BoxCar
    31
Everything posted by BoxCar
  1. You can't measure SWR on handheld radio antennas without very specialized equipment.
  2. Good info, but personally, I would have just replaced the screw.
  3. There is a wallet card on all recent license documents from the FCC. It's below the "mini" license they provide nowadays.
  4. Actually, it is based on observation of processing many thousands of requests to the Commission for processing. l
  5. I will wager this statement will prove false.
  6. Notice, I stated the primary purpose is to pass data. I did not state a fixed station was data only nor reference nor imply that was their only use.
  7. Not quite, fixed stations are primarily used to pass DATA between two fixed locations i.e. flood monitoring stations and monitoring posts. "Base" stations are control sites which activate repeaters or fixed stations to report. Base stations are at either permanent or temporary locations and are used to pass both data and voice to other base stations or mobile stations either through repeaters or directly. This implies there are three classes of stations, fixed stations reporting to another, single, fixed station, control stations, which may serve as both control and base stations and mobile stations which have no permanent location.
  8. Fixed stations don't connect to mobile stations.
  9. Dimmy antennas are used to contact stations 200 miles away.
  10. Any 50 ohm load rated for 50W or more.
  11. Our ham club operates a GMRS repeater on our tower and is maintained through club resources. Yes, it is licensed through a club member holding both licenses. So, stating a club cannot operate and maintain a GMRS repeater is incorrect. The licensee is the owner of record and responsible to the FCC but it's a ham club operated repeater.
  12. From SoCal? He only knocks what anyone has.
  13. And to add, the tones used as default vary between manufacturers. Retevis tones are not the same as Baofeng's or TID's.
  14. Stereo to mono plugs DO NOT combine two channels but keep them separate. Combining the two channels through wiring only affects the impedance seen by the amplifier and speaker. To work correctly, the two channels have to be fed into a mixer which combines the audio signals and keeps the impedance of the circuit constant. What the stereo to mono plugs go is combine the ground return path while putting one audio signal on the tip and the other to the ring.
  15. Heliax is the best, but a lot depends on the repeater itself. How much power does the repeater have? What antenna are you planning to use? A low power repeater (less than 25W) can usually get by with LMR 400 or better coax for that length run. Coax loss can often be made up with antenna gain. Where the repeater is located, terrain, and intended use also factor into the need for Heliax over coax. Repeaters only cover the area from the antenna to the radio horizon and increased power only means the signal is stronger in the same area determined by the antenna type and placement.
  16. Welcome!
  17. I don't think any antenna would survive that kind of abuse. Think about a 1/4 wave stubby like a Laird or similar that's about 6" high. They're relatively inexpensive but work well.
  18. Caca de toro - or BS to those not understanding Tex-Mex. You can't make such a wild assertion without empirical truth to back up your WAG. Hams in my area are actively reaching out to GMRS users to the point where they have collocated GMRS repeaters at their stations. The clubs I belong to are talking to GMRS users and preppers actively helping them make the best use of the equipment they have.
  19. I would check the antenna. Use a Nano VNA if possible and check the frequency the antenna resonates at along with the bandwidth. As you stated it's a home brew, its possible it is off frequency.
  20. Illiterate? Write for free help
  21. @Jaay Because it's a contest -- and I'm winning!
  22. Or, you can do like the rest of the doofuses, cut first and then if it doesn't work, get on the Internet and tell everyone how crappy the product is.
  23. It can be done as a voting system which isn't cheap. The two repeaters listen to the incoming signal then the one with the better receive "score" triggers its transmitter. Yes, the repeaters are interconnected but it's for the purpose of control and not relaying messages.
  24. NaNa NoNo has spoken.
