464
Welcome! I hope you enjoy it!
Try menu #19, sub channel display
Hearing digital data sounds on GMRS8
SteveShannon replied to rockwithrick's topic in General Discussion
Are those areas where they “shouldn’t be using it” frequencies that have already identified for use somehow, such as the National calling frequency 146.520, or do they violate the area band plan? If not, a person with a digital radio (Fusion, DMR, or D*Star) has just as much right to use the frequency as anyone else. -
Input Tone? Output Tone? Am confused.
SteveShannon replied to ClockworkComic's topic in General Discussion
YES, assuming the repeater uses DCS, the “input tone” for the repeater is T-DCS on your radio, the tone that you must transmit. For the receive side you must either program the right receive tone or code OR tell your radio to not require a tone or code. That can be helpful when first starting. In that case your radio reproduces everything received on that frequency. -
Questions about suggested antenna
SteveShannon replied to WRJC636's question in Technical Discussion
You referred to it as an antenna, but the rest of your question seems to indicate it might be a tower. I’ll answer it as if it is an antenna. My answer would be different for a tower. A picture of the antenna might help, but the things that come to mind first are as follows: First I would put an antenna analyzer on it to see if it’s resonant anywhere close to the GMRS range of frequencies. Channels 2-13 were VHF (30-300 MHz), not UHF (300-3000 MHz). The UHF channels may have been covered by antenna also, but most TV antennas were targeted at VHF. Second, TV antennas were designed to be 75 ohm. Most two way radio antennas are 50 ohm. That’s not a bad problem, but may require some ingenuity. Third, the structure of this antenna might be usable as a tower to raise a GMRS antenna. That might be a useful thing! Good luck! -
"Travel" channels....why all the arguing??
SteveShannon replied to WRXH357's topic in General Discussion
There’s no GMRS repeater here. For 2 meter 146.940, 100 Hz tone, -0.600 MHz offset (146.340 xmit) is probably the most monitored channel. It can be reached beginning at about Dillon. Drive safely. -
That’s what I did.
As a condition of buying this tower the guy insisted that I take a Mosley TA-33 antenna, no extra charge. Unfortunately, it exceeds the boom length that Rohn specifies for this tower, which is 10 feet as you said. I haven’t decided on anything else yet. I know I will probably also use it to support a wire antenna and possibly some side arms with VHF and UHF vertical antennas.
Yeah, but once I looked at it I knew I was going to buy it. The galvanizing and the tower is all in good shape and it was $400. I probably would never buy a new tower of the same model because they sell for several thousand dollars.
Those are good ideas. I agree about the base. My original plan when I bought this was to buy the base, dig the necessary hole, and pour the concrete. It was only after looking at all the boulders that are much larger than the block of concrete that I started pondering attaching directly to one. I like the mat foundation as well. That’s sort of what I was wondering if I could do. Rohn no longer makes this particular tower but another company took over manufacturing it, including all of the various pieces. They sell the bases and they also sell the tower sections, so if I wanted to purchase a new #7 section and #8 section to build a 64 foot tower I could. I think I can call them and ask questions, too. I might try that.
The more I look into this the better I understand (yes, it would have been better to understand all of this before buying my first tower, but that’s just how I’m wired, I guess. ) The way they built this series of towers was with a series of tapered eight foot sections numbered #1 through #8. #1 is the smallest, measuring 7 3/4”. Each section is about 2 inches wider than the one above it. Depending on which series of sections you bought, you could assemble them as a tower from 32 foot to 64 foot. That means you could assemble six of the eight foot sections in three different ways to form a 48 foot tower. The strength of the tower depends on whether you use the #1, #2, or #3 section as the top piece: Sections 1, 2, 3, 4, 5, and 6 could be assembled as a BX48. That’s the lightest 48 foot tower in the line. It can handle 120 pounds in thrust and a six square foot area antenna. But, if you use sections 2 through 7, with #2 as the top and the #7 as the bottom, you end up with a slightly larger (in girth) tower that’s 9+inches across at the top, the DBX 48. That’s capable of handling 240 pounds in thrust and 12 square feet. So, if you use the #3 section as the top and the #8 at the bottom, you end up with a tower that’s greater than 11 inches at the top and capable of handling 360 pounds of thrust (dead weight) and an area of 18 square feet. Another way to look at this is that I could assemble the sections to form an HDBX32, a DBx40, or a BX48. And it’s also important to realize that even though each section is eight feet long, because you lose four inches of overlap at each joint, the actual length of a BX48 assembled is about 46 feet. But however you assemble the pieces, you assemble them to a four foot long bottom section which is embedded into a block of reinforced concrete. The bottom section, whether it’s a #6 (in my case) or #7 or #8, is assembled to the base piece before the concrete is poured. It must be kept plumb so you have a vertical tower. Finally, the reason I replied to this particular previous post: my tower only has two bolt holes for each of the bottoms of the three legs. That’s all that the #6 section has when attaching to the base. Only the #7 and #8 sections have three bolt holes at the bottom of each leg where they bolt to the base. Based on the little bit of rust inside it, that third hole that is present on one of the legs was drilled after the galvanizing process. I will apply some kind of cold galvanizing treatment to it.
In researching this better I’ve discovered it’s a BX48, not the heavier duty HDBX48. That doesn’t bother me. It means that I am more limited in the antenna I mount. The HDBX48 was rated for an antenna that weighs 120 lbs and has an area of 6 square feet. The HDBX would have handled 360 lbs and 18 square feet.
I don't scan GMRS. I only use GMRS to talk to friends when we are engaged in some activity. We already have prearranged channels and tones. If I wanted to reach out I would use my ham radios and call "CQ".
Any Tips For Someone Thinking of Getting A H.A.M. License?
SteveShannon replied to OffRoaderX's topic in Amateur Radio (Ham)
Until fairly recently, one legend about the origin of the word "ham" as related to amateur radio operators, did admit the possibility of an acronym, made up of the first initials of three amateur operators who had one of the first call signs. It has since been debunked, but honestly, the folks who get upset over things like this should just take a deep breath. Another suggests that the letters came from Hertz, Armstrong, and Marconi. There is an entire article about the etymology of "ham" in Wikipedia https://en.wikipedia.org/wiki/Etymology_of_ham_radio#:~:text="A little station called HAM",-This widely circulated&text=An amateur station that Hyman,represent all of amateur radio. An amateur station that Hyman supposedly shared with Bob Almy and Reggie Murray, which was said to be using the self-assigned call sign HAM (short for Hyman-Almy-Murray), thus came to represent all of amateur radio. -
Yeah, they sell a base that gets embedded into the concrete and provides three stubs to bolt the bottom section to. Only one of the bottom section legs had three bolts. The other two were two bolts each. I don’t know if that’s because there was a different design previously or this wasn’t truly the bottom section but it’s beefy.
This is pretty small. It’s 24’x32’ with a loft but it does have a basement. And a big deck.
So in your original question you asked about placing a repeater into the “repeater section.” My answer was based on the preprogrammed channels: 1-22 simplex and 23-30 repeater. With Chirp, make the changes wherever they make sense to you and where they are allowed by Chirp.
It’s easiest to put it in the repeater (channels 23-30) section. All you have to do is select the correct channel and set the tone to match the repeater. The offset is already programmed in. If you try to program it in the channels from 1-22, there’s no offset. Those channels are preconfigured for simplex, which is when both radios transmit and receive on the same channel. If you have numerous repeaters you want to program you will have to program them into DIY (do it yourself) channels that typically exist above channel 30. You will have to enter the frequencies, using the correct offset, and the tones. It’s not difficult, as long as your radio supports that. (I’m pretty sure the 935 does. It’s highly recommended by folks who have one.)
You’re right, the tower isn’t designed to be guyed. In fact, the primary reason I got this one instead of a Rohn R25 is the free-standing design. I would rather not guy it if possible. I would dig the hole and buy five yards of concrete first. But, not everything always works out the way I want. So, if it needs guys I will just have to figure it out. The soil consists of a lot of decomposed granite. Based on the guys used for utility structures and cell towers in the area it seems to work well.
I never used either so I appreciate hearing your experiences.
I’ll attach a picture of the cabin. I have a Makita SDS Plus hammer drill already. Corded. I’ve been wistfully looking at an SDS Max lately, cordless. The anchors were what I was thinking about. I’m not sure if I should drill the boulder and epoxy in a bunch of rebar and then pour a thick slab on top, or if sufficiently long anchors and flanges bolted to the legs of the bottom section would be enough. Here’s a picture of the boulder I have in sight. It’s in shadow in the picture but the exposed face is probably about six feet tall.
Yeah, but short ones to avoid hurting the boulder.
