281
I'm surprised you didnt "throw it into the trash" like you and "everyone you know" does with all their other sub-perfect radios.
Anybody now someone in Lake county IL who can program gmrs radio
OffRoaderX replied to WRXB237's question in Technical Discussion
I bet you don't make many friends in real-life either, do you? -
"Some people" love to spend other people's money and "some people" are incapable of understanding the difference between some guy putting up a hobby radio antenna and a professional-radio station antenna. LMR400 will work just fine - it is not perfect, but the perfection-per-dollar ratio is plenty high enough for regular people.
Your pizza pan will work just fine.
I TRIED to warn you! *Their.. .and.. Do you seriously think anyone came here to find out what you would do?
OVERLORDS, not gods...
You forgot to say that everyone you know that bought one has returned them or thrown them into the trash..
New Baofeng GM-15Pro Incorrect TX from the factory
OffRoaderX replied to WRPG517's topic in General Discussion
NOOO! Get the UV-5G PLUS ! Its WAY BETTER. -
Maybe i'm missing it in your screenshots - is the offset correctly set at +5Mhz? If the offset is correct but its still calculating it wrong/you can't manually fix it, then box that junk up and send it back to Amazon and get your money back - you've already wasted more time on it than its worth. -
Generally, no, especially if the tones are posted in the listing. OTOH, it does not hurt to request access... OTOOH, you could just start using it and if the repeater-owner asks you to stop, then, stop.
Yes, i've seen this multiple times with a couple of different manufacturers. You can try a factory-reset, but in most cases that just puts it back the same way because its burned-in to the chips wrong. Manually changing the frequencies is probably going to be your ultimate fix. -
It Begins - Time to scan the band - Heard anything?
OffRoaderX replied to Lscott's topic in General Discussion
I do not understand how anyone with an IQ higher than 75 believes anything the media says anymore. -
What does "265 DPL" mean as a repeater Input Tone?
OffRoaderX replied to RogerSpendlove's topic in General Discussion
Thanks for trying, but this is incorrect. GMRS/the FCC rules fully support "i" or inverted DCS/DTC/DPL tones. In a case where N or "i" is not specified, it can always be assumed to be "N" (Normal). -
The reason the antenna is fixed on the Q10G is not because it has a GPS, but because it can SEND its GPS location in the form of a digital data transmission. So, per the rule you quoted, it must have a non-removable antenna - which means you cannot connect it to a giant antenna on your roof and blast the very annoying digital-signal-noise for miles in every direction. The 935G, like 99% of all other GMRS radios, does not/cannot send digital data transmissions, so it can have a removable antenna. There is also a rule buried in the FCCs rule book about certain transmission specifications must be met (ie the radio must have 'clean signals') in order to have a removable antenna, so a few (VERY few) low-end GMRS radios also have non-removable antennas because of this.
Are THEY on a repeater? Do you have that specific repeater programmed into the radio with the correct tones? Are you on the correct channel for that specific repeater?
1) Install CHIRP NEXT 2) Select GM-5RH D) Program Radio 5) Thank me
They lied to you... Are you using "CHIRP" or "CHIRP NEXT"? In CHIRP NEXT, select GM-5RH
I see this message when I have selected the wrong type of radio from the drop-down list. Is your radio a UV-5RH?
BAOFENG handhelds poor performance between vehicles?
OffRoaderX replied to IamConfusion's topic in General Discussion
You should stop showing everyone how ignorant/disconnected from reality you are because people are laughing. -
Have you tried comparing your FRS radios to the Baofengs, in the exact same cars with the exact same people at the exact same time, just to ensure you are actually getting a full apple-to-apple comparison? -
Maybe if you told us what kind of radio you have... and..maybe.. if you told us what steps you are taking.. and.. MAYBEEE.. if you told us what exactly is not working..or what happens.. or really, any detail at all.. .. then.. maybe.. just maybe.. someone could help.. But otherwise, welcome to the forum!
Why would you care what they say? Just tell them that its an iCom and they'll say it sounds great.
All you are going to get is people re-enforcing their opinion that whatever they bought is the best.. and, you will get one that will say "brand X is junk and everybody i know that ever had one returned it or threw it away"...You can ignore him because we are all pretty sure that he is rhee-tarh-ded.. Tell us what is important to you in a radio and you will likely get some better recommendations ..
