Antenna mounting options for truck?
I have a 2006 F150 with super crew cab.  I recently bought a Midland MXT575 radio and am exploring different mount options.  If anyone has suggestions for mounting ideas, I'd appreciate any and all ideas!
14 answers to this question
Center of the cab roof is always going to be best.\
I don't know how thick the roof metal is on a 2006 F150. but the roof is pretty thin on my 2010 F150. A magnet mount does hold the antenna at highway speeds but it won't take much to knock the antenna off. I'm going to go with a permanent NMO mount as soon as I can find someone close to help with the install.
I’m running with a Midland NMO and the ghost antenna in the center of the roof.  But, I’m looking at trying a window mount on the rear window (which has may have some issues due to the tent and defrost wires).
If the roof top metal is that thin then consider some kind of backing plate on the bottom side to distribute the bending moment created by wind resistance on the antenna at highway speeds. No use in seeing the roof buckle around the mount if you can avoid it.
I have a sun roof on my CX-5 so even if I wanted to drill a hole, which I don't anyway, there is precious little room. That's why I had the optional roof rack rails installed when I purchased it. The mount attaches to that. Even at highway speeds the 60 inch tall antenna isn't going to bend that wide rail.
https://forums.mygmrs.com/gallery/image/473-close-up-of-mobile-mount/?context=new
Yup,,  Center of the cab and don't waste your money on those third brake light mounts.   I got one on a deal on Ebay and after about a year it cracked at the antenna mount.  Worthless hunk of $hit...
That is the plan if/when I get the roof drilled for a NMO mount. I do plan on adding a backing plate to the underside of the cab roof.  I would not want the roof to tear if I hit something with the antenna.
I don't want to put holes in the roof of my pickup. I found a bracket they attached to the rear of my bed. I posted a video of it another fellow did earlier. It works great.
I do have a metal bedcover and I think that helps. I have used both the Midland MTX26 and a ghost antenna. Interestingly, the ghost antenna might be slightly better.
You can buy NMO antennas and purchase a magnetic base with an NMO connector.  I do that, that way I can mount mine as high as possible to my SUV's.  However, you can also order custom mounts for your rig that fit to your front quarter panel frame rail.
yes you can, in fact you get get some pretty beefy strong NMO magentic mounts..
I have two mag-mounts. They are small but surprisingly strong. I've seen the "beefy" ones you mentioned and I can't imagine how strong those are.
i have a beefy mag mount for my 11 mtr antenna which has a pull handle and its still pretty tough to remove..  The Wilson 5000 never budges.
I have a 2023 F150 crew cab and the center rib of the cab runs down the middle so drilling in the center of the roof is not a good option.  I also just didn't want to drill a hole in my roof, at least right now (I did on my F250 for a 220/70 antenna and didn't have any problems).  The newer cabs are aluminum so I bought a stick on mounting plate and a mag mount antenna off Amazon.  Located it centered front to back and just off center left to right on the driver's side.   I'm not going to pretend it is the greatest or end-all setup but it works good enough for me.  I can hit the repeater (approx. 275' tall) at 35+ miles over flat terrain (haven't tried it any farther) with my cheapo DB-20.  Again, nothing special or earth shattering.  Easy to remove before going through the car wash.  It's not as slick as running it through the roof but I haven't found that I care that much.   Just an option, even if it's not the best.
