466
Super Cheap Chinese DMR Radios, Experience?
SteveShannon replied to Lscott's topic in Equipment Reviews
Thanks! That helps. He and I are always looking for something that would be easier for him to use. -
More like 80% in my experience.
Ive been helping a blind, partially deaf, ham by programming his DMR radio so he can use it. It’s an Alinco DJ-MD5, which has room two thousand channels. Unfortunately, it has no voice prompts and very few audible cues. However, channels can be selected by entering a four digit channel number. So the method we came up with is to duplicate the channel list for every repeater, but minimize the number of zones because zones cannot be randomly selected from the front panel.. So, for instance, the channels for each individual repeater all start with the first two digits, such as “10” and all of the channels for all of the Brandmeister linked repeaters are the same last two digits. So, Brandmeister talkgroup #93 is channel 1093 for one repeater, 1193 for another, and so on up through whatever the practical limit is (not to exceed 9993). In that way my friend only has to learn the 20 or 30 different repeater digit pairs and up to 99 channel numbers. But that’s harder than it needs to be because of the inability of the manufacturer to imagine how their interface affects a blind person. Ideally a person could select a repeater randomly by entering its unique number and then select a Brandmeister talkgroup randomly by entering its number. So, after that long explanation, how does this displayless DMR radio allow a user to select channels? How does a person know which channel they’re on? -
Welcome, James! I hope you enjoy it here.
coax Diameter recommendations for new Base setup
SteveShannon replied to Stik's question in Technical Discussion
Here’s a cable loss attenuation chart. M&P 10 mm cable is very close in attentuation to LMR400 (which is also 0.400” diameter). https://www.w4rp.com/ref/coax.html Here’s another: https://www.universal-radio.com/catalog/cable/coaxperf.html I use the M&P 10 mm cable. It’s pretty good. But when I need to make a sharp bend, or if I couldn’t physically fit the diameter, I would get a short jumper of the best smaller diameter cable I could find, something from M&P or Times Microwave, not because of the cable, but because adding additional connectors can quickly add to loss. Better quality cables have better connectors. Never believe that all connectors are the same. Unfortunately,mprice isn’t the only predictor. I really like the M&P EVOlution connectors. I also like the old school silver plated Amphenol connectors. -
Winning!
The M&P is 10 mm which is 0.400. You can certainly find smaller diameters. There are lots out there but what you should be looking at is how much loss you can withstand. Smaller diameter cables have higher losses. So, can you shorten the run? Can you get by with a short piece of M&P 7mm Ultraflex but 10 mm everywhere else? Or can you get by losing half of your signal to losses in the cable? Unfortunately there are tradeoffs. -
I don’t believe amplifiers are prohibited for GMRS, but good luck finding one that’s part 95e certified.
The KG-1000G plus from Wouxun is very popular with those who have purchased it. Some consider it the best mobile radio specifically built for GMRS. It is certified for GMRS and transmits on GMRS only. But it will also receive a wide array of frequencies between 50 MHz and 985 MHz (not completely inclusive), including 108-179 MHz: https://www.buytwowayradios.com/wouxun-kg-1000g-plus.html You might want an antenna switch as you can switch between a good GMRS antenna and something else for the other bands you want to listen to.
On Monday, Wednesday, and Friday I try to join in on a 40 meter net. I usually run at 50 watts on digital modes but I usually turn my radio up to 99 watts output for the net. This past Friday I forgot. I checked in and the net control said I was easy to copy. Another person said I sounded a little weak compared to usual. So I checked my power and discovered that I was running at 10 watts. I had been playing with low power and had forgotten I cranked it down. Certainly, power makes a difference, but far less than people think. Nobody will ever hear the difference between 45 watts and 50 if there are no other changes.
It might be, but honestly it’s hard to generalize. Gain simply means that the power delivered by the radio is more focused in certain directions. If you know where you want to direct your signal that can help, but if you need your signal to be received by a station that is moving around, or much higher or lower in elevation, a low gain antenna can be better.
Several of us also have and enjoy the Radioddity db20g.
Maybe the problem is the people you’re trying to talk to. The Anytone isn’t a bad radio.
Poor recieve quality in new mobile rig
SteveShannon replied to WSAB905's question in Technical Discussion
Yes, a spring mounted antenna can sometimes result in choppiness. But picket fencing like Gil mentioned is very common even if an antenna is not spring mounted. -
Is it while you’re moving or parked that it’s choppy? -
What is the best commercial radio for GMRS use?
SteveShannon replied to TheNevilleKid's topic in General Discussion
@LScott is a Kenwood aficionado. I think he likes the TK-3170 (corrected). -
Most modern radios have a green or blue light that illuminates while a transmission is being received and turns red when you hit the PTT. But I don’t mind a Roger beep. I can completely ignore it.
Adding additional Repeater channel
SteveShannon replied to Merky1761's question in Technical Discussion
There are only eight repeater channels and they are pre-programmed into GMRS radios. A repeater channel in this case consists of a transmit frequency (on which your radio transmits to the repeater) and a receive frequency that is 5 MHz lower. If you create additional repeater channels they will use those same frequencies, differing only in tones. If your radio doesn’t automatically do an offset then you would have to program one. -
Did you read paragraph where they mentioned rejecting comments suggesting TDMA digital modes for GMRS? It’s pretty clear.
There’s a lot to unpack isn’t there?
For the current regulations for GMRS use this government site: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95#subpart-E
One thing the government is good at is paperwork.
And that's cited as the reasoning in the FCC Docket where all these decisions were documented: https://docs.fcc.gov/public/attachments/DOC-344617A1.pdf The FCC was concerned that a user would increase the power on the interstitial channels to exceed the 0.5 watt limit which could interfere with repeater operations:
8 Pin Straight Wire Mic Extension Cable
SteveShannon replied to WRZX444's question in Technical Discussion
DIN or Mini DIN? Here’s a mini DIN extender: KENTEK 6 Feet FT Mini DIN8 Extension Cable Cord Connector 28 AWG Molded Serial RS-232 MDIN 8 Pin Male to Female M/F for Peripheral Device https://a.co/d/c339le0
