WRHS218 reacted to an answer to a question: The mystery of the MXT-400 that can ....Talk Around Feature
marcspaz reacted to an answer to a question: Can I use an RJ45 splitter to run dual Hand Mics?
marcspaz reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
SteveShannon reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
SteveShannon reacted to a post in a topic: Mr
WRUU653 replied to WSJL659's question in Technical Discussion
I honestly haven’t looked at the schematic for any of my mics and none have a speaker but they do have a keypad and led lights so I wonder if this might be an issue. I like @marcspaz’s idea for a Bluetooth mic but if it were me I would constantly forget where I put it . -
SteveShannon replied to WSJL659's question in Technical Discussion
No, not based on the schematics I’ve seen. The PTT does not connect the microphone to the radio. It’s a separate circuit. It has to be for VOX to work if enabled. - Today
LeoG replied to WSJL659's question in Technical Discussion
So on the impedance front... Isn't the microphone only connected when the PTT button is pressed? So unless both are pressed at the same time they never interfere with each others electrical properties. I can't say the same if you have speaker microphones because both speakers will be connected and in parallel and therefore cut the resistance load in half (if they are the same resistance) -
simplest solution for removable antenna is nmo or even bnc bulkhead on an inspection plate. easy to replace the inspection plate when gmrs/ham/part 90 radio not in use...
amaff replied to marcspaz's topic in General Discussion
This is the most ham radio this GMRS forum has ever looked -
WSJP854 started following Club Forum Page
WRUU653 replied to H8SPVMT's question in Technical Discussion
@nokones has this correct, talk around only changes your TX while of course using the tones of the repeater, the RX remains the same. Reverse on the other hand does just that, it reverses TX and RX frequencies. Which sounds like what @H8SPVMT is describing rather than talk around. -
WRFX223 joined the community
nokones replied to H8SPVMT's question in Technical Discussion
No, it doesn't reverse anything. The receive freq and tone stays as programmed and the transmit freqs changes to the same freq and tone as the receive freq and tone is programmed for simplex operation. -
BoxCar replied to marcspaz's topic in General Discussion
Or bunions -
BoxCar replied to H8SPVMT's question in Technical Discussion
Perhaps I could have stated that better. It reverses the transmit and receive repeater channels in the radio it is being used on. -
Lscott replied to marcspaz's topic in General Discussion
Maybe we should start a thread about Hemorrhoids. -
UncleYoda replied to WSJL659's question in Technical Discussion
I wonder if that would work with the mic and the programming cable. - Yesterday
UncleYoda replied to H8SPVMT's question in Technical Discussion
Nope, reverse is different. Talkaround uses the same frequency (e.g, repeater output) for RX and TX. -
LeoG started following Can I use an RJ45 splitter to run dual Hand Mics?
I use an RJ45 splitter to connect my KG1000G mic and my bluetooth mic at the same time. Works just fine and everyone says I sound fine. This is what I use -
Also known as Reverse as it reverses the transmit and receive frequencies on a repeater channel. -
It’s a tad bit more in that it will do this with the tones set for the repeater output automatically without you having to put them in separately for simplex. This makes it useful in my opinion to see if you are within simplex range with the touch of a button. it’s all magic This is my understanding as well. -
There's no way to know for sure without more information, but some repeaters do use Morse code to identify.
WRXL702 replied to H8SPVMT's question in Technical Discussion
Talk Around Is Nothing More Than A Created Motorola Term For Simplex Communications. Nothing More - Nothing Less. No Magic Here...... -
WSAR627 joined the community
Sometimes I hear Morse code from repeater that I have tuned to. Is this an identifier for the repeater or does it signify something else. Thanks in advance!
Also, it is a great feature so that you do not have to use another channel position in the radio for a simplex or mobile-to-mobile with the same freq and tone settings. -
Utah VHF Society (band plan manager for Utah; utvhfs.org) lists 429 repeaters. Of those, 292 use tones, and 137 do not. There are, from what I can tell, 29 tones used by those 292 repeaters, with the most common being a simple 100.0. There doesn't seem to be any specific rhyme or reason other than obvious things like most (but not all) of the Intermountain Intertie linked repeaters using the same tone. There's no pattern other than the sometimes-used concept of "similar things should be [conveniently] similar", as in the example of the Intertie network. There's a pretty good explanation for why you might see a pattern. Humans seek patterns in random events due to apophenia, a common cognitive tendency to find meaning and order in randomness, which is rooted in an evolutionary advantage for survival. For our ancestors, a false positive in pattern recognition (seeing a predator in random leaves) was safer than a false negative (failing to see a real predator). This brain mechanism makes it easier to process information and make quick inferences, though it can lead to errors like misinterpreting data or believing in conspiracy theories. (Explanation came from AI, which is probably ironic)
WSIZ582 joined the community
AdmiralCochrane replied to H8SPVMT's question in Technical Discussion
I believe the main function of talk around is to determine if repeater users you hear are close enough for you to establish simplex comms instead of using the repeater. -
marcspaz replied to marcspaz's topic in General Discussion
We should schedule a 0700 breakfast meet up at the County Hospital cafeteria! We need to wear hats with our call signs and or favorite PT t-shirt. LoL -
Repeater Off-Sets are different with HAM.
Davichko5650 replied to TNFrank's topic in Amateur Radio (Ham)
Might be a regional thing, like around here> A common one for many of the local 2m repeaters in the TC area of MN is 114.8. a couple exceptions but I'd say about 85-90% or more here are using 114.8.
