BoxCar
    31
Everything posted by BoxCar
  1. This is the primary reason I went from GMRS to amateur. At the time I received my Tech license (2021) there were no GMRS repeaters operational in my area of south Asheville and the only traffic was on FRS from a couple senior residences and a local fast food place. My experience with amateur prepared me for the loss of power and having my Go-Box radio up and running on fully charged batteries. We lasted 3 days before traveling out of state due to no water and a route being open allowing us to go north. During the 3 days we were here, our club repeater was running on emergency power and traffic was being passed both in and out of the area. With no AM radio, we had no news except for what was passed over our net. So, when the fecal matter hit the revolving impeller, my wife and I were both prepared and able to contribute.
  2. Radiated signal has very little effect on distance. You are increasing the signal density within the same area governed by the height of the antenna above the terrain level as dictated by the curvature of the earth. The distance to the horizon doesn't change no matter the power of the signal. Increased power primarily affects the area at the fringe of the coverage area making a marginal signal stronger.
  3. l Well, part of this is BS, but there are some parts that are correct. There are two paths that must be considered along with the radiated power of the target unit. There is a "talk out" path which is the repeater's coverage area. This depends on three things, antenna height, antenna type, and radiated power. This is also dependent on the terrain (more than obstructions) between the units. The other path is the return or "talk in" path. This path is also dependent on the same restrictions as the repeater. Obstructions do have an effect on the two paths, but their effect is more dependent on the type of obstruction and the density and - the total amount of obstructions. Trees, depending on the type, can interact with the signal. Leaves on trees such as the oaks Texas has in abundance have less effect than say a mesquite or pine. This is because the shape of the leaf can be seen as a mini antenna that acts as a receiver absorbing some of the signal. Buildings contain metal which blocks radio signals, and both the type and amount create problems. On the other hand, buildings and hard, dense ground like rocky cliffs can also be reflectors causing the signal to bounce in a different direction. The power of the radiated signal doesn't increase distance as much as it fills the same area with more signal (signal density). The antenna determines how the signal is radiated. The most common is an omnidirectional having a doughnut shape around the center of the radiating element. How fat the doughnut is depends on the gain of the antenna. The higher the gain, the less "fat" shape of the pattern.
  4. I think you are overdoing the security aspect. Using a digital signal such as DMR or NXDN would probably be all the security your son's team would need. While you re not supposed to use digital signaling in the FRS or MURS bands, a few radios operating low power would probably be dismissed by most people. The limited power, 2 W or less will also limit interference to others.
  5. You are correct in that no one person or entity (other than the FCC) owns or controls the channels. No person or group can stop you from using any of the channels allowed by your license or device. You are free to receive any channel or frequency, however, you are allowed to transmit on authorized channels. With only 8 channels or frequencies available for repeaters the key concept is sharing use. The rules clearly state that no user is not to intentionally cause interference, and they must accept any interference to their use of the channel. In the situation you asked about, all channels being in use, it then comes down to sharing and accepting the fact you will both cause and receive interference. The users of a single channel should agree between themselves what type of interference is acceptable and how much is considered reasonable. It is against the rule about sharing if one user deliberately causes other users of the frequency interference by causing their transmissions to be interfered with just as any retaliation against an interferer is not allowed.
  6. Welcome to the forum and good luck with the test. Best advice - don't overthink the questions.
  7. Actually you can. If the SWR decreases at higher frequencies the antenna is short. Conversely, if the SWR decreases at lower frequencies you need to start trimming in 1/8 inch chunks.
  8. What type of labor are you going to do"?
  9. BoxCar
    Radtel RT-493
    Reports on other models of Radtel state they're not great but adequate.
  10. The party controlling the White House selects the Commissioner and the majority of the other members. they used to be engineers but that changed to lawyers 40 or more years ago.
  11. Site owner - Rich
  12. Really that's a question for Rich as it is his site and he knows the registration requirements.
  13. Amazon also has it for $374.13 but you may be able to get free shipping if Prime. https://www.amazon.com/Hustler-G6270-R-Station-Antenna-Connection/dp/B00FYUW6H6/ref=sr_1_9?crid=2QDOYM4F018MF&dib=eyJ2IjoiMSJ9.Vd3s9Y4qmh9yveZ29u2R0gfB6CVJaqFgmTsW3_NH2jc_y4zQhAD3IOsDYLqsPydNKEHKLSjZyYbrGG8XB6myXI4souVsXOItKD9VMRsYzxlbNpxSxfcjdYsfiKeFqk3OJXvsFCJwIMzW2uHoezGae7Zf85NGMqFkftuiuuQc4zIyDqncvw_0Rv4kdnb9ciFOU7YmLX6UnEBsMCbgQeqFK3EfeaqeRTqisOH5bpn6DIc.lSJybktqJKFsJKYNI-4OUizVnJKoEN2X0pQDjQ0j1EE&dib_tag=se&keywords=hustler+g6+antenna&qid=1729965713&sprefix=hustler+g6+antenna%2Caps%2C97&sr=8-9
  14. There are lots of choices for handheld (HH) radios for a lot less than the $200 Midland wants for theirs. Some other brands to look at include Wouxun, Retevis, Radioddity, TID, and BTECH (Baofeng) to name a few. Prices range from $24 for a Baofeng UV-5G to $70 for a pair of Baofeng UV-5R radios on the first Amazon page I pulled up. Personally, I've been reading good reports on the Radioddity and the TID radios along with the more expensive Wouxun units.
  15. I like Gretsch
  16. How do you know you aren't transmitting? Channel 1 is simplex meaning you receive on the same frequency where on repeater channel 1 you are using two frequencies.
  17. Let's break your statement down. First of all, you are correct in that the radius is an approximation (really, guesstimation) on the coverage area. Some of the best estimations are based on a mathematical model developed by the team of Anita Longley and Phil Rice in Boulder Colorado. Their model, the Irregular Terrain Model, takes the curve of the earth along with its ridges and valleys into play and does a fairly accurate job of predicting if a signal sent from one point reaches another point and at what strength. The model takes several things into consideration in its projection of coverage. Chief among them are the "big three" of frequency, radiated power, and the height above ground of the antenna. Also playing an important part of the calculation is the radiation pattern for the transmitting antenna. The coverage radius for a repeater is typically based on just two factors, the transmitter power and antenna height. This provides a guess that you should be able to both transmit and receive better than 80% of the time within the area calculated. The only time the model is 100% correct is when there is a clear path between the two stations (line of sight for VHF and UHF). So yes, you are correct in stating because you are in the radius reception and transmission may not be possible. But other than that, the rest of your statement should not be taken as being fully accurate. The ability to reach a fixed location, the repeater, depends soley on the position and power from the mobile station. We refer to this condition as the "talk out" and "talk in" projections.
  18. Just because "I saw it on the Internet" doesn't necessarily imply it is correct or complete information. You need to know and understand the source and their agenda in accepting the information as correct. With radios, the allowable frequencies and uses are set by both regulation and treaty. Treaties between countries are important as radio waves do not respect borders so agreements are needed to mesh the use between different purposes as defined by each. As an example, Canada has assigned different uses for some radio frequencies than they are in the US. The treaty allowing some frequencies to be used also blocks others because the frequency is intended for a different use in their country. I
  19. You have two things to understand here. Repeaters are almost always higher power than your hand held (HH). Repeater antennas are almost always higher above ground than your HH antenna. Power means better coverage for the signal area and height means distance. The higher above the average terrain in your area you put an antenna, the greater area served.
  20. More likely the battery is bad from being over discharged as it probably doesn't have a low voltage cutoff.
  21. Yes, they are called SDR (Software Defined Radios) and interface to your computer.
  22. Ahh, another wallet in the wishing well!
  23. Yup, welcome to the zoo!
  24. While there is some truth in what @Socalgmrs sys, the shape of the ground plane isn't as important as it sounds. Your antenna will work fine with a better radiation pattern front and back than to the sides.
  25. Definitely sounds as if it is a configuration issue. Does the repeater use tones? If so, remove the tone on the transmit frequency (462 MHz) and on the handsets receive (also the 462 MHz frequency). Be certain the HH transmit frequency has the same tone as the repeater's receive frequency (467 MHz). Does a HH open the repeater's receiver on the 467 frequency? What antenna is the repeater using? Is the antenna tilted away from your location? That may cause the radiation pattern to be more elevated when using higher power. Try a different antenna with the repeater. Just some thoughts on trying to diagnose the issue.
