WyoJoe
    11
WyoJoe last won the day on April 24 2022
WyoJoe had the most liked content!
1 Follower
1522 profile views
WyoJoe's Achievements
  1. If you are seeing activity on your radio, but not receiving it, it is probably because you have a receive tone set - either CTCSS or DCS. If you remove the receive tone on that channel, you should hear the activity your radio is receiving. Keep in mind that it is possible that the activity could be simplex, and not coming from the repeater. In that case, the other user might be using a "privacy code" to keep others from hearing the conversation. In reality, it isn't private, and you should still be able to hear it if you turn the receive tone off on your radio.
  2. You are partly correct. I was actually thinking of the 701, which is also a handheld antenna. The 701 is the short (~8") handheld antenna, while the 771 is the long (~15") handheld antenna. I think the zero in the 770 threw me off, and made me think of the 701. You are correct that the 770g is indeed a mobile antenna. The crazy thing about it is I have one (a 770g), but made this mistake anyway. I stand corrected. Thank you wayoverthere.
  3. I believe the NL-770G is an antenna for a handheld radio. This type of antenna doesn't have a spring base, or any other type of base for that matter, because it's intended to be mounted to a handheld radio. For mobile use, you'll likely want a radio with an NMO or "UHF" mount, either of which would be much stronger than the SMA mount that is common to many handheld radios.
  4. I would say that having to pay for shipping or a restocking fee to get a refund on a defective product would also be a reason. Even having to pay shipping to get a defective product repaired would be sufficient reason to do so. In these cases, the purchaser was not provided with the product they paid for. It should not be incumbent upon them to pay anything for the repairs or to get the repairs made. It is incumbent upon the vendor to provide the (working) product that the customer paid for, and no customer should have to pay extra to get it. If the customer is not provided with the product they were promised at the agreed upon price (without added costs), then it is the responsibility of the vendor to make it right (at no added expense to the customer). If Bridgecom is making customers pay anything extra just to get the product they were promised in the first place, they need to be reported. The BBB would be a good place to start. Perhaps the District Attorney (or a Consumer Affairs Bureau) in their jurisdiction would be another place to report them. Filing a dispute with the credit card company is another way to begin to resolve this issue. Posting unsatisfactory reviews on Yelp or Google is a way to warn others, and it may get their attention to where they reach out to resolve the matter. Finally, and especially if unable to resolve the matter in a satisfactory way, posting on forums such as this is helpful for others that may be considering doing business with that company. I'm sorry to hear that there are companies out there that would engage in such wormy business tactics, but I know they exist. Unfortunately, it's a sad reality.
  5. To be even more specific, the plus should be specified in the "Duplex" column and the 5.000000 should be in the "Offset" column as shown here on channels 23-30:
  6. WyoJoe
    New to gmrs
    It may sound like a silly question, but do you know that the repeater is still active? It is not uncommon to see a listing for a repeater that is either not there, or is programmed differently than stated. Are you able to hear other users on the repeater?
  7. This can be determined by looking at the offset in Chirp. The offset needs to be set to "+" (plus). If it's "-" (minus), or (None), then it isn't programmed properly.
  8. I suppose then, that the AT-779UV is waaaaay better!
  9. My radio actually does weird things like that too. I tell it to display the channel name, but it displays the frequency. It doesn't seem to "take" until the second time I change the setting. I've found that I have to make the change from the front panel twice, too, because whatever I do in the software doesn't work correctly when writing to the radio. Basically, the only place it's been an issue is with the second VFO. I typically use that VFO to monitor a local ham repeater, so if I forget to reset it after powering down the radio, the only thing that happens is that I don't get to hear that repeater.
  10. In both cases, it depends on the obstacles in the way. Over a small hill may not pose much of a problem, but a big hill or mountain will almost certainly pose a problem (unless you can go around it instead of over it). The same is generally true for "around the bend." If that bend involves a hill or mountain, you would likely be okay to a point, then it would drop out completely. The only way to really know if it's going to work for you is to try it.
  11. I second this recommendation based on my own experience with this radio. I believe it will do everything the OP wanted in an HT. I would assume the KG935G would be similar, but I have no experience with it.
  12. I'm not exactly a rookie, but I read it anyway, and I have a solution to offer you. I assume by "channel B" you are referring to the second VFO, shown on the lower half of the radio's display. The easiest way to set this to your liking, is to make it the main VFO by pressing the "MAIN" button. You can then configure it to your liking. Then all you have to do is press "MAIN" again to set the other (first) VFO as the main.
  13. The UV-5R fits the bill, except it's not type certified for GMRS or FRS use, and it doesn't offer USB charging. There is another model that is type accepted, and that's the UV-5G/UV-5X GMRS radio. It looks nearly identical and has the same form factor. As you might have already figured, there are two different names for this model: UV-5G and UV-5X GMRS. Unfortunately, there is also another model called UV-5X that is not a GMRS radio, and it has a different form factor. If you stick to the GMRS model that looks like a UV-5R, you'd be fine. Anyway, these radios cost about $60/pair, and offer the low cost and small form factor desired by the OP. They do require charging cradles, but once charged, they last quite a long time on the included battery. There are also spare battery options available, including high capacity batteries for even longer run time. In addition, there are multiple antenna options available should you decide to upgrade, but beware that these radios require an SMA male antenna as opposed to the UV-5R's SMA female antenna. These radios also offer the option of Chirp programmability in case that's needed or desired. The Tidradio TD-H5 (also sold as the Radioddity GM-30 and Pofung P15UV) offers similar functionality, but also offers USB-C charging. It is a little larger than the UV-5 series, at about 1/2" longer, and perhaps up to 1/8" thicker. Overall, it's not a much larger radio, but it feels a little bigger. As of now, it is not Chrip programmable, so to program it requires use of the front panel (for some functions) or the factory software. The G11S (aka Pofung P11UV or Retevis RB27) may be another good option, although I haven't ever used or even seen one. In a quick search, I was unable to find the actual radio dimensions, so I can't compare the form factor. The simplicity of the radio may be better for kids, though, since it doesn't have the full front panel. Something else to keep in mind is that the "bubble pack" radios from Midland and others are not compatible with repeater use. While this may not be a consideration at this time, you may wish to use a repeater in the future to increase your coverage area. The UV-5 series, TD-H5, and G11S radios are all capable of working with a repeater. This is just something to consider for the future. Any of the radios mentioned would be fine for the intended purpose. I'm not a fan of the bubble pack radios because their battery systems aren't very good, and they don't offer the same functionality of other similarly priced GMRS radios like the UV-5G/UV-5X GMRS, TD-H5, or G11S.
  14. Is it possible that what you heard wasn't the repeater, but rather simplex traffic on the same frequency? That is one reason why you might not hear a tail.
  15. This kind of reminds me of the grapevine in the movie Johnny Dangerously: In all seriousness, though, I think this type of communication would be better handled on ham radio, as you could get much longer "hops" than with GMRS.
