WSHH887 Posted May 21 Report Posted May 21 Depending on the alloy stainless steel can be highly magnetic or not. After being burnt, literally, by Chinese stainless steel that wasn't what it said it was my first quick check was a magnet. The alloy we used in chemical piping should not have been magnetic. After that incident, the piping came from an ISO manufacturer, I specified US or European manufacturer only. All Chinese metal is mystery metal as far as I'm concerned. Raybestos 1 Quote
WRTC928 Posted May 21 Author Report Posted May 21 My radials are on the way from Comet. I hung it from a tree and ran a few tests using my improvised "mystery metal" radials. I think I'm going to like this antenna. I had a lot of work to do to get my deck ready to support the mast, but I think I have it ready now. I can raise the antenna as soon as the radials get here. Well, when I also have someone to help me. I can raise it with a rope using a tree branch as a pully, but I need someone to guide it and secure the clamps while I hold it up. SteveShannon 1 Quote
WRUE951 Posted May 22 Report Posted May 22 On 5/19/2025 at 12:47 PM, WRTC928 said: TBH, I'm not sure. It has that dull sheen like aluminum, but that could just be the finish. I don't have a magnet handy, but a lot of stainless steel isn't very magnetic anyway. I think the whole "dissimilar metals" things is a bit overblown anyway. Cars and motorcycles bolt aluminum to steel all the time. If it were a part that carries a current, it might be different, but I've seen lots of aluminum wire secured to an outlet with steel screws for decades without any issue, so maybe not even then. Cars and motorcycles do use dissimilar metals for fasteners and they also advise use of anti-seize. Also, dissimilar metals for fastening use does not promote the corrasion effect as much as it does when electrical current flows through the dissimilar metal. Quote
WRTC928 Posted May 22 Author Report Posted May 22 4 minutes ago, WRUE951 said: Cars and motorcycles do use dissimilar metals for fasteners and they also advise use of anti-seize. Also, dissimilar metals for fastening use does not promote the corrasion effect as much as it does when electrical current flows through the dissimilar metal. As I said, I've seen houses wired with aluminum wire and secured with steel screws without any significant corrosion. Granted, they aren't exposed to the weather, but they carry a lot of current. I'm not saying it doesn't happen and I'm not going to start randomly screwing dissimilar bits of metal together, but if Comet uses stainless steel radials screwed into an aluminum base, they must not be too concerned. Quote
SteveShannon Posted May 22 Report Posted May 22 2 hours ago, WRTC928 said: As I said, I've seen houses wired with aluminum wire and secured with steel screws without any significant corrosion. Granted, they aren't exposed to the weather, but they carry a lot of current. I'm not saying it doesn't happen and I'm not going to start randomly screwing dissimilar bits of metal together, but if Comet uses stainless steel radials screwed into an aluminum base, they must not be too concerned. Once upon a time aluminum was used for house wiring but there were fires in some places. It’s a little trickier to work with aluminum because aluminum oxidizes very quickly and aluminum oxide is a pretty good insulator. We still use aluminum for utility conductors but with quite a bit of extra training to do it right when joining copper and aluminum. Gil @WRUU653 would be much more likely to understand the process than me. But that’s at DC and and 60 hz. RF travels through molecular thin oxide layers pretty well and I agree with you that stainless steel and aluminum don’t appear to bother Comet. WRUE951 1 Quote
WRUE951 Posted May 22 Report Posted May 22 3 hours ago, WRTC928 said: As I said, I've seen houses wired with aluminum wire and secured with steel screws without any significant corrosion. Granted, they aren't exposed to the weather, but they carry a lot of current. I'm not saying it doesn't happen and I'm not going to start randomly screwing dissimilar bits of metal together, but if Comet uses stainless steel radials screwed into an aluminum base, they must not be too concerned. Yea, i have as well.. Water and moisture surelty contribute to the corrosion factor. About 10 years ago i restored a 1970 Yamaha 250 Enduro Motorcycle. It sat in my dads back yard for over 30 years. Many of the steel bolt used for the aluminum casing were seized with some destroying the threaded casing. The bolts that were steel to steel cam out with ease. WRTC928 1 Quote
WRUE951 Posted May 22 Report Posted May 22 33 minutes ago, SteveShannon said: Once upon a time aluminum was used for house wiring but there were fires in some places. It’s a little trickier to work with aluminum because aluminum oxidizes very quickly and aluminum oxide is a pretty good insulator. We still use aluminum for utility conductors but with quite a bit of extra training to do it right when joining copper and aluminum. Gil @WRUU653 would be much more likely to understand the process than me. But that’s at DC and and 60 hz. RF travels through molecular thin oxide layers pretty well and I agree with you that stainless steel and aluminum don’t appear to bother Comet. I just got currious about anti-seize and pulled mine out of the cabinet to read. It's a copper base antisize recommend for electrical connections. I wonder if Comet recommends a copper base anti-seize to enhance the electrical connection with their antennas? Quote
WRUU653 Posted May 22 Report Posted May 22 45 minutes ago, SteveShannon said: Once upon a time aluminum was used for house wiring but there were fires in some places. It’s a little trickier to work with aluminum because aluminum oxidizes very quickly and aluminum oxide is a pretty good insulator. We still use aluminum for utility conductors but with quite a bit of extra training to do it right when joining copper and aluminum. Gil @WRUU653 would be much more likely to understand the process than me. But that’s at DC and and 60 hz. RF travels through molecular thin oxide layers pretty well and I agree with you that stainless steel and aluminum don’t appear to bother Comet. Part of the problem with aluminum wiring in homes was an issue with dissimilar metals and how they expand and contract at different temperatures. Special outlets were used with aluminum screws but if the wrong outlet was used which typicaly had brass srews or copper wires joined with the aluminum and a joint compound (antioxidant, aka Noalox) wasn't used then arcing and oxidation would occur and it's all down hill once the arcing starts. Later people started using stab style connections on new outlets and these are a recipe for disaster. Larger feeders isn't an issue when wire is prepared properly and isn't as prone to outside movement like an outlet in a home that gets plugged into and out of constantly or your DIY people installing things incorrectly. Back in the day electricians would put noalox into wire nuts and use this for splicing. Then some manufacture saw this and made wire nuts with the compound pre installed and got UL listing and a patent. Damn why didn't I do that moment . More info than anyone wanted I'm sure. Anyway it does not hurt to put a thin layer of Noalox when connecting aluminum to another metal. You don't need a lot. WRTC928, SteveShannon and AdmiralCochrane 2 1 Quote
tcp2525 Posted May 23 Report Posted May 23 19 hours ago, WRUE951 said: I just got currious about anti-seize and pulled mine out of the cabinet to read. It's a copper base antisize recommend for electrical connections. I wonder if Comet recommends a copper base anti-seize to enhance the electrical connection with their antennas? No need for it. Just put the antenna together and stop overthinking the situation and enjoy 20+ years of trouble free use. Only thing you need to do with that antenna is to wrap some good quality electrical tape around the joint in the center of the radome. Quote
WRUE951 Posted May 23 Report Posted May 23 32 minutes ago, tcp2525 said: No need for it. Just put the antenna together and stop overthinking the situation and enjoy 20+ years of trouble free use. Only thing you need to do with that antenna is to wrap some good quality electrical tape around the joint in the center of the radome. https://perens.com/2024/05/14/radio-antennas-and-anti-seize-compound/ WRXB215 1 Quote
tcp2525 Posted May 23 Report Posted May 23 17 minutes ago, WRUE951 said: https://perens.com/2024/05/14/radio-antennas-and-anti-seize-compound/ Too much internet and not enough real world experience. One can put K-Y Jelly on their antenna and get the same results. I reconditioned my 18 element 2-meter beam that was on the tower for 30 years with no anti-seize or K-Y and all was good. I had to replace several broken elements and feedline. Antenna is as good as new and still being used. You gotta use whatever gives you peace of mind, even if it's a sugar pill. Quote
WRUE951 Posted May 23 Report Posted May 23 5 minutes ago, tcp2525 said: Too much internet and not enough real world experience. One can put K-Y Jelly on their antenna and get the same results. I reconditioned my 18 element 2-meter beam that was on the tower for 30 years with no anti-seize or K-Y and all was good. I had to replace several broken elements and feedline. Antenna is as good as new and still being used. You gotta use whatever gives you peace of mind, even if it's a sugar pill. if you read the article, you would see real world scenarios. KY Jelly is petroleum based and would liquify under heat. It may work as an anti-seize for a short period but would be useless over time. WRXB215 1 Quote
OffRoaderX Posted May 23 Report Posted May 23 Just now, WRUE951 said: KY Jelly is petroleum based and would liquify under heat. It may work as an anti-seize for a short period but would be useless over time. I can confirm that it works great for 45 seconds at a time.. Never tested it any longer than that. WRUE951, Raybestos and AdmiralCochrane 3 Quote
tcp2525 Posted May 23 Report Posted May 23 4 minutes ago, WRUE951 said: if you read the article, you would see real world scenarios. KY Jelly is petroleum based and would liquify under heat. It may work as an anti-seize for a short period but would be useless over time. I did read the article, that's why I responded the way I did. There's no benefit of using anti-seize on an antenna other than making the person putting the antenna together feel good. On the other hand, if it makes you feel good, buy the 16oz. can with the fancy brush. Quote
SteveShannon Posted May 23 Report Posted May 23 2 hours ago, WRUE951 said: if you read the article, you would see real world scenarios. KY Jelly is petroleum based and would liquify under heat. It may work as an anti-seize for a short period but would be useless over time. KY jelly is water based, not petroleum based. Quote
OffRoaderX Posted May 23 Report Posted May 23 1 hour ago, SteveShannon said: KY jelly is water based, not petroleum based. Can confirm.. the petroleum based brands taste horrible.. But KY does not have much taste at all and it's much easier to wash out of your hair than the petroleum kinds. Raybestos 1 Quote
WRUE951 Posted May 23 Report Posted May 23 2 hours ago, SteveShannon said: KY jelly is water based, not petroleum based. fI don' t don't know my 'Jelly's' too well.. But I'll stick with Blackberry.. SteveShannon 1 Quote
AdmiralCochrane Posted May 24 Report Posted May 24 I carried Noalox on my HVAC service van for decades. tcp2525, WRUU653 and SteveShannon 3 Quote
WRTC928 Posted May 24 Author Report Posted May 24 On 5/22/2025 at 3:01 PM, WRUE951 said: I just got currious about anti-seize and pulled mine out of the cabinet to read. It's a copper base antisize recommend for electrical connections. I wonder if Comet recommends a copper base anti-seize to enhance the electrical connection with their antennas? If they do, there's nothing about it in the instructions that came with the antenna. It seems like a good idea, though. SteveShannon, WRUE951 and WRXB215 3 Quote
tcp2525 Posted May 24 Report Posted May 24 7 hours ago, WRTC928 said: If they do, there's nothing about it in the instructions that came with the antenna. It seems like a good idea, though. I highly suggest a quick phone call to Comet, they are very friendly and will answer your question. My guess is use it if it makes you sleep better at night. WRTC928 and SteveShannon 2 Quote
WSHH887 Posted May 24 Report Posted May 24 My background is petroleum industry and water treatment. Always use anti seize. That one fastener you think you will never have to remove and decide to skip coating is the very one you will have to take apart. Anti Seize (the brand doesn't matter, they all work) is about the cheapest sanity insurance you can buy. And take it from experience, it will save lots of skin. Also, always repeat always make every electrical connection (even those in "water resistant" housings) as water tight as humanly possible. Long story short I grabbed an electrical conduit that had been out of service for a couple of years. Lit me up like nobodies business. Two lessons learned, never believe lockout/tagout tags, and never trust an electrician unless you verify it yourself. Water had gotten into the conduit. WRTC928, SteveShannon and WRXB215 3 Quote
WRTC928 Posted Sunday at 01:22 PM Author Report Posted Sunday at 01:22 PM 13 hours ago, WSHH887 said: Always use anti seize. When I was restoring a lot of old military firearms, I bought that stuff by the bucket. Removing the barrel from a 70 year old M1 rifle can be...interesting. Much cursing was involved. When I put the rifles back together, barrel threads and other metal-to-metal screws got some anti-seize. So, I'm right there with you on that. WRUE951 and SteveShannon 2 Quote
WRTC928 Posted Sunday at 01:35 PM Author Report Posted Sunday at 01:35 PM The radials arrived in the mail yesterday, so I'm ready to stand up the mast whenever I can wrangle some help. A couple of friends who are GMRS users have volunteered to help; we just need to find a day we're all available. My location isn't ideal for a repeater, but it's pretty good, and I'm not in a position to rent space on a tower. If my calculations are correct, 50' should get me over the hill to my southwest, which is the only major obstacle for a considerable distance. If I can get over the hill, I should be able to reach the family farm west of town. East and north will have excellent coverage, but my biggest goal is to reach the farm. SteveShannon 1 Quote
