31
Everything posted by BoxCar
This won't be decided here if those frequencies are available above Line A or east of Line C. Kenny, why didn't you verify your point with the FCC before posting your interpretation of the rules?
But at least the conversation is semi-intelligent.
i believe you are dismissing the Shannon Effect in stating you need solid copper core coax. The Shannon Effect (not our Steve's notes) states the higher the frequency, the electrons move closer to the surface of the conductor. That's one reason some coax has steel or aluminum cores and just a copper shell. The key figure to check in the cable's specs is the velocity of propagation along with the cable's loss.
You'll want this: https://www.amazon.com/dp/B0842B1WFS/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B0842B1WFS&pd_rd_w=x2cE1&content-id=amzn1.sym.386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_p=386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_r=9YZT9E1TH5RETEYTT830&pd_rd_wg=YGa5N&pd_rd_r=342e6db3-d9e7-4982-9774-5635fddbabc5&s=aht&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM
They are fine with the exception of the coax. I recommend https://thewireman.com/product/cq-rg8-low-loss-4xl-lmr400-equivalent/ for coax ($1.80 per foot). If you order from the Wireman, you will need 2 PL-259 connectors and 2 installations. The connectors are either $3 or $6 each and there is a $5 install charge for each. The Wireman also charges for shipping so that's an added cost. I use coax from this vendor for my own site.
Repeater question - TD-H3 GMRS, Tennessee Valley / North Alabama
BoxCar replied to WSDA306's question in Technical Discussion
You could also be getting a "Knife edge" as a sharp peak will deflect a signal toward the valley behind it. -
@WSDS356 You do know TQSL puts the same tone on both transmit and receive, didn't you? If you only want to send the tone but be able to hear everything on the channel, go to set TONE MODE to TONE with the code in theTONE column.
They are all about the same. The fact about FM is that all radios using analog FM are compatible. Don't overpay, but don't skimp either. The Radioddity 20W is good along with any other in the price ($20) range is what I would recommend. The Radioddity brand was provided as only a start, not necessarily recommendation. You will need coax with PL-259 connectors, LMR-400 quality and an antenna. Your situation, where you're talking only a few miles requires just a J-Pole style and my recommendation here is not an Ed Fong but an https://www.jpole-antenna.com/shop/462-mhz-land-mobile-gmrs-j-pole-antenna/,
No, a repeater is NOT what you need. Just a 20-25W radio set up in the house with an antenna 15-25 feet above the roof.
Lots of choices in this area. Keep in mind though the radio is only part of the purchase - You need an external antenna and mount which can cost as much (or more) than the radio.
It depends on what you expect. As you are just starting, a handheld radio provides a decent start. Your biggest hurdle is learning the terms sed and what they mean and apply to your situation. As you obviously have no experience or background in radio, start with an inexpensive unit. I would keep the cost less than $40 for your first unit. Read the manual that comes with it and spend time on Youtube with the tutorials and reviews. After you have played with the radio for a couple months and know its functions and features well, you might be ready to upgrade to a unit with higher cost and features. Don't get caught up in wanting bigger, better higher power unis until you know what you have and how to use it.
Maybe try holding the buttons and then power up the radio???
Club memberships required to use (aka Pay to play)
BoxCar replied to UncleYoda's topic in FCC Rules Discussion
No, but almost no radios are manufactured in the US. -
Buyer Beware - Fake Motorola PMNN4409AR Batteries
BoxCar replied to PACNWComms's topic in Equipment Reviews
+1 on Atlantic Battery having the right battery. -
There are ham groups in your area you can contact. Many hams (like me) are dual licensed for both services. Some clubs have both services on repeaters also. My home club is looking into adding a GMRS repeater to our primary site as an example. I would begin by contacting the Myrtle Beach club to ask for assistance. https://w4gs.org/For-New-Hams/
The answer is really pretty basic - it's what's inside of the radio. Transistors, chips, capacitors and all the other parts and pieces are all made to operate within an ideal environment. The wider the operating environment, the higher the cost for the component. Then there is the design. The oldest (and one of the best overall) is the heterodyne which mixes a known frequency with the received frequency and the resulting product is processed for the receiver. The newest design is SDR or software design which converts the incoming signal to digital bits and the processes them. The other design has everything inside an IC or chip. The SOC or system on a chip is the least flexible but very good within its specifications. No GMRS radios or handheld models use SDR so they are either heterodyne or SOC. The transmitter portion of the radios is pretty much the same no matter the receive portion of the radio. So, its the components and the care taken in fine tuning them that makes up the real difference.
Yes, the frequencies (channels) are set by regulation.
Question about antennas and setting up new radios
BoxCar replied to WSDQ634's question in Technical Discussion
My experience with longer antennas on hand-helds is you may hear better but it doesn't translate to transmitting further. -
Welcome to the S*** show that's radio hobby use. You'll find that any external antenna mounted the higher the better will be an improvement. Along with a better antenna, good quality coax is required. The baseline for coax is Times Microwave LMR 400 or equivalent. RG-8 coax is a big No-No.
There is no real difference between the radio brands. Yes, commercial and public safety models generally have better specifications but that is reflected in the price. System on a Chip (SOC) radios work perfectly for general hobby/personal use. Personally, I think the Motorola, Kenwood and other "top-tier" radios are all way overpriced and for personal use. I recommend some of the Tytera, TYT, Wouxon and other brands as being perfectly usable for general use. 5 W output is 5 W whether it comes from a Moto or BaoFeng.
Dweebs are dorks that don't have adhesive tape on the bridge of their glasses.
You don't loose 1/3 of your coverage area by narrowbanding. The most I ever saw back in 2013 was about 1 or 2 miles at the extreme edge and some even gained some additional coverage area. I monitored ALL of the Public Safety narrowbanding request as part of my role as the national frequency coordinator for some frequencies.
It would be better if they listed the tones used as not all radios use the same tone code scheme.
