RogerSpendlove Posted Saturday at 01:31 PM Report Posted Saturday at 01:31 PM I'm still fairly new to radios and GMRS and trying to get my mind wrapped around the technical concepts. My intended use is for communications between multiple drivers transporting a group of young men to camping outings (we're a Trail Life USA troop). I'm contemplating getting a 20w mobile to install into my car (because, or course, I'm attracted to the possibility of farther range ). But most of the other dads would likely be using 5w handhelds in their vehicles. My question is: I, with my 20w would be able to transmit farther (in most conditions) than the 5w handhelds -- so does that mean that if we got separated a number of miles on the highway, they would be able to hear me from farther away, but that I would probably NOT be able to hear them calling back, due to their lower power? For transportation communications like this, would it be better for all of us to have the same power handhelds? Thanks for any help and insight you'all could give me. Quote
WRTC928 Posted Saturday at 01:41 PM Report Posted Saturday at 01:41 PM Probably, but not for the reason you think. The biggest factor is that the antenna of a mobile radio is outside the vehicle while the HT antennas are inside the vehicle -- essentially a Faraday cage. Transmission and reception will both be adversely impacted by being inside the vehicle. Second, a mobile radio antenna is usually a better antenna in general, because it doesn't have to be short enough to be easily carried. Third, a VHF or UHF radio signal is significantly impacted by obstacles -- mostly hills and buildings in the case you're describing. The rule of thumb is that in order to double the distance of the signal, you have to quadruple the power of the radio. All other things being equal, your radio should yield about twice the effective distance of the HTs, but all other things are not even close to equal in your case. Short answer -- yes, I would expect them to hear you further than you can hear them, but it has less to do with power than with other factors. You could learn a lot by simply doing the experiment. Try communication between your mobile and an HT under different conditions and see what you get. Quote
WRTC928 Posted Saturday at 01:47 PM Report Posted Saturday at 01:47 PM 14 minutes ago, RogerSpendlove said: For transportation communications like this, would it be better for all of us to have the same power handhelds? I don't think so. The probability of getting separated is about the same no matter what radios you have, but with the mobile, you at least have a chance of getting a message to them even if they can't effectively respond. One-way is better than no-way, IMO. amaff 1 Quote
nokones Posted Saturday at 01:52 PM Report Posted Saturday at 01:52 PM You might get a couple extra yards of farz out of the extra power, but I wouldn't bet on it. Quote
AdmiralCochrane Posted Saturday at 01:53 PM Report Posted Saturday at 01:53 PM If nothing else the 20w radio will sound louder. You will have the clear commanding voice. WRXB215 and SteveShannon 2 Quote
WRUE951 Posted Saturday at 02:43 PM Report Posted Saturday at 02:43 PM i can give you my experience while RV' ing with RV friends. Most of the time we travel in groups of 3 to 4 other RV's on the road. We all have GMRS radios and we all started out using HT's. After the first time together using HT's we discovered communicating with HT's pretty much sucked. We were lucky to reach each other when we got separated by as little as a mile. The low profile HT antenna and fact we all were pulling huge signal blocking clumps of fiberglass and steel was the problem. Once we all got mobile radios this problem pretty much went away. With the mobiles we can stay in touch easily as far as 20-25 miles apart and sometimes further, especially when we are hitting repeaters. Traveling through canyons is a bit of a problem even with a mobile but dependable within 2 miles. I will say one of they guys in our group 'was' using a Midland Ghost antenna, which worked pretty good for the most part but he was the first guy we lost in the canyons..... Early on i did adapt my HT to a Mobile antenna, which helped a little but no comparison even close to using a good 50W Mobile.. In my case i use a Hytera HM782 Quote
amaff Posted Saturday at 02:57 PM Report Posted Saturday at 02:57 PM 1 hour ago, RogerSpendlove said: My question is: I, with my 20w would be able to transmit farther (in most conditions) than the 5w handhelds -- so does that mean that if we got separated a number of miles on the highway, they would be able to hear me from farther away, but that I would probably NOT be able to hear them calling back, due to their lower power? For transportation communications like this, would it be better for all of us to have the same power handhelds? As has been said, you may get SOME additional punch through trees and what not at 20W over 5W, but the biggest thing is putting the antenna outside of the big metal box. The nice thing about it though is that with the antenna on the outside, not only does it improve your transmit range, but you'll be able to hear them from further away than you otherwise would as well, with a handheld inside the car without an external antenna. All that said, if staying in touch is super important to the group....if a large separation happens, have a plan for correcting that / regrouping. WRYZ926 and SteveShannon 2 Quote
WRYZ926 Posted Saturday at 03:32 PM Report Posted Saturday at 03:32 PM Many of us have used hand held radios with an external antenna with good results. As others have said, getting the antenna outside of the vehicle is the biggest improvement you can make. Adaptor cables that go from SO239 to SMA are cheap and make connecting an external antenna to most hand held radios easy to do. amaff, SteveShannon and AdmiralCochrane 3 Quote
LeoG Posted Saturday at 04:35 PM Report Posted Saturday at 04:35 PM Using an external antenna gets the antenna up higher and out of the metal box of the vehicle. I set up my wife with the Nagoya UT72 and a handheld microphone with an H3 radio. Makes using it much easier and gives much better range than the short antenna on the HT. AdmiralCochrane 1 Quote
GreggInFL Posted 5 hours ago Report Posted 5 hours ago On 7/26/2025 at 12:35 PM, LeoG said: Using an external antenna gets the antenna up higher and out of the metal box of the vehicle. I set up my wife with the Nagoya UT72 and a handheld microphone with an H3 radio. Makes using it much easier and gives much better range than the short antenna on the HT. That's what I did, with the same antenna. A good first-step improvement. I still use it occasionally with a DB25-G. Quote
Bogieboy01 Posted 5 hours ago Report Posted 5 hours ago On 7/26/2025 at 12:35 PM, LeoG said: Using an external antenna gets the antenna up higher and out of the metal box of the vehicle. I set up my wife with the Nagoya UT72 and a handheld microphone with an H3 radio. Makes using it much easier and gives much better range than the short antenna on the HT. Second this, i have 2 vehicles, and have only had time to install a mobile in one of them, when i want to drive the other AND talk to anonymous men on the radio in the other vehicle, i have a mag mount antenna that i hook to a Boofwang ar5rm with a hand mic, crazy part is the range is not all that different with an 8w handheld than it is with my 25w mobile rig... granted both of them are operating on stubby ghost antennas.... Quote
