SteveShannon reacted to a post in a topic: Baofeng gm15pro shows long antenna included, but not shipped?
OffRoaderX replied to a topic in Guest Forum
More lies and misinformation Tammy! People stand up and call BS to my face every day. -
TerriKennedy replied to a topic in Guest Forum
I was going to let this slide. But hey, it's Tuesday and I'm under my quota of arguments for the week so far... 1) It's Terri with an "i", short for Teresa. Which you'd know if you'd ever used any of my CPS programs. 2) Standard box size. Let's see. Here's a picture of 16 different Baofeng models in their boxes. I'm sorry I could only stack 4 high by 4 wide before I ran out of space. Front and top views. These are all single radios (which is what started this post). Obviously a box for a pair of radios, or more, would be larger. 3) "Nearly every radio manufactured by Baofeng (dozens)" Yup. Riggghhhhttttt. I have 34 different models, all unboxed, right now in my line of sight, not to mention the ones in the boxes in the pictures. Nor all of the ones I've given away. Here's a screen capture from a Baofeng factory promotional video where it shows just a small part of their showroom before the image pans around and looks down rows and rows of different models on display. 4) I could probably stuff a small rattlesnake into a standard size Baofeng box. Neither it, a 15" antenna, or the customer would be happy when the box was opened. You come along, all high and mighty with your proclamations here because you're a Youtube superstar with (as of just now) 266K subscribers and almost nobody is willing to stand up and call "BS" to your face. Well, surprise! Note that I only wrote this reply because you tried just about everything you could to provoke a response from me. Normally I'm easygoing and try to be helpful when answering questions here, without sarcasm or denigrating the other person. Now, let's all return to our respective corners and try to behave civilly, OK? -
WSIT843 joined the community
At least with BTECH, you know you're dealing with a real human in South Dakota.
WSBY935 joined the community
SteveShannon reacted to an answer to a question: UV-5R and UV-18 Pro Max Dual Receive?
WSEE962 joined the community
Need Antenna Recommendation For Amphibious GMRS Station
WSEC330 replied to tcp2525's question in Technical Discussion
UncleYoda replied to WSIC904's question in Technical Discussion
Calm down Queenie. I was trying to get him to understand it's not "dual on both". Sounded like by both bands he may also be thinking of bands A and B as the two frequency bands in VFO mode, rather than Line A and B. -
OffRoaderX replied to WSIC904's question in Technical Discussion
Which to a normal person, using normal ears, appears to be "listening to two channels at the same time"... Next you going to explain to us how "movies don't really move"? Geezusphuckingkrist "some people" are insufferable.. -
Sounds like you're misunderstanding. There is no "dual monitoring on both bands". It alternates automatically between checking Display A and Display B. It only receives on one or the other at one time. And the dual watch setting is called TDR on the UV5R function menu. -
How many fars on the Maljamar, NM repeater?
WSEC330 replied to WSFE293's question in Technical Discussion
No wait! the earth is flat...google that S@#t -
WRTT834 joined the community
Seriously? Radio jail? How would you be 'punked' in there? People walk away so you cant hear them? Do they just now respond to conversation? Step behind an object to not engage? Would your prison number be your callsign you didn't use? Would you have to make up a crazy story to be accepted, like a renegade repeater of something...LOL
He's the only one in most of the videos.
AdmiralCochrane replied to WRPL700's topic in Amateur Radio (Ham)
Music is math is music. At some colleges, some music classes are accepted as required math credits. My wife's best friend got out of several math classes via that route. -
He's the star of the video!
Lucky Sears is everywhere. Seems like it is always hard to find Homer Atkins. I have a friend who is half Chinese and half Hungarian/American. Her parents were very clever, her Chinese names are her middle names and are the same as her English language name framed around the Chinese.
GreggInFL replied to WRPL700's topic in Amateur Radio (Ham)
A friend with a doctorate in industrial psychology once told me that aptitudes for math correspond with aptitudes for music. -
Thank you!
Yes, dual monitoring on both bands, A and B.
Thank @OffRoaderX, he made the video.
Thanks for the you tube that helps a bunch!! WSEU 498 Fatrat56
YouTube, look for videos from the Notarubicon channel. One specifically describes configuring a radio for a repeater.
My radio is unlocked so it will work on a repeater? Where can I find how?
IF it is not "locked", then, YES. IF it is 'locked', then, NO. So the actual answer is: It Depends TL;dr: Maybe
Mine can, but it’s an older model.
can a baofang uv 5 r be programmed to talk on a gmsr repeaters?
Fatrat56 joined the community
WRON274 joined the community
That's true, the FCC just kind of let it slide into history with zero notice... which kinda stinks for people who knew it as the de-facto operation since the `60s.
Do repeaters have to be part 95 accepted
OffRoaderX replied to Elkhunter521's question in Technical Discussion
The point is, "some people" are out there, right now, spreading lies and misinformation on the online forums, videos, etc, claiming that the FCC will actively go after you, track your location, fine, you, or even jail you for using a radio/repeater on GMRS that is not Part 95E approved. We must stop the lies.
