Nfranks97 Posted March 24, 2019 Report Posted March 24, 2019 Want to put a gmrs radio in my semi and have been thinking of putting the midland mxt400 in it but I am open to any all other radio recommendations Quote
0 coryb27 Posted March 24, 2019 Report Posted March 24, 2019 Want to put a gmrs radio in my semi and have been thinking of putting the midland mxt400 in it but I am open to any all other radio recommendations I would stay away from this radio, it has many issues and will not provide great performance as it is narrow band and can not do split PL / DPL. Its short comings have been discussed in the Equipment section of this site. Find a nice Kenwood TK-880 if you don't mind used otherwise ICOM and Motorola both make great part 90 Business radios both new and used that will preform nicely on GMRS. I run the Motorola XPR series and love the full display, 1000 channel capacity, unlimited talk groups, scan lists, long range bluetooth microphones etc... Elkhunter521 1 Quote
0 Nfranks97 Posted March 24, 2019 Author Report Posted March 24, 2019 Thank you !! That was my next question is what kind of other radios doYou guys recommend? Quote
0 coryb27 Posted March 24, 2019 Report Posted March 24, 2019 Thank you !! That was my next question is what kind of other radios doYou guys recommend? Motorola gear is a pain to get programming software for but not impossible. I can take a week or longer to navigate Motorola's process but in the end you will have legal software and you can get the entitlement for wideband operation for free after some quick online training. I use Motorola for the options alone, in the truck I run handheld control heads and a long range Bluetooth speaker mic so I can use the trucks radio well in restaurants our friends houses. The same mic is also on my base paired with a desktop mic, its nice being able to go anywhere in the house and just carry a small mic that allows the use of the base. This gear is a little pricey but can be found used on ebay reasonable, its all comes down to personal preference. Bluetooth Mic that can be attached to most of the newer Motorola XPR radios including portables. http://mwgmrs.com/mygmrs/handmic.jpg This is the handheld control head, it is also the speaker and mic, 4 years old an not a single issue. http://mwgmrs.com/mygmrs/truck1.jpg Radio Head unit is installed under the back seat. http://mwgmrs.com/mygmrs/truck2.jpg The control head cable comes thru the map pocket allowing it to tuck away nicely out of sight. http://mwgmrs.com/mygmrs/truck4.jpg Simple 1/4 wave gives great performance, i am able to hit repeaters 30 miles away and simplex 10 miles easy in the freeway. http://mwgmrs.com/mygmrs/truck3.jpg MrCoffey, WRAE660, marcspaz and 1 other 4 Quote
0 Nfranks97 Posted March 24, 2019 Author Report Posted March 24, 2019 Awesome set up !!!! I should have mentioned I’m not to tech savvy at all and I don’t have access to a computer unless I go to the library or over someone’s house that has one Quote
0 WRAK968 Posted March 25, 2019 Report Posted March 25, 2019 Awesome set up !!!! I should have mentioned I’m not to tech savvy at all and I don’t have access to a computer unless I go to the library or over someone’s house that has oneI use TK880's for mobile units, mostly because the MOL software is a pain to get (And at times requires an out of date OS and a RIB depending on how old the radio is) Kenwood TK880's come in 25 and 50 watt models and the software is easy to get at a low price. The software also can be run on windows 10, and the cable is simple as well (No complicated RIB or anything) I've gotten all three 880's for less than $50, though one or two of them needed some cleaning. To reduce the number of programs I use, I ordered the 380 series portables which use the same software as the 880 mobiles. The only thing I dont like is that you can only store 10 "Tones" for CTCSS/DCS that you can select. I have the travel tone set in there and a few other codes for use when I travel. Outside of that the radios work really nice. RCM 1 Quote
0 coryb27 Posted March 25, 2019 Report Posted March 25, 2019 I use TK880's for mobile units, mostly because the MOL software is a pain to get (And at times requires an out of date OS and a RIB depending on how old the radio is) Kenwood TK880's come in 25 and 50 watt models and the software is easy to get at a low price. The software also can be run on windows 10, and the cable is simple as well (No complicated RIB or anything) I've gotten all three 880's for less than $50, though one or two of them needed some cleaning. To reduce the number of programs I use, I ordered the 380 series portables which use the same software as the 880 mobiles. The only thing I dont like is that you can only store 10 "Tones" for CTCSS/DCS that you can select. I have the travel tone set in there and a few other codes for use when I travel. Outside of that the radios work really nice. For sure Motorola On Line is a PITA, I dont know of anybody that would disagree. The equipment I spoke of needs no RIB and the stock USB cable does not require a driver. The Kenwoods are a great option but lack the features I wanted like the handheld control head, Bluetooth and WiFi programing. If i want to update my trucks programing I just leave the radio on and access it from my desktop. Again its all personal preference, its always nice to have options! Quote
0 WRAK968 Posted March 25, 2019 Report Posted March 25, 2019 For sure Motorola On Line is a PITA, I dont know of anybody that would disagree. The equipment I spoke of needs no RIB and the stock USB cable does not require a driver. The Kenwoods are a great option but lack the features I wanted like the handheld control head, Bluetooth and WiFi programing. If i want to update my trucks programing I just leave the radio on and access it from my desktop. Again its all personal preference, its always nice to have options!Thats nice but pricey lol. Also I don't have a MOL account (I cant even figure out how to get one) making it difficult to get software, but it is nice to hear Motorola finally moved forward with their software accessibility lol. I still remember the DOS window and the big black box that needed its own power supply. RCM and coryb27 2 Quote
0 Nfranks97 Posted March 26, 2019 Author Report Posted March 26, 2019 Thanks guys I just ordered a TK-880And the gentleman is gonna program my local repeater in for me , I probably payed a lil to much at 120 shipped . My I’m ok with my purchase . I will need help for future programming though Nfranks97 1 Quote
0 Ian Posted March 27, 2019 Report Posted March 27, 2019 (edited) Corey, that's incredibly awesome kit. That basically fills all of my weird-XXXuse-cases, and it's super elegant work. I'd love to read more about this setup! Motorola gear is a pain to get programming software for but not impossible. I can take a week or longer to navigate Motorola's process but in the end you will have legal software and you can get the entitlement for wideband operation for free after some quick online training. I use Motorola for the options alone, in the truck I run handheld control heads and a long range Bluetooth speaker mic so I can use the trucks radio well in restaurants our friends houses. The same mic is also on my base paired with a desktop mic, its nice being able to go anywhere in the house and just carry a small mic that allows the use of the base. This gear is a little pricey but can be found used on ebay reasonable, its all comes down to personal preference. Edited June 20, 2019 by spd641 Language Quote
0 Ian Posted March 27, 2019 Report Posted March 27, 2019 Thanks guys I just ordered a TK-880And the gentleman is gonna program my local repeater in for me , I probably payed a lil to much at 120 shipped . My I’m ok with my purchase . I will need help for future programming thoughYou didn't overpay. I paid more for less radio only a few months ago. Quote
0 Nfranks97 Posted March 31, 2019 Author Report Posted March 31, 2019 Got my new to me Kenwood yesterday and I love it thanks guys ! Radioguy7268 and WRAE660 2 Quote
0 w1ig Posted May 17, 2019 Report Posted May 17, 2019 I am using the Alinco DR-638. (On sale at HRO) Works great!! Quote
0 hfd376 Posted May 26, 2019 Report Posted May 26, 2019 Motorola gear is a pain to get programming software for but not impossible. I can take a week or longer to navigate Motorola's process but in the end you will have legal software and you can get the entitlement for wideband operation for free after some quick online training. I use Motorola for the options alone, in the truck I run handheld control heads and a long range Bluetooth speaker mic so I can use the trucks radio well in restaurants our friends houses. The same mic is also on my base paired with a desktop mic, its nice being able to go anywhere in the house and just carry a small mic that allows the use of the base. This gear is a little pricey but can be found used on ebay reasonable, its all comes down to personal preference. Bluetooth Mic that can be attached to most of the newer Motorola XPR radios including portables. http://mwgmrs.com/mygmrs/handmic.jpg This is the handheld control head, it is also the speaker and mic, 4 years old an not a single issue. http://mwgmrs.com/mygmrs/truck1.jpg Radio Head unit is installed under the back seat. http://mwgmrs.com/mygmrs/truck2.jpg The control head cable comes thru the map pocket allowing it to tuck away nicely out of sight. http://mwgmrs.com/mygmrs/truck4.jpg Simple 1/4 wave gives great performance, i am able to hit repeaters 30 miles away and simplex 10 miles easy in the freeway. http://mwgmrs.com/mygmrs/truck3.jpgCorey, I see your using, the XPR series, how do change the PL on the fly? Or would you still have to put it on the computer. Quote
0 coryb27 Posted May 26, 2019 Report Posted May 26, 2019 Corey, I see your using, the XPR series, how do change the PL on the fly? Or would you still have to put it on the computer. I program all the repeaters I want in the radio and update the program as needed. I don't have FPP on any of my radios. Quote
0 hfd376 Posted May 26, 2019 Report Posted May 26, 2019 I program all the repeaters I want in the radio and update the program as needed. I don't have FPP on any of my radios. Thank you, I've got a Motorola PM400, and while its obviously not FPP, it does have the ability to change the transmit and receive PL as desired as a menu item. I thought maybe the 7550 and 5550 series may have that as a menu item as well. Quote
0 bonelifer Posted June 3, 2019 Report Posted June 3, 2019 I use TK880's for mobile units, mostly because the MOL software is a pain to get (And at times requires an out of date OS and a RIB depending on how old the radio is) Kenwood TK880's come in 25 and 50 watt models and the software is easy to get at a low price. The software also can be run on windows 10, and the cable is simple as well (No complicated RIB or anything) I've gotten all three 880's for less than $50, though one or two of them needed some cleaning. To reduce the number of programs I use, I ordered the 380 series portables which use the same software as the 880 mobiles. The only thing I dont like is that you can only store 10 "Tones" for CTCSS/DCS that you can select. I have the travel tone set in there and a few other codes for use when I travel. Outside of that the radios work really nice. Looking into getting a Kenwood TK880. Where's the official place to purchase the software? Quote
0 axorlov Posted June 4, 2019 Report Posted June 4, 2019 On ebay the official CD runs between $15 and $20. Or you can look around on the internets. You need KPG-49D for the TK-880. You also will need a programming cable, that's another $20. Quote
0 n4gix Posted June 5, 2019 Report Posted June 5, 2019 Looking into getting a Kenwood TK880. Where's the official place to purchase the software? Be on the lookout for a TK-880H (1) if at all possible. The "H" indicates it is a high-power (45 watt) version, and the "1" indicates the band coverage of 450-490 Mhz, which includes all of the GMRS frequencies. WRAE660 1 Quote
0 bonelifer Posted June 24, 2019 Report Posted June 24, 2019 Be on the lookout for a TK-880H (1) if at all possible. The "H" indicates it is a high-power (45 watt) version, and the "1" indicates the band coverage of 450-490 Mhz, which includes all of the GMRS frequencies.Yeah, I got a TK-880H(1). At first it seemed nice they didn't cut off the power connector. But it took awhile to find the right mate online. All the power adapters I was finding were of the T-type variety. I'll know in about 4 days, if the one I found is the right type. Else, I'm just going to cut ends off and apply new Anderson plugs and be done with it. Wish I could find the mate for the accessories plug. But it seems like Molex Incorporated has ceased making it "76650-0070". Couldn't find if another company makes it.molex incorporated 76650-0070 Quote
0 n4gix Posted June 25, 2019 Report Posted June 25, 2019 Years ago I switched over to using nothing except Anderson Powerpoles on all my radio gear. This allows me complete flexibility and interchangeability. Quote
0 okinater Posted June 25, 2019 Report Posted June 25, 2019 Yeah, I got a TK-880H(1). At first it seemed nice they didn't cut off the power connector. But it took awhile to find the right mate online. All the power adapters I was finding were of the T-type variety. I'll know in about 4 days, if the one I found is the right type. Else, I'm just going to cut ends off and apply new Anderson plugs and be done with it. Wish I could find the mate for the accessories plug. But it seems like Molex Incorporated has ceased making it "76650-0070". Couldn't find if another company makes it.molex incorporated 76650-0070 Look up molex connector 03-06-6155. Maybe that is what you need? Quote
0 okinater Posted June 25, 2019 Report Posted June 25, 2019 Look up molex connector 03-06-6155. Maybe that is what you need?I think that was wrong, I think you are looking for a Molex 03-06-2151. Quote
0 Radioguy7268 Posted June 25, 2019 Report Posted June 25, 2019 Better yet, look up "Kenwood mobile power cord" on EBay. Plenty available, most around $10 with cord & fuse. berkinet 1 Quote
0 axorlov Posted June 26, 2019 Report Posted June 26, 2019 I'm quite sure that original plug is GM-type connector, available in Autozone or Kragen/O'Reilly. However, I soldered T-type to all my TK880s to easier plug different mobiles. Quote
0 BoxCar Posted June 26, 2019 Report Posted June 26, 2019 I'm quite sure that original plug is GM-type connector, available in Autozone or Kragen/O'Reilly. However, I soldered T-type to all my TK880s to easier plug different mobiles.I use a "Deans" T-connector. They are available at any hobby store selling radio control cars, boats and planes. The connectors will handle a 30 amp load with no problems. Quote
Nfranks97
26 answers to this question
