31
Everything posted by BoxCar
Ground plane vs no ground plane mobile antennas
BoxCar replied to VETCOMMS's question in Technical Discussion
To partially answer your question, visualize an AC wave. How often that wave cycles is its frequency. As the frequency increases, the waves become much closer together. At 465 million cycles per second (465 MHz) the distance the wave needs to complete one complete swing is quite short (measured in meters). Now think of that wave riding on a wire. The full wave starts at zero (the wire) then swings to an amplitude before swinging back to zero. That's one half of a full wave. The half wave continues on to repeat in the opposite direction (polarity) to complete the full wave. In radio we use the distance a wave needs to move on a wire as an antenna. We feed the antenna at the point where the wave crosses the zero point and cut the wire to the length needed. The full wave still needs to happen with the parts of the wave not on the wire being found in (on) the metal the radiating wire is connected to. The metal forms the ground plane and can be any shape as long as there's enough of ti. -
Been using a sheet of steel like that for my base as well for over 2 years now. -
The Bridgecom repeater is manufactured by Maxon, using two of their 50W UHF radios. www.maxonamerica.com
I wouldn't wrap the two around each other, but they should be okay in parallel.
Mounting Wouxun KG-1000G + Front Panel w/ Magnetic Tape Strips
BoxCar replied to CALO50's question in Technical Discussion
My only suggestion would be for you to test for interference with the tape and panel. Not knowing your panel and how it is engineered, I suspect it contains only the electronics needed for the display and speaker. The audio from the microphone is most likely a pass-through, along with any signaling from the keypad. -
And has been stated, you are entitled to your views on radios, but those of us who are regulars on this forum are very tired of your rant and claims of hitting repeaters 200 miles away with your handheld.
The coax used is as important as the antenna. The signal going through coax is always reduced by a constant amount. The amount of loss depends on the coax itself and is expressed as a loss measured in dB per 100 meters. Choosing low-loss coax such as the Times Microwave LMR 400 or LMR 600 improves the amount of power reaching the antenna. When you subtract the coax loss from the antenna gain (if any) you can then calculate the amount of radiated power. Your transmitter is limited, by regulation, to a maximum of 50W of power but there is no regulation on the amount of power radiated from your antenna.
Non-binary
How far away is the repeater and is the path between your radio and the repeater clear?
The cheap connectors have inferior dielectric between the poles as well as poorer grades of metal. The dielectric won't handle high power (KW range) as well and the center pin can more easily shift causing impedance problems if they are moved frequently. For the most part, if you use one and it stays in place there will be very little, if any, difference in the overall performance of your radio.
you need the kenwood software and cable for that radio.
Recommending a radio is like recommending a church. It depends on what you want to accomplish as your journey progresses. You mentioned thinking about getting a ham license as a goal. Personally, I think amateur is the way to go, as the technician level license is easy to obtain. Yes, it requires study, memorizing answers and passing a 35 question test over the material, but the benefits are access to a much greater number of repeaters and systems. If that is your goal, then my recommendation is for an amateur handheld that can be unlocked for use on the FRS/GMRS frequencies. My recommendation for an amateur handset in this case is a Yaesu FT-65 or FT-4XR. Both are 5W units and can be unlocked by entering a code from the keyboard on the unit. The instructions are easily found on the Internet.
Welcome WRZB774. First off, it's unlikely you will be able to transmit and receive over 1 to 3 miles reliably with any handheld radio. So much depends on the antenna connected to the radio and its height above ground and surrounding obstructions. There are a lot of factors in even connecting your radio to an external antenna that make improvements to coverage area. The biggest factor is your antenna's height above ground followed closely by the antenna type, coax type and length. Your radio, and all GMRS radios, are line-of-sight plus about 15% due to atmospheric bending of the radio waves. That's why height matters so much. Your antenna type is also a major factor but consider the fact that almost all antennas do nothing to increase the range or strength of your signal. Antenna gain figures are bandied about by all manufacturers, but remember there are two ways of reporting figures. Gains of 2.15 dB mean nothing as this is a figure measured against a theoretical antenna that doesn't exist. This is dBi. Dbd is a measurement against a real antenna and is always 2.15 dB above dBi. The next limiter is the cable between the radio and the external antenna. All coax, the type of cable needed, resists the passage of radio signals resulting in loss. Loss is measured in dB or decibels and is a logarithmic value. 3 dB equals a factor of two, meaning the signal either doubles in strength or is divided by half. Different cables have different loss values depending on the type. RG8 type cables are the worst for loss and the common RG193 found on most antenna mounts provides an acceptable loss when the cable length is 20 feet or less. Increased power just floods you coverage area with more signal but does not increase distance. Only antenna height will increase the radio's signal horizon. Have fun.
Batteries with different voltages and capacities are available from Hobby stores catering to the remote control people. I used 3.2V, 7.4V, 12V batteries in the airplanes I used. Capacity ranged from 250ma to greater than 12A. These batteries do not have an internal balancing circuit, so one has to be provided externally. RC battery chargers have them built in.
Wonder if it could be one of the Chinese test frequencies.
Only when drinking a Lone Star.
Cable loss is loss period. It's the amount by which the signal is reduced going through the cable. It doesn't matter the direction, it affects all signals, incoming and outgoing.
For what you are going to spend buying pieces and parts, consider the BTECH RPT50 (https://baofengtech.com/product/gmrs-rpt50/) It's all together and the only thing needed are the cables, power, and antenna. At $1500 for the repeater that you KNOW will work, it meets all your needs. Run it at 25 W for longevity.
Power must be referenced to dBl, the imaginary laser operating in free space.
Your statement about losing 180 degrees of radiation is incorrect. An omni antenna has a larger lobe facing the ground plane and will still radiate in all directions. The increased radiation is from the opposite side of the radiation pattern.
FCC Improves On-line Interference Reporting
BoxCar replied to intermod's topic in FCC Rules Discussion
Another story is the commercial shipboard operators called the amateurs "ham fisted."- 42 replies
- FCC
- interference
(and 3 more)
Tagged with:
