Doctnj Posted July 22, 2021 Report Posted July 22, 2021 This is the second battery eliminator from wouxun that from my point of view is now trash. They replaced the first one that died so Im thinking I just got a bad one. Now I'm thinking there is either something I did or someone needs to go back drawing board. The first time it happened with the first B. E. , I started to get cut off while transmitting. By the clock it would shut off transmission after 20-30 sec. I keep an HT in my truck and keep it hooked up to antenna as well as battery eliminator on the HT. I do unplug sig lighter when getting out of the truck so to my knowledge it hasn't been accidentally transmitting for any length of time. I just got the bigger battery so between those two I probably don't need an eliminator. But I still have one last B. E., un opened. Guess for emergency it can be useful but it too will probably have a countdown. Quote
Lscott Posted July 22, 2021 Report Posted July 22, 2021 Looking at the photo the plug is like several I have. The knurled nut on the end around the center pin likely unscrews. Typically there is a fuse in there. It might be the fuse is toast. JLeikhim 1 Quote
Doctnj Posted July 22, 2021 Author Report Posted July 22, 2021 It works when just listening but key up and talk and you have about 20 S before it shuts off the transmission. I'll record it and post it. Quote
Lscott Posted July 22, 2021 Report Posted July 22, 2021 On 7/22/2021 at 6:05 PM, Doctnj said: It works when just listening but key up and talk and you have about 20 S before it shuts off the transmission. I'll record it and post it. Expand So it's a one time deal? Listening all you want, then TX for 20 seconds and it dies never to work again? Quote
Doctnj Posted July 22, 2021 Author Report Posted July 22, 2021 I tried to upload a video but since it takes about 30 sec to shut off the file is too large. I've trimmed it down and it.still won't work. Strange it's only on rptr channels where it drops TX. Quote
n4gix Posted July 23, 2021 Report Posted July 23, 2021 That sounds as though there is too much drop in voltage when transmitting. AdmiralCochrane 1 Quote
TOM47 Posted July 25, 2021 Report Posted July 25, 2021 IHAVE A FEW OF THOSE Wouxun KG-E-1 (ELO-001) battery eliminators FOR THE KG-805G'S THAT I HAVEN'T TRIED YET FOR EMERGENCY USE. Quote
Doctnj Posted July 26, 2021 Author Report Posted July 26, 2021 On 7/22/2021 at 7:03 PM, Lscott said: So it's a one time deal? Listening all you want, then TX for 20 seconds and it dies never to work again? Expand No once it starts it happens all the time. Right now I just use a battery. I have one more so I'll try it again. Quote
WRFP399 Posted July 26, 2021 Report Posted July 26, 2021 On 7/26/2021 at 12:49 AM, Doctnj said: No once it starts it happens all the time. Right now I just use a battery. I have one more so I'll try it again. Expand He is asking does the BE stop working all together after it shuts down indicating that it could be the fuse that is blown....but if I understand what you are saying is that the BE works just fine unless you put it under a heavy load, at which point it "stops working" and you can only listen, indicating that the BE still is supplying power, but maybe just not enough. Quote
Roadrunner74 Posted August 8, 2021 Report Posted August 8, 2021 I bought a BE for my 905G as well... was planning on using it next week on a short road trip... however, this thread has me a bit concerned now as to whether or not I should even use it. Part of me wants to but the other part of me doesn't want to risk it -RR Quote
TOM47 Posted August 8, 2021 Report Posted August 8, 2021 WITH AN EXTRA BATTERY AND YOUR CHARGER BASE USING Wouxun Vehicle Charging Adapter (CCO-001) (buytwowayradios.com) MAY WORK FOR THAT SHORT ROAD TRIP? Quote
Doctnj Posted August 8, 2021 Author Report Posted August 8, 2021 That may indeed. Right now I've been using batteries and it's functioning fine. I have one eliminator left. Wouxun is fast to blame the amp in line with radio although Motorola makes a device you drop your HT into and it too has an in line Amp, charges the battery and uses installed antenna. And actually I'm about to receive my new Motorola and want to see how it does and I'll figure out where best to use it. May just get a converticon and be set. Quote
