BoxCar
    31
Everything posted by BoxCar
  1. Mark the spot? ('cause you're all ...)
  2. You assume much with that statement.
  3. one ahh shit wipes out 100 atta boys.
  4. @WSGN731Welcome to the zoo! Before you ask, the best radio to install in your Jeep is the one that fits your requirements best. That, and there are as many recommendations for antennas as there are antennas,
  5. As far as how high can I go with my antenna, there are rules covering antenna height and lighting/painting depending on how close to the airport you are. For most practical purposes, you can ignore them unless the highest point of the antenna exceeds 200 feet. Practically, plan on your height being 20 - 40 feet above your roof as a maximum.
  6. That can only happen by connecting the local repeater to another network. If the control passes only control codes affecting the ability of the target to carry information, then the connection is valid, however, should any other type of information be transmitted through the connection the connection becomes invalid as different networks carrying information ae interconnected. With a stricter interpretation of the relevant section, it would be an invalid connection even if the purpose were to listen (monitor) traffic on the target radio.
  7. OK Cogent, I'll call your bluff. What law firm are you using as an advisor for interpretation of the FCC's rules and Part 97 regulations? If you don't have an attorney of record providing regulatory guidance who has worked with the Wireless Telecommunications Bureau on the feasibility of this proposal, then it is nothing but a pipe dream borne from a desire to increase division revenues.
  8. Cogent just wants people to purchase equipment through them for the revenue. The Commission has made their position clear in that GMRS repeaters are not to be interconnected for carrying conversations. The spectrum assigned to FRS/GMRS in the Commission's jurisdiction isn't large enough to support linked repeaters without causing undue interference to other users.
  9. Sounds as if you have a defective radio. Contact the seller for help and/or replacement l.
  10. Different licensing pools.
  11. @OffRoaderX We don't know how the OP plans to mount the antenna for his proposed repeater. He may very well be within one of the propagation nodes for whatever antenna he chooses, and then, he may not be. Your testing of HH with your repeater's antenna above you has you within an area of very low propagation for your antenna and therefore, your results are applicable only to you. As to suggesting amateur radio, this is an option just as using GMRS, MURS or FRS are options. GMRS and amateur radio services are the only services having repeaters available for use by other licensed users and therefore fill the requirement for repeater availability. It is well known you are a vehement adversary of ham radio preferring to classify all amateurs as sad hams. Does that make you a sad GMRS user? l believe you need to be more moderate with your tar brush remembering when you point your finger, three are pointing back at you.
  12. For just you and your friend, a pair of FRS radios will work between your locations as outlined. A repeater on your balcony will probably overload your HH radio when you try to connect through it. If you both get licensed ($35 for 10 years) then you can go to GMRS, or, you both could study for a week or two with one of the many license prep manuals and the YouTube videos to pss your Amateur Tech license exam and use existing amateur repeaters across the country.
  13. Yes.
  14. Maybe Socalgmrs swallowed a bag of cow manure and is just regurgitating some. OBTW, he's the only entry on my ignore list.
  15. I'm surprised they haven't gone metric as the numbers would be larger.
  16. LMR 400 available from many different suppliers. Antenna depends on height, and need.
  17. Helene took out most of the towers in western NC because the power was lost. Very few cell sites have any type of backup power.
  18. If I remember correctly, most states have laws against having both ears covered while operating a vehicle. That would depend on an officer classifying a bicycle as a vehicle which, technically, it is.
  19. The rules don't prevent a 3rd party from operating the radio with the license holder present. 97.1705 states who may hold a license while 95.1743 excludes minors from responsibility for improper operation. Further complicating the scenario is the question of operating on FRS channels. Is the station still a GMRS unit or is it an FRS unit? Notwithstanding the fact the station equipment meets the specifications of a GMRS unit as it is not handheld and has a removable antenna makes it exceed the FRS equipment restrictions. However, this is all moot if the instructor provides FRS handheld radios to contact his station.
  20. Do you handle the PTT with a non-ham?
  21. As I understand the rule, you are not sharing your license so others may operate independently as family. It's a single station, with you present allowing another to talk over the radio. As long as the students don't try to operate personal radios under your license it should be good. Also, the rules are silent about who may talk on a station with the license holder present.
  22. The issue is operating legally. As long as you control the station, students can operate it as a GMRS station.
  23. BoxCar
    CONFUSED
    You won't get any real help without telling us what city/state you are in and what radio you are using.
  24. BoxCar
    CONFUSED
    Asking for help?
  25. If you are pretty much set on a HH, I would look to Yaesu, Anytone, or TYT as alternates. These can all be unlocked for GMRS and have about the same capabilities but can be lower in price. One of the low-price GMRS "suitcase" repeaters would be sufficient for covering 5 miles with a decent base antenna or a good mobile antenna with a ground plane.
