WRYZ926 Posted June 1 Report Posted June 1 32 minutes ago, WRTC928 said: Your information may be out of date. There are active 70cm amateur repeaters in both Midwest City and Del City Oklahoma, both of which are adjacent to Tinker Air Force Base. My information may be outdated. Though last time I checked there are not any 70cm repeaters allowed around certain air bases in California. WRTC928 1 Quote
WRTC928 Posted June 1 Report Posted June 1 7 hours ago, WRYZ926 said: My information may be outdated. Though last time I checked there are not any 70cm repeaters allowed around certain air bases in California. We may both be right; it may have to do with the type of operations they conduct at that base. Just an educated guess, but I spent 14 years in the Air Force. Quote
WSDD519 Posted July 11 Report Posted July 11 On 5/16/2025 at 11:10 AM, 73blazer said: My parents still use a 49MHz cordless phone system in their house. I never looked at what type is was before until just a couple months ago when we switched them from AT&T's rape job $110/mo landline to a $6/mo VOIP service. My dad just got some new batteries for the handsets last year! I used to have fun eavesdropping on the neighbors cordless phones. Some interesting conversations Quote
WRUE951 Posted July 12 Report Posted July 12 13 hours ago, WSDD519 said: I used to have fun eavesdropping on the neighbors cordless phones. Some interesting conversations Yup, use to do that all the time, even analog cell freqs using field strength metters Quote
Ian Posted July 16 Report Posted July 16 I also feel like MURS and FRS ought to be merged, since their rules are so close to identical. This would mean removable antennas on FRS radios, which… should be mostly a nothingburger with a few "duckheads" running amplifiers to create high-powered jamming equipment but… you can already do that today, it doesn't happen, so we shouldn't be forced onto fixed antennas because stupid people want us to not have nice things. Seriously, it's a non-thing. Time to drop it. Quote
Ian Posted July 16 Report Posted July 16 On 5/3/2025 at 9:19 PM, OffRoaderX said: So you'd need two different radios, or one radio with two different antennas to make use of these and the existing GMRS channels? Does not seem very user-friendly... If they are unused, throw 'em to the H.A.M.s.. they'll use it.. they'll use anything. This is smack in the middle of the "magic band", which is especially suitable for meteor-bounce communication and other really weird shit. We'll do fun propagation science to it, even if we need to buy a GMRS license to do it. On 5/3/2025 at 10:37 PM, Radioguy7268 said: Before you get too excited about the long range possibilities of a low band repeater, talk to anyone who has actually built one, or tried to use one. Beyond the problems of skip, near-far, and antennas that can double as fishing poles, you also find out that you need to have one antenna tuned for the transmit frequency, and another tuned for receive. Typical bandpass cavities are 5 ft. tall, you will need enough space for at least 6, and you better keep them in a climate controlled environment, unless you want to keep a separate set tuned for each season. You also need to know that a typical low-band mobile antenna is only good for about a 500 KHz spread while your proposed pair is 3 MHz apart. Noise is a huge problem, terrible at times. It's only gotten worse in the last 25 years. There's a reason why Commercial (paying customer) Low-band has become a wasteland. Actually, there's many reasons beyond the ones I've mentioned. Most manufacturers have abandoned the band. That sounds just about fucking ideal for linking repeater sites over the air. How much digital data can we squish into the CTCSS frequencies? Something like AllStar without internet interconnections should be rules-compliant. Quote
Lscott Posted July 16 Report Posted July 16 2 hours ago, Ian said: also feel like MURS and FRS ought to be merged, since their rules are so close to identical. This would mean removable antennas on FRS radios, Maybe not a bad idea. One could pick the frequency band that works best for the local conditions without being forced to carry two radios. The removable antenna bit could be a hangup issue however with the FCC. Otherwise no real technical difficulty. Hams had dual band HT's radios for decades. People have been doing this on the sly for a long while ever since dual band radios were around with the MARS/CAP mod's, or the opened CCR's like the UV-5R. Quote
WRYZ926 Posted July 16 Report Posted July 16 2 hours ago, Ian said: This is smack in the middle of the "magic band", which is especially suitable for meteor-bounce communication and other really weird shit. Actually it is right below the 6m band which is 50.0 MHz to 54.0 MHz. The US Military still uses 30 MHz to 70 MHz. Some source state 30 MHz to 75 MHz or 88 MHz. This includes the frequency hopping SINCGARS radio system. Yes 46 MHz or 49 MHz could be used for public two way coms but that portion of the VHF spectrum can be fickle hence calling the 6m band the magic band as it is either open or closed and you never know which it is. And openings don't stay open very long. Quote
WRYZ926 Posted July 16 Report Posted July 16 2 minutes ago, Lscott said: The removable antenna bit could be a hangup issue however with the FCC. Otherwise no real technical difficulty. Hams had dual band HT's radios for decades. People have been doing this on the sly for a long while ever since dual band radios were around with the MARS/CAP mod's, or the opened CCR's like the UV-5R. It would be easy to make a dual band antenna that covers MURS and FRS/GMRS. It's done all of the time for 2m and 70cm dual band radios. Tri band and quad band hand held radios generally require two antennas: one for 2m/70cm and another for 1.25m and 6m. The cat's out of the bag when it comes to actually separating FRS from GMRS. I doubt that will ever happen. But I could be wrong on that. SteveShannon and Lscott 2 Quote
Lscott Posted July 16 Report Posted July 16 3 minutes ago, WRYZ926 said: It would be easy to make a dual band antenna that covers MURS and FRS/GMRS. It's done all of the time for 2m and 70cm dual band radios. Both MURS and FRS lie just above the Ham 2M and 70cm bands. The ratio between the mid point of the 2M band frequency range to the mid point of the MURS band is 0.953. The ratio between the mid point of the 70cm band frequency range to the mid point of the FRS band is 0.946. It's an almost identical ratio so a simple reduction on the element length would likely work just fine for both to modify a Ham dual band rubber duck antenna. WRYZ926, WRTC928 and SteveShannon 3 Quote
WRYZ926 Posted July 16 Report Posted July 16 Some dual band 2m/70cm antennas already work for MURS/FRS with acceptable SWR of 2.0 or less. And you are correct that it would not take much to dual band MURS/FRS antennas with just small changes to the element lengths. Lscott and TNFrank 2 Quote
WRTC928 Posted July 21 Report Posted July 21 A dual-band FRS/MURS radio would be extremely useful. FCC would have to change the rules to allow a detachable antenna on FRS. TBH, I don't think it's even on their priority list, so it's not going to happen, but it would be really handy. BTW, what's the reason for requiring a fixed antenna on FRS? I understand the restrictions on bandwidth and power, but not the reason for the fixed antenna. Quote
SteveShannon Posted July 21 Report Posted July 21 1 hour ago, WRTC928 said: A dual-band FRS/MURS radio would be extremely useful. FCC would have to change the rules to allow a detachable antenna on FRS. TBH, I don't think it's even on their priority list, so it's not going to happen, but it would be really handy. BTW, what's the reason for requiring a fixed antenna on FRS? I understand the restrictions on bandwidth and power, but not the reason for the fixed antenna. To limit range. FRS is intended to be used for short distances using handheld radios and no licenses. As soon as a high gain antenna is installed the range for two watts is basically the same as GMRS radios. WRXB215, GreggInFL, Lscott and 2 others 5 Quote
WRTC928 Posted July 22 Report Posted July 22 9 hours ago, SteveShannon said: To limit range. FRS is intended to be used for short distances using handheld radios and no licenses. As soon as a high gain antenna is installed the range for two watts is basically the same as GMRS radios. Okay, that's valid. SteveShannon 1 Quote
wqnd300 Posted August 22 Report Posted August 22 For those that welcome this just keep in mind that you're cheap Baofeng won't work for that. I tried searching the ol ebay for any used radios and found a few that are not cheap. And now you would need a separate antenna. Sent from my SM-S938U using Tapatalk Quote
WRUE951 Posted August 22 Report Posted August 22 48 minutes ago, wqnd300 said: For those that welcome this just keep in mind that you're cheap Baofeng won't work for that. I tried searching the ol ebay for any used radios and found a few that are not cheap. And now you would need a separate antenna. Sent from my SM-S938U using Tapatalk i've noticed that too.. A year ago you could buy retired used Commercial radio stuff on Ebay cheap cheap.. I was lucky and got a few things including a couple high end Hytera Repeaters, one of them brand new. Now, the used commercial stuff is going for high dollar premiums and the junk left over from then.. Quote
TNFrank Posted August 23 Report Posted August 23 The main issue I see is finding a 6M antenna for an HT. There's plenty of HT size 27MHz CB antennas to be had but nothing for 6M/50MHz that I can find. Quote
SteveShannon Posted August 23 Report Posted August 23 1 hour ago, TNFrank said: The main issue I see is finding a 6M antenna for an HT. There's plenty of HT size 27MHz CB antennas to be had but nothing for 6M/50MHz that I can find. The Diamond SRH999 and SRH940 both include 6 meters. Quote
TNFrank Posted August 23 Report Posted August 23 1 hour ago, SteveShannon said: The Diamond SRH999 and SRH940 both include 6 meters. I'll have to look those 2 up, thanks. SteveShannon 1 Quote
WRXB215 Posted August 23 Report Posted August 23 Someone should make one of these for 6m. TNFrank 1 Quote
SteveShannon Posted August 23 Report Posted August 23 2 minutes ago, WRXB215 said: Someone should make one of these for 6m. Just pull it out to the length needed for 6 m. Use an analyzer to tune it, mark it, and return to that length when you want. WRTC928, marcspaz, TNFrank and 1 other 3 1 Quote
marcspaz Posted August 24 Report Posted August 24 18 hours ago, SteveShannon said: Just pull it out to the length needed for 6 m. Use an analyzer to tune it, mark it, and return to that length when you want. Same concept as a screwdriver antenna. SteveShannon and AdmiralCochrane 2 Quote
