Hey. I was trying to save two repeaters in my radio the other day and it didn't work so well. I have all 8 repeater channels in memory with freuqncies and tones saved. When I tried to add a second repeater output which was already taken up by one of the other repeater channels, I tried to create a new frequency line using CHIRP, and it saved like all the other did, however, when I go to transmit, the radio doesn't work there. I just get a dead key. I assume because on a GMRS dedicated radio, we only get channels 15 to 22 to use. So what do you do if you need more channels? Do I end up having to delete one and enter the other just to use that one?
Is there no way to save the same repeater multiple times when the channels are all used up?
If that's the answer, that we can't, well OK. I am curious if anyone else has run into this and what you do?
jaycee
13 answers to this question
