SteveShannon reacted to a post in a topic: Unlisted GMRS repeaters
SteveShannon reacted to a post in a topic: Well that was a surprise
SteveShannon reacted to a post in a topic: Base station cannot use repeaters
SteveShannon reacted to a post in a topic: Just passed my General class test on Saturday!!!!
Implies a dedicated system is not just something I made up. Saying that a Fixed Station may only communicate with other Fixed Stations is the very meaning of the word “dedicated”. Then I said “such as” because I used two relatively easy to understand examples, but using the words such as also implies that there may be other uses. The regulations do say Digital Data is limited to handhelds, but analog data and controls have no such constraint and can be passed using tones, such as DTMF. Digital data. GMRS hand-held portable units may transmit digital data containing location information, or requesting location information from one or more other GMRS or FRS units, or containing a brief text message to another specific GMRS or FRS unit.
WSIE370 changed their profile photo
WSIE370 joined the community
marcspaz reacted to a post in a topic: Fixed Station vs Base Station?
SteveShannon reacted to a post in a topic: Fixed Station vs Base Station?
WSHH710 joined the community
Ya, he's guessing at how it could be used. And I agree. I also agree there can be many more uses for it too. The only limitation would be your imagination and the 15 watt output.
yep, I understand the word, but I was saying he made that up and he can use it if he wants but I want interpretation or examples from the people in charge - why is that so hard for so many to people to understand
"Implies"
Except they didn't say that. And isn't data only for handheld? I can't picture what a 2-way intercom would be but I don't need to know anyway.
WRCR724 replied to WRPL700's topic in Amateur Radio (Ham)
You have to complete the NCVEC form 605 and on that form, there's a box to check if you want to change your callsign systematically. If checked, you will automatically be assigned a new callsign when your upgrade is processed by the FCC. So it kind of is automatic if you request it. Until then, you can use your current callsign/AE and operate with your new frequency privileges. Also, you don't need to pass ANY exam in order to request a new systematically assigned callsign. You could submit form 605 to a VEC or submit the request online through the FCC license manager site. -
Has no relevance. Ham doesn't have the fixed station type and GMRS doesn't have microwave, and you can't mix services.
WSEZ864 replied to WRPL700's topic in Amateur Radio (Ham)
If one passes their AE exam, they keep their original call sign unless they can find a vanity call they like that's available and apply for the change. You won't get issued anything automatically just because you passed the exam. Getting AE only qualifies one to apply for any available call and one will not automatically get reassigned a new or shorter call. -
WRCR724 reacted to a post in a topic: Texas needs more repeaters
WRCR724 reacted to a post in a topic: Call Sign Look Up and Personal Info.
WRCR724 reacted to a post in a topic: Interesting comments being filed with the fcc on unused 46Mhz/49Mhz pairs
Shame on me! I thought even the south end of a north bound horse would realize the example of microwave stations were just that, examples of fixed stations.
I have been here myself with a new H3. Please troubleshoot /check the radio's antenna port pin for visible damage/broken off. Please also examine the cable and the inline SMA adapters used during testing. Poor antenna port connection problems might affect your Finals, Output, and Reliable Repeater Connections. I have history here. I think the current CP is corrupted and not actually writing to the radio what you think. If you have a reliable H3 available, you can easily upload this good CP from this reliable HT >into Chirp> and then write that reliable CP to the non-working unit. Loading a reliable code plug is better than a Reset in my experience with multiple brands. In Chirp, always confirm that the Vendor and the Model are correct. Best Regards!
The regulations tell us exactly what is required of a Fixed Station and what a Fixed Station may do. They just don’t provide an example of how it might be used, and that’s good, because it leaves it up to the imagination of the user. 1. A Fixed Stations may only communicate with other Fixed Stations. The regulations do not limit it to just one other Fixed Station. This implies a connection to a dedicated system, such as telemetry or part of an intercom system, where the Fixed Stations have a single purpose. 2. A Fixed Station is limited to 15 watts. This makes sense for a system of dedicated radios in fixed locations where the distances and directions never change, such as two or more points in an intercom or telemetry system. It also reduces the likelihood of interference with other stations, especially if a person uses high gain directional antennas, such as parabolic dishes or Yagi antennas. 3. Fixed Stations may transmit on both the 467 MHz and 462 MHz main channels. Although simplex isn’t prohibited, this unique carve-out in the regulations makes it possible to operate full duplex between two Fixed Stations, transmitting and receiving simultaneously, which allows for very natural speech on an intercom system and is ideal for transmitting data and controls on a telemetry or SCADA system. So, for a family business (or a business which has a grandfathered license that covers their employees) Fixed Stations could be used for a wireless intercom. A farmer could use Fixed Stations to turn irrigation systems on or off several miles away. With the exception of the ability to operate in full duplex, which is made possible by being granted access to the 467 MHz main channels, all of these examples could be done as well or better with portable, mobile, or base stations. But for a system which is dedicated to a particular purpose between two or more fixed locations, such as telemetry or an intercom, where full duplex would a distinct advantage, using Fixed Stations would be a reasonable solution.
Speaking of which, why do we park on the driveway and drive on the parkway?
Baofeng GM-15 PRO program ANI.ID numbers?
WRXB215 replied to WRWU395's question in Technical Discussion
In the software, click on "Phone System" on the left. In the "Phone System" screen that comes up, edit the "Radio ID Code" on the right. -
WSID588 joined the community
I have received 16 TD H3s. I bought 14 and 2 were bad and they sent me 2 more. I don't use chirp. The TD H3 has it's own CPS that works well and is similar to the way chirp works. So use the H3 CPS. Have you tried to update the firmware to revitalize the "broken" H3s? You can even install the same firmware and overwrite the existing.
srwong41 joined the community
I’m beginning to think so too
And people tell me I’m nuts when I say h3s stink. Every one I know that has fell for them has a 50-75% fail rate. Vote me down all you want guys. This is just more evidence h3 radios are total junk.
And….now the two tdh3’s that took the place of the prior two that didn’t transmit now have the exact same problem. I think Chirp is bricking them somehow. They worked great for about 2 weeks and now zero output wattage. I’ve done nothing to them other than fiddle around chirp programming channels and repeaters. Resetting the radios did nothing. Wow. Stumped beyond belief. I’ve got two uv5g’s, 1 uv5g plus, and had 5 tdh3’s and out of 5 tdh3’s 4 of them have went to zero output wattage on my surecom meter after previously showing 3.7 watts. Gosh I hope I can sort this out. It’s not the meter because none of these tdh3’s will open local repeaters and they used to.
No. You seem to be joking / playing dumb. A car that is stopped is still mobile. One I always wondered about is my car, parked at home - is that mobile enough? Or do I have to drive up and down the driveway while transmitting?
No microwave frequencies in GMRS. And data as far as I know is limited to handheld and short duration transmissions. The official response made no mention of any special transmission modes.
AdmiralCochrane replied to UncleYoda's topic in FCC Rules Discussion
BINGO -
As has been stated many times on this forum, it's all about how the transmitter is being used. Two stationary units only exchange signals between themselves. They are not used to contact repeaters or mobile stations nor; do they contact other base stations that communicate to either other base or mobile stations. Perhaps the best example of a fixed station communicating to another fixed station are microwave links. they don't contact repeaters or any mobile or other base stations. they only talk to one other station at a fixed location.
krazeekirk joined the community
I used the term stationary to differentiate between a unit that doesn't move as opposed to a mobile unit that moves. Nobody argues about mobile, regardless of how it moves. But stationary (not moving) seems to be confusing. Seems pretty simple. A stationary unit( not moving communicating with another stationary unit ( not moving) both units are fixed. If a stationary unit communicates with a mobile unit it's then a base. Do I understand correctly.
DB20-G, GMRS mode, with ch. 39 programmed for simplex, ch 39 can be programmed from the mic for 467 mains with or without tone
LeoG started following Surecom sr112 on a retevis rt97s?
Maybe he's setting it up by himself like I did. Not everyone has people available when they need them to talk on the radio. I myself used a digital voice recorder which only activates when a sound is made. Used an app on my phone. I didn't get a response but I would go to places that I needed it to work and transmitted where I was and if it got recorded I knew that was a good test. If not, more work to be done or just don't use it there.
