WSDI414 joined the community
LeoG started following Duplexer insert keeps burning out.
When you changed out the tuning rods and made them thinner by removing the threads instead of leaving a space in there maybe you could make the teflon (or plaster) insulator thicker so it is more snug on the smoothed out threaded screw. A thicker insulation would give you better protection. Good idea taking the receive insulators and use them on the transmit side. I think the 1st one burns out because it's 1st in line of the three, taking the brunt of the power.
WSIU894 joined the community
mperciful joined the community
Lscott replied to marcspaz's topic in General Discussion
Been there about 12 to 15 years back. Had a minor rotor cuff tear in the tendon. Got surgery to stitch up the tear, doc put in an anchor to reattach the torn section to the bone and clean off some bone spurs. I wrecked the shoulder at the gym while using the upright seated bench press machine. Yeah, it hurt like an SOB when it happened too. Then the shoulder “popped” just a fraction of a second after I felt the stretching sensation. When home offer that. Basically couldn’t lift my right arm. It took about 6 months of PT just to get back normal range of motion. Then another 6 months to a year building the strength back up. -
Lscott reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
SteveShannon reacted to a post in a topic: Repeater Off-Sets are different with HAM.
WSDY936 joined the community
Kudos to @dosw and @tweiss3 for understanding the question and providing good answers.
WRXB215 reacted to a post in a topic: Repeater Off-Sets are different with HAM.
WRUU653 reacted to a post in a topic: Repeater Off-Sets are different with HAM.
Actually, your local repeater coordination body (typically won't answer anything and are useless), have recommended tones (2-5 of them) for each region of the area which they coordinate. These are Ohio's recommendations, not requirements, but it keeps adjacent pairs from using the same tones.
WSFA263 joined the community
WSGV743 joined the community
AdmiralCochrane reacted to a post in a topic: Interesting comments being filed with the fcc on unused 46Mhz/49Mhz pairs
While the choice of CTCSS tones is not entirely random, it may as well be. There are common conventions, like avoiding adjacent tones in a given overlapping area, avoiding tones that are harmonics of power lines, that sort of thing. I think in some cases it's more about "legacy conventional wisdom" than about "real world issues in 2025." But as far as repeaters following a pattern, what you might be seeing is either a freak coincidence, or regional conventions that may have some historical rationale. Not any broadly adopted pattern.
Your title says "offsets" but then, in the body of your message, you talk about CTCSS. Which one is it and what pattern do you think you are seeing?
WRZG610 joined the community
Jbfaust joined the community
SteveShannon replied to TNFrank's topic in Amateur Radio (Ham)
No, I haven’t noticed. -
I've also noticed kind of a pattern for CTCSS tones for each band. Not every repeater follows the pattern but I'd say a good 80-90% of them do. Has anyone else noticed this?
WSJM822 joined the community
RoadApple reacted to a post in a topic: Roger Beep
WSJS901 joined the community
The mystery of the MXT-400 that can ....Talk Around Feature
tweiss3 replied to H8SPVMT's question in Technical Discussion
Talk around is a great function commonly used in commercial radios. It switches your TX frequency to the output of the repeater to operate in simplex. I personally think it should be used more, but it's only as good as those trained how/when to use it. -
two different MDC acronyms. I'm referring to Motorola Digital Communicator.. So yes i 'get it' Motorola Data Communications is acceptable. I'll still stick with MAGA though
H8SPVMT replied to H8SPVMT's question in Technical Discussion
YEP, that did the trick! Don't know, "why it worked," but can guess there was something in the internals that prevented the access either to the channel selection of the Tone selection. After recording all my setting in the MXT-400, I did a RESTORE function. The RESTORE function reset the internal components back to factory setting. I input all my previous setup options and it works like a charm! -
A Better Term Would Be That Repeater Access Would Not Be Allowed. So In Short - Yes. It Could Disallow Someones Use Of A Repeater.
MDC Is Legal For Use On GMRS. MDC Is A Motorola Brand Name For AFSK - Auto Frequency Shift Keying. See Definition Below: AFSK Encodes Digital Bits Into Two Audio Tones To Be Transmitted On Analog radios. § 95.1777 GMRS tone transmissions. In addition to audible and subaudible tones used for receiver squelch activation and selective calling, to establish or maintain communications with specific stations or to access repeater stations (see § 95.377), GMRS transmitters may also transmit audio tones for station identification (see § 95.1751). § 95.377 Tones and signals. Personal Radio Service stations that transmit voice emissions may also transmit audible or subaudible tones or other signals for the purpose of selective calling and/or receiver squelch activation. These tones and signals are ancillary to voice communications and are considered to be included within the voice emission types, e.g., A3E, F3E, and G3E. (a) Tones that are audible (having a frequency higher than 300 Hertz), must last no longer than 15 seconds at one time. (b) Tones that are subaudible (having a frequency of 300 Hertz or less), may be transmitted continuously during a communication session.
gortex2 replied to NWHov's topic in FCC Rules Discussion
Line A is still a thing. What has changed is GMRS frequencies are no longer part of the restrictions. I still have multiple FCC frequencies for public safety being held up in Canda. -
bihlein started following Ailunce HA1G PTT ID not working?
Hello all, I recently got a Ailunce HA1G radio and have been trying to get it working with a PTT ID required repeater in my area. Everything I have tried so far has not been working. I sent up the repeater channel, added my assigned ID to own ID under signal settings (or call ID if your programming via CPS), set to BOT at 300ms and set the channels signaling setting to one of the dtmf signaling lists I have. Anything I maybe missing? Any help on things I may be missing or tests I can do is much appreciated.
My At-779UV does the red blinking light thing too. I just jiggle the mic cord and it resolves. Haven't had the audio issue described.
Might be a dodgy connection from the mic cable? those RJ-45 connectors aren't the strongest things in the world. If you jiggle the connector at the radio does it happen? I've noticed it do weird things if I disconnect or connect the mic or programming cable while the radio's on.
I'll have to let the repeater owners explain how it works on repeaters. My ham mobile can block incoming signals based on the tone, but that's different from an ID code. I don't think any radio I have can decode IDs even though they can transmit them. [A newer radio I have has an encryption function but it isn't legal to use so I can't even test that.] All my radios are analog.
[The cutesy title is a play on the brand name.] Just had an unnerving occurrence where no sound was coming out of either earphones or the radio speaker (receive LED and signal meter did indicate it was receiving). I tried all the relevant settings I could think of to no avail. After giving it up for broken, I tried turning SUB back on and switched to B -- boom!, sound blaring out. Switched back to A and sound there too. And it worked with earphones too. Doesn't make sense but I'm glad it started working again (no signals to test with right now). The other odd thing I've noticed is the red TX LEDs will come on briefly at random times when I'm not touching the radio. No pattern to it that I can discern so far. And the mic is hanging up where the PTT button is not touching anything.
WRQC299 started following Can the Anytone AT-878-UVii still be unlocked for GMRS?
I mean, "obvious" is a strong word, but yeah, it's certainly logical. I was just making sure. I assume that's not something that analog radios are able to do? You'd need a digital radio, yeah?
While you're waiting for 702's reply, I'll say that if specific IDs are required, then would it not be obvious that revoked IDs would be blocked? But for the official procedure to ban someone, the owner is supposed to send a letter to them (probably after telling them).
WSGE773 changed their profile photo
So let me ask a follow up question to this. If a radio can identify itself to a repeater and then the repeater can allow it access, can the opposite be true, as well? Can a radio be "banned" from a repeater by not allowing it's ID?
- Last week
WSJL659 replied to WSJL659's question in Technical Discussion
Update: It worked. I entered test mode and changed the unit to Mode 2. It now has the same range as the older units. Thanks for the speedy answers. I just didn't want to open the box and power the unit up if someone had already tried and did not have success. The new frequency range must just be listed that way for US sales... -Adam
