BoxCar
    31
Everything posted by BoxCar
  1. Do birds roosting on the spider wire cause interference or just loss?
  2. Use Repeater Book. You can specify listings by highway in each state you are planning to visit.
  3. The codes are really filters that exclude transmissions not having the matching code. They don't offer "privacy" as any transmission can be heard by not using the filter code. Repeaters use input codes, t-ctcss, to limit the signals it retransmits. The R-CTCSS code in your radio screens all traffic not matching the code, but it's not really needed for receive. Having no receive code means you hear everything transmitted on the channel. So yes, you need to set the T-CTCSS but the receive is optional.
  4. Misspelled - should have been bring the antenna down (closer to ground level).
  5. Did you look at the radiation pattern for this antenna? Comet shows it having a very narrow lobe (around 20 degrees is my guess) so the power is directed at the horizon and not close to the ground. In order to pick up your friend a 1/2 mile away you will need to ring the antenna down or use a second, low gain antenna, I
  6. Search for FT-4XR unlock on YouTube. (
  7. I go to a local ACE Hardware and they have both SAE and metric set screws in stock. I then see what fits and use blue Loctite when installing.
  8. Probably the best solution for this would be a decent mobile antenna on a mag mount sitting attached to a steel baking sheet. If you wanted to stay with the antenna attached to the HH, I use ones from Signal Stick.
  9. Will that result in pickled contacts? I
  10. ??? Generally if you leave a battery-powered device on, the wattage in the battery decreases.
  11. On the railing your signal would look like a football if you could see it. Better EW but still usable for a shorter distance NS.
  12. Isn't that what I said?
  13. The railing will also work. The signal from your radio will be stronger going in the same direction as the railing, but still omnidirectional for all practical purposes.
  14. All repeaters are +5 - period. The gods at the FCC have spoken and we must obey. Unless a digital code is followed by the I (eye) it is normal.
  15. Reported to Rich
  16. As a Moxon is a variation of the Yagi, the driven element should be between the director elements and the reflector. the reflector is around 5% larger than the driven element and the directors 5% shorter as they go toward the front of the antenna. I'm not certain of the spacing between the elements.
  17. BS The key point is you need a compatible driver for the cable. Cables using the FTDI chjp/driver set are almost 100% interchangeable between radios. The only time I've found they aren't is when the radio requires a specific driver to access a proprietary feature found in their cable's chipset.
  18. As Steve says, but there's more to it than just getting a battery. You'll need a charger for the battery, something like Amazon.com: 14.6V 10A LiFePO4 Battery Charger Special for 12V LiFePO4 Battery, Trickle Charger for Lithium Iron Phosphate Battery, Battery Maintainer, Built-in Safety Protections, Support Fast Charging : Automotive along with the crimp tools for the connectors. You'll need a couple of crimp on connectors for the battery. They'll need to be .250 inches wide for an F1 tab. Quicksilver Radio will sell you a premade power pole connector for the battery box Play-Series™ Powerpole Mount.
  19. Why did you attempt a firmware update? Was there a problem with your radio the update was supposed to fix? The old saw, "If it isn't broken, why fix it" applies. This goes along with the caution that an incorrectly applied update will make your radio unusable.
  20. Probably the station ID being broadcast in Morse Code.
  21. You know, you are very annoying bragging about what you have without providing any information regarding brands or where to find equivalents. Just what brand is your "80A supply," where did it come from, and, what' the current cost. Try saying something truly useful for a change.
  22. That will work, but I'd future-proof and go with a 25-30A model instead.
  23. Any antenna that has an SO-239 connector. You'll also need coax between your radio and the antenna. Look for coax labeled as LMR-400 or equivalent. DO NOT USE RG-8 and its variants.
  24. Almost any power supply putting out 10A (12oW) will do for that radio. For a 50W radio, you'll need 15A up to 20A (180-240W).
  25. The 60W power supply is good for receiving only. You'll need at least 96W to transmit but a 240 to 360W will be much better. I'll also recommend 2 antennas, one for the car with the other for the house.
