  2. You're not a scammer. So good for you!
  3. It's on the Zello website https://support.zello.com/hc/en-us/articles/36830119152397-2025-Service-Changes Depending on what they charge I think I would pay for it. It's an outstanding service for our Community
  4. Where did you find this information? Only asking because I didn't see anything on their blog mentioning it. Thanks.
  5. Went and poked around on their website and found this. Is that just a rebadged $30 UV88 (also the basis for the Radioddity GM-30)? I'm in the wrong line of business.
  6. https://zello.com/downloads/desktop/ I can't download it right now on the work PC but I don't know if that download is for the free version or a paid version.
  7. Oh yeah, super easy. All you need is a DM-5R and then build yourself a Pi Star hotspot and connect over the internet to a DMR node across the country and - wait what do you mean that's cheating?
  8. Guess we gotta up our game on our boofwang handhelds.....just saw this on facebook today....
  9. I wouldn't be too afraid of that. Pretty sure you would have to read and understand the manual or find the right YouTube video. Probably as likely as randomly hitting the tone by guessing.
  10. Today
  11. i haven't got one of thse yet. i do have a few radios where you have to initiate a process to discover tones...
  12. We have a channel 1 gmrs CW identifier that seems to be super common. I think it’s bleed over from another channel or band but I’m not certain, it is very loud and clear. Sounds like a repeater on ID every so often. You could be close to someone who is using CW id that is on a different frequency (dunno) using a radio that transmits “unclean” power
  13. Sounds like that may just bring the unlicensed, non-radio folk, one step closer to getting onto local repeaters... welcome or not. Modern GMRS radios in the hands of "FRS type" users will no doubt continue to blur the lines between the two services.
  14. Make an audio recording of the CW and upload here to decode. https://morsecode.world/international/decoder/audio-decoder-adaptive.html
  15. Channels 1-7 are the 462 MHz Interstitial channels and channels 8-14 are the 467 MHz Interstitial channels.
  16. AFAIK, they'd hidden/removed the install file for either the PC version or the free version for PC awhile ago, so not entirely surprising. I still had a copy installed and working, but it looks like they're shrinking access to the free side of things....not that I had access to much anymore anyway.
  17. A lot of new radios have automatic tone ID. If both tones are the same, they only need to be within receiving range of the repeater. If the tones are different (or only input), they would have to be within range of someone transmitting to the repeater, but it is automated these days. No longer necessary to just quess.
  18. Yeah, my truck has crap for ground plane and the 2x4 doesn't like it, but on the roof of my car, it has spectacular SWRs on GMRS, MURS, 2 meters, 70 centimeters, and even 1.25 meters. Yes, 1.25 meters. I don't know how well it will actually perform on 1.25m, but I intend to find out. SWR is well below 2.0:1, so it shouldn't hurt the radio. I also have a Comet SBB224 which is officially a tri-band (2m, 1.25m, 70cm) antenna and it approaches but does not cross 2.0:1 on GMRS. It also needs a ground plane, so it will go on the car if the 2x4 is weak on 1.25m. Or maybe even if it isn't. IDK I can't find any single antenna that will give me all the bands I want with the lousy ground plane on my truck so I ended up adding a dedicated 1.25m radio and antenna in addition to a GMRS/2m/70cm/MURS radio and antenna. Add the CB radio and antenna, and my truck kinda looks like a spaceship. The car is going to get a tri-band radio/antenna and a second NMO mount so I can stick on a CB antenna when I get the whim.
  19. Record it and post it here. Someone will decipher it. (Still not me )
  20. Yesterday
  21. You can get a smartphone app to decode CW. Not sure if leaving it running for hours would be a problem. I don't know if mine eats up storage space or just overwrites the same small amount of memory so I only let it run for a few minutes. Works better in a quiet room.
  22. To fast for me to ident... maybe 4 numbers/letters. Only happens every few hours.
  23. It would have had to be channel 7 since channels 7-14 are the interstitial channels at 467 MHz.
  24. I have heard a Station ID on one of the Interstitial channels before. I believe the channel was either 6 or 7.
  25. It could be anything. What does the Morse code say?
  26. Channel 6 in GMRS is limited to 5 watts Max. 462.6875
  27. Zello is shutting down the PC version and older versions on June 25th. Android app versions older than 6.0.2 (Note: newer versions no longer support Android OS versions earlier than 7) iOS app versions older than 6.1 (Note: newer versions no longer support iOS versions earlier than 14) Legacy PC app – all versions
  28. What do you mean by "max 5 watts"? You're receiving a signal from unidentified source. You would have no way of knowing its power output without the message you're receiving telling you. I know in amateur radio there are beacons set up that continually emit a morse code (cw) message that tells a call sign, a location, and power level. This is used by others to determine if a band is propagating. But you just get this "sometimes", so it's more likely that someone has equipment that is outputting morse to identify their station. However, if you're really curious, you can record the signal, and use an online morse decoder (or decode it yourself manually) to read what the message is saying. That will probably tell you who owns it. ...- ...- ...- is usually the beginning of a beacon's signal. The "vvv" symbols are easily identifiable as a beacon preamble.
