31
Everything posted by BoxCar
Gentlemen, Uncle Yoda is correct in the definition and use of a fixed station. Fixed stations only communicate to other fixed stations. Fixed stations DO NOT communicate to other mobile, handheld or base stations. The most common examples of fixed stations are SCADA stations used to monitor events and microwave sites. Microwave sites and SCADA stations only talk to another station of the same type, SCADA to SCADA and microwave to microwave. Base stations, operating from a "fixed" locations, communicate with other base stations, portable units and mobile units. A repeater site, even though it is in a stationary location is not a fixed station because of how it is used. It fits the definition of a base station as it passes communications between other base stations, mobiles and portables. Fixed stations use highly directional antennas such as a Yagi or parabolic dish pointed at the ONE station set to receive their transmissions. So, the radio in your house or the repeater you use, even though their locations are fixed - as in stationary - they are not fixed stations.
You can always ask them to repeat their call sign a little slower so you can log it.
Repeater hopping through passing codes across the air isn't possible with the current technology. Linked repeaters are connected through a separate network either through microwave or landline links.
Without being more specific a complete list would span DECADES of approvals and that could be over a 1000 units.
I would follow the ham repeater protocol and just state <call sign> is monitoring, anyone out there?
QRZ and Gigaparts are offering new hams a great 2M 440 handheld for less than $15. QRZ New Ham Jumpstart Program This program is only available to Amateur Radio Operators whose (first) FCC license was issued within the past 6 months. This program is designed to promote amateur radio to the masses, helping to eliminate a possible barrier to entry by providing new hams with everything they'll need to get on the air at a very reasonable price. Jumpstart Packages will be provided to new hams who meet eligibility requirements. New hams who have recently obtained their first license from the FCC may apply for a welcome package. Applicants must apply within 6 months of the license grant date per the FCC records. The eligible ham must have a QRZ user account and be able to log in and apply for the program. Certain types of identification, including a photo ID, will be required. This information is not shared or exchanged with any party and is used only to validate eligibility under this program. Additional shipping charges may apply when shipped outside of the contiguous 48 states. This program is available exclusively to USA licensed amateur radio operators. New Ham Jumpstart Program - QRZ.com
You're in for it now. Constant questions, debate and the pursuit of ever newer and better radios!
As people keep saying, it isn't the power that's key, it's the antennas. All increased power means is you have a stronger signal in the areas you already cover. UHF is line-of-sight so the "fix" is to get the antennas where they can "see" each other. Raising an antenna 6 feet gives you about a 2 mile increase in coverage area and that is much more important than pushing power into the same smaller area you currently have. This isn't CB (or low band VHF) that will somewhat follow the terrain, this is radio waves that reach the horizon and continue on into the ether.
Look for a local radio dealer. Google will be your friend here.
I believe what the note about an external GPS is it means an external antenna connected to the tablet.
The other point in your post - Increased power does not mean increased range with UHF frequencies.
Any recommendations for business band radios?
BoxCar replied to HK2GO's topic in Miscellaneous Topics
RCA is another option. RCA Mobile Radios (radiodepot.com) BRM300D_Spec-sheet_print-1.pdf -
It sounds as if the final power amplifier stage was blown. By any chance could the radio have been keyed up without an antenna or dummy load attached?
Receiving signal from repeater, but no volume
BoxCar replied to WRPT260's question in Technical Discussion
Make certain you have no tones set on your receive frequency. -
Antennas are radio agnostic. As long as the impedance is right and the connectors match antennas work. So yes, the Midland antenna will work with almost any radio.
Actually, the person requesting to transfer the license only needs to be eligible to hold the license. It does not need to be business to business for 90.35 frequencies. The same is true for Part 90.20 licenses as well. The transferee must be eligible under the rule to hold a public safety class license. The classes of individuals are listed but include veterinarians and disabled persons.
What model/brand of HTs are you trying to program?
BoxCar replied to WRAX891's topic in FCC Rules Discussion
The two most common elements in the universe are hydrogen and stupidity. The ongoing debate is which is the more common. -
It's probably safe to leave it in the charger, however, Lion batteries don't discharge themselves quickly like the older NiCad batteries did. I've charged up radios and let them sit for a couple of months on the shelf to find they retain 90% of their charge or greater.
The usable frequency range of the transmitter covers the Part 90 spectrum.
The manual that comes with your radio should tell you what the power draw is during transmit. Round this value up to the nearest multiple of 5 and you should be good. I personally use the Mean Well (Meanwell) brand of power supplies that can be found on Amazon as well.
BoxCar replied to coryb27's topic in General Discussion
Maybe start knocking on doors and asking if you could rent their attic for an antenna location. Offer them say $5 per month for the space and a little electricity to power the connected antenna and radio. -
Why not help your friend get his Tech license? Then you could use the existing repeaters to stay in touch. -
There is no rule about giving an existing repeater priority but there is a rule within Part 15 that states a station must avoid causing interference. That rule (admonition) is repeated in many other parts of the regulation. Simply translated into practical usage is if someone is already there, you need to go somewhere else. With only 5 channels, it can be difficult to find an unused pair, but it is the responsibility of the new station to either negotiate a sharing agreement with the incumbent or forego establishing their site.
If there are no repeaters in your area then the 5 frequencies are available. If there is a repeater operating, you are required to give that user priority for the channel and either select another channel or reach agreement to operate so not to cause interference to the existing user. The rule reads you must avoid causing interference but accept any interference from another station operating on the same frequency. Using tones or codes on a channel does not stop interference as you are both using the same channel.
