than that. I have considered contacting the school and just making sue they are aware that they can be heard by others within a few miles of the school. No idea if they realize that they are not "Private" ... but have not contacted them yet because I wonder if they would think I am someone to worry about since I "have been listenting" to them. But yeah I wonder if they even have a clue that their radios can be heard by anyone with a cheap radio in the area.
AdmiralCochrane replied to WRTC928's topic in Equipment Reviews
I carried Noalox on my HVAC service van for decades. - Yesterday
WRTC928 replied to WRPL657's question in Technical Discussion
How the heck did I read right past that? Of course, if I read it a couple of days ago, it's entirely possible I forgot it. I'm old. That happens. -
WRYZ926 replied to SteveShannon's topic in FCC Rules Discussion
At least the nursing home staff has not used any patients names that I have heard.
