31
Everything posted by BoxCar
Starting a thread for sale notices
I get my Wouxun KG-1000 G Plus Mobil Today - Base Antenna Discussion
BoxCar replied to Tiercel's question in Technical Discussion
Laird antennas are some of the best ones made. Larsen antennas are a close second IMO. What you want to look for are any gain figures. Measurements in dBd are real gain while measurements in dBi are theoretical gain. You can convert dBi to dBd by subtracting 2.1 from the dBi figure, and yes, some antennas have negative gain in the real world. You'll find a lot of the inexpensive antennas have no or unity gain 0 dBd or 2.1 dBi. Gain flattens the signal sphere around your antenna, so more signal radiates toward the horizon rather than up (and down) toward the sky. -
For coax, go here: https://thewireman.com/product-category/feed-lines/coax/?product_count=48. The Wire Man provides the private branded RG-8 coax sold by DX Engineering. Same coax, half the price, -
I've got one of the FTM-6000s. It currently sits in a go-box, unused. I'm not a fan of the menu system and found it difficult to work with, as it's just not intuitive, IMO. As a unit, It is a decent starter rig, but I do prefer ICOM and its menu system. My primary unit is an ID-5100 which has its own quirks as far as using the remote head is concerned, but I solved that with a Swap My Rigs extender kit.
Antenna height and length of coax hypothetical question.
BoxCar replied to WRZI712's question in Technical Discussion
Go to https://timesmicrowave.com/documentation/lmr-guide/ for the Times Microwave guide to their coaxial cables. -
beofeng gm15 and antenna and power question
BoxCar replied to WRZF693's question in Technical Discussion
Antenna height is the key. A higher antenna means the distance to the horizon increases along with clearance for obstacles like hills, trees, and buildings. You can use something inexpensive as a mast for an outdoor antenna such as PVC pipe. You can easily use 2 ten-foot sections of 1 1/2 inch pipe to get your antenna up over 20 feet. -
Straight-through cables and the various Cat cables all connect pin 1 to pin 1 at each end of the cable. The difference being the color of the wire strands used. There are other differences but they are important only in network situations.
Seeking advise on 5w HT vs. 15-20w mobile for repeaters
BoxCar replied to WRZI393's topic in General Discussion
Handhelds are limited to low power, but the advantage is that they're self-contained and very portable. They can be connected to an external antenna through adapter cables or plugs, but you're still limited. A mobile will have more power to punch through local obstructions but require an external power supply, power cable adapter, or connectors, along with an external antenna and cabling. The biggest advantage is power, of course, but also much greater flexibility with the programming. What you get will depend on how you are planning on using the radio. If you are primarily using it from your home, then a mobile would be the better choice. With an extra power cord and antenna you can use the same radio in your vehicle. If you wander around the landscape on foot, then the HH is better. -
However, if you do want to tune your antenna, or compare different antennas, use one of these: https://www.amazon.com/AURSINC-NanoVNA-H-Vector-Network-Analyzer/dp/B07Z5VY7B6/ref=sr_1_3?crid=1R9O27XQ4SNH6&keywords=vna&qid=1700049596&sprefix=vna%2Caps%2C215&sr=8-3&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840&th=1
What is the best antenna and brand for HT GRMS radio? Beufong GM15. ?
I don't like disagreeing with you, but your statement is both true and false. Radio engineers, at least the ones I have met, do test stock antennas with their designs and write specifications for the "rubber ducky" that provides the best match. Many times this results in one that has to be manufactured to specifications that existing units don't meet. Why else would LMR radios specify different antennas for specific radios operating in the same band? One size doesn't fit all. -
Welcome to the forums.
Higher power means better coverage in the same area as the increased power penetrates obstacles better, but the area served remains the same. -
And it does have a dark underside.
Does that answer come under RTFM?
If I understand you correctly, the two radios will NOT talk to each other on that frequency pair. You need a third radio in the mix, the repeater. A repeater consists of two radios set to receive on one frequency and then transmit what is received on the other frequency. What you are trying to do is use a split channel where the radios receive on one frequency and then transmit on the other frequency but not simultaneously. In order to do this, the frequency assignments in one of the radios must be reversed so its receiver is on the other's transmit frequency.
In a nutshell, Standing Wave Meter, CQV SWR120 Digital Power Meter, 240x240 Full Color LCD Display, 1.8Mhz to 54Mhz, 0.5W to 120W. I just received this meter and plugged it into my radio. I was impressed with the easy to read screen even with its small size. QST has a review on the meter in the Nov. 2023 issue and they show it is quite accurate out of the box. Amazon lists it for $79.02 but a quick search got the price doen to $45.02. I paid slightly less from a Chinese store, just over $41.00. It sure beates my Surecom SW-102.
GMRS Repeater Build - Targeting a 20-30 mile radius
BoxCar replied to WRZA597's question in Technical Discussion
Does your ham club have a repeater? Ask if a GMRS one be added to the site. -
Newbie looking for HT to cover both GMRS and HAM frequencies...
BoxCar replied to WRZE000's topic in General Discussion
My suggestion is to check the ARRL website for ham clubs near you so you can see what V/UHF bands are used in your area. Yes, the Wouxun does cover the amateur bands available to users holding a Technician license or higher, but you aren't going to reach many without using a repeater. Most amateur repeaters are VHF or 70cm (440 MHz), with a few at 220. Some excellent ham radios in the handheld form are the Yaesu FT-4X and FT-65. These can have the GMRS and MURS channels enabled by entering a code through the keypad, but that modification makes the radio non-compliant in all services. That doesn't mean it isn't done; it just means the radio is non-compliant for use outside the ham bands. -
A 45W mobile can be had for about the same price with fewer points of failure. What's not shown in their ad is you'll need a hand mike for the radio as trying to hold and key a HH while driving is very cumbersome.
I don't believe i will work as drawn. You need to charge the batteries with a 48V+ source. Now, could the chargers be in series, I don't know but our resident P.E. Mr Shannon may be able to answer.
Yes, there are effects from what I learned was a parasitic radiator. The amount of effect is determined by the percentage of a quarter wavelength distance between them. At a quarter wavelength the parasitic radiator will boost the signal from the transmitting antenna and at a half wavelength will have no effect. At 1/8 wavelength there will be maximum affect as the reflected wave will be in full opposition to the radiator. A simple visualization can be done by drawing a full wave on a piece of paper and then moving a mirror representing the second antenna along the X axis, You will have a visual representation of the affect of the two antennas.
A better power supply (IMO) is a Mean Well LRS series unit. A Mean Well LRS-12-360 supply can be bought from Amazon for less than $40 and can supply the 13.8V needed by the radio with medical grade power. It doesn't have the fancy meters and you'll need a cheap volt meter to adjust the output voltage but once set you can forget it for the next 20 years or more. I know of several public safety sites that use these supplies in their repeater sites.
