Wouxun KG-805G Stopped RX-ing/TX-ing after using CHIRP.
Hi everybody,
I received my Wouxun KG-805G three days ago from BuyTwoWayRadios.com. It is a great small radio. Sound quality is great. I downloaded and installed Wouxun factory software and programmed the radio. Everything was working fine.
Then yesterday, after reading multiple posts on this forum where some people said that they used CHIRP and 816 profile to program 805G, I tried to do that. After uploading file from CHIRP to 805G this happened:
All voice commands switched to Chinese language.
Radio stopped transmitting and receiving. Display shows that it transmits, but my GMRS-V1 doesn’t get any signal on the same channel. And when I transmit from V1, 805G does not get anything.
Then I used factory software and their default codeplug file to restore 805G, but it did not help.
I called BuyTwoWayRadios.com customer services and described everything. They said that this was problem between CHIRP and 805G, and that this was not warrantable.
I search Internet and found post from October 2020 in this thread:
Update: turns out that the CHIRP read embeds certain defaults into the radio, including Chinese voice, 60 sec TOT and several other things. I tried unprogramming and reprogramming the radio without success and I can't get it to stop doing these things, so for the moment, DO NOT use CHIRP to program the radio. Sorry I posted this and hopefully people will see this before they try it. Just wanted to make sure folks were forewarned and I apologize for not discovering and posting the problem earlier.
MozartMan
Hi everybody,
https://forums.radioreference.com/threads/wouxun-kg-805g.414204/
Quote from that thread:
It looks like I am stuck with $80 brick.
Any suggestion appreciated.
35 answers to this question
