koni13 Posted May 4 Report Share Posted May 4 5 hours ago, WRXP381 said: So get one of the many radios that does use chirp. Loads of options. Agree WRXP381, just overwhelmed with all the options out there? Also installing into a Jeep so limited space, although want to use as a dual unit with the capability of mobile and home base. Quote Link to comment Share on other sites More sharing options...
back4more70 Posted May 4 Report Share Posted May 4 10 hours ago, koni13 said: Agree WRXP381, just overwhelmed with all the options out there? Also installing into a Jeep so limited space, although want to use as a dual unit with the capability of mobile and home base. Every mobile radio can be used as a mobile or base unit. If used as a base, you just need a decent power supply. For the mobile mount of the DB20G, you may want to spend a few $ on an external speaker, depending on mounting location and road noise. Quote Link to comment Share on other sites More sharing options...
jwilkers Posted May 4 Report Share Posted May 4 FRS radios must have a permanently attached antenna and have a 2 watt maximum output power.Anything else is illegal.Sent from my SM-S911U1 using Tapatalk WRXP381, koni13 and AdmiralCochrane 1 2 Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted May 5 Report Share Posted May 5 2 hours ago, jwilkers said: Anything else is illegal. Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? koni13 1 Quote Link to comment Share on other sites More sharing options...
WRXP381 Posted May 5 Report Share Posted May 5 43 minutes ago, OffRoaderX said: Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? I’m sure some ones head explodes!!! koni13 1 Quote Link to comment Share on other sites More sharing options...
koni13 Posted May 5 Report Share Posted May 5 Appreciate all the insight and laughing with all the comments provided, loving the GMRS world. Just received my Radioditty DB20-G mobile radio, along with my Nagoya UT-72G antenna also DHT cable SMA female to UHF SO-239 female connector. Quote Link to comment Share on other sites More sharing options...
WRYS709 Posted May 5 Report Share Posted May 5 12 hours ago, koni13 said: Appreciate all the insight and laughing with all the comments provided, loving the GMRS world. Just received my Radioditty DB20-G mobile radio, along with my Nagoya UT-72G antenna also DHT cable SMA female to UHF SO-239 female connector. I see that Amazon's listing of that antenna includes a SMA to 239 adapter cable, for $35. Was that your experience. koni13 1 Quote Link to comment Share on other sites More sharing options...
koni13 Posted May 6 Report Share Posted May 6 On 5/5/2024 at 9:19 AM, WRYS709 said: I see that Amazon's listing of that antenna includes a SMA to 239 adapter cable, for $35. Was that your experience. It sure was, connecting today after work in hopes can transmit on stations and repeaters. Quote Link to comment Share on other sites More sharing options...
WRYS709 Posted May 7 Report Share Posted May 7 16 hours ago, koni13 said: It sure was, connecting today after work in hopes can transmit on stations and repeaters. Let us know how it goes. I might pick up that antenna as an improvement instead of my $20 Dual Band Mag Mount. koni13 1 Quote Link to comment Share on other sites More sharing options...
koni13 Posted May 8 Report Share Posted May 8 Sure will WRYS709, by the way how does the $20 Dual Band Mag Mount work out. Quote Link to comment Share on other sites More sharing options...
WRYS709 Posted May 8 Report Share Posted May 8 4 hours ago, koni13 said: Sure will WRYS709, by the way how does the $20 Dual Band Mag Mount work out. I like it; it does not go too far above the top of my vehicle's roof, so it only hits my garage door lightly twice. But it seems that yours with a coil with have better mobile range. koni13 1 Quote Link to comment Share on other sites More sharing options...
koni13 Posted May 9 Report Share Posted May 9 We been having lots of rain in the area, and tonight continuance of tornado warnings. Hopes are compete setup tomorrow, and hit you back on range or connectivity outcome. Quote Link to comment Share on other sites More sharing options...
Davichko5650 Posted May 9 Report Share Posted May 9 On 5/4/2024 at 7:17 PM, OffRoaderX said: Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? I've seen your hands on those videos, I'm not so sure SOC radio disassembly would be your forte? Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted May 9 Report Share Posted May 9 Just now, Davichko5650 said: not so sure SOC radio disassembly would be your forte? I have a hammer and a butter-knife, I can take anything apart. Davichko5650 and SteveShannon 1 1 Quote Link to comment Share on other sites More sharing options...
back4more70 Posted May 9 Report Share Posted May 9 3 minutes ago, OffRoaderX said: I have a hammer and a butter-knife, I can take anything apart. I built my AR-15 with a screwdriver, pliers, and a socket wrench (because I didn't have a hammer). WRXR255 and Davichko5650 2 Quote Link to comment Share on other sites More sharing options...
Davichko5650 Posted May 9 Report Share Posted May 9 4 hours ago, OffRoaderX said: I have a hammer and a butter-knife, I can take anything apart. Everybody's babbling about Bob's bountiful bargain-basement butterknife bonanza!!!! Quote Link to comment Share on other sites More sharing options...
Davichko5650 Posted May 9 Report Share Posted May 9 4 hours ago, back4more70 said: I built my AR-15 with a screwdriver, pliers, and a socket wrench (because I didn't have a hammer). Never built an AR-15, but could take apart and reassemble my M16A1 with bare hands. Seems to work with my AR's here in the Civilian world as well. SteveShannon 1 Quote Link to comment Share on other sites More sharing options...
WRXP381 Posted May 9 Report Share Posted May 9 9 minutes ago, Davichko5650 said: Never built an AR-15, but could take apart and reassemble my M16A1 with bare hands. Seems to work with my AR's here in the Civilian world as well. Haha funny statement since they are the exact same. Quote Link to comment Share on other sites More sharing options...
Davichko5650 Posted May 10 Report Share Posted May 10 18 hours ago, WRXP381 said: Haha funny statement since they are the exact same. I don't have any selective fire models however. Now just need some LSA and a hotdog for the old barracks trick on sleeping dude. SteveShannon and WRYZ926 2 Quote Link to comment Share on other sites More sharing options...
WRYZ926 Posted May 11 Report Share Posted May 11 One of our club members has been considering how to make a FRS base station for his grandson. We talked about taking the guts of a FRS radio and installing everything in a 3D printed body to keep the antenna permanently attached. His grandson is about 7 years old and loves talking on the radio with his grandpa. As far as assembling an AR. I use nothing but simple hand tool for the lower while sitting at my desk or on the couch. I only use a vice and torque wrench for attaching the barrel and muzzle device on the upper. Otherwise I hand assemble the rest of the upper at my desk too. @Davichko5650 your post made me smile remembering all the gags we would pull on each other when I was in the Army. Quote Link to comment Share on other sites More sharing options...
WRQC527 Posted May 11 Report Share Posted May 11 32 minutes ago, WRYZ926 said: FRS base station There's always this if you want to go the expedient route for about a hundred bucks. https://midlandusa.com/products/xt511-base-camp?variant=39972162371761&gad_source=1&gclid=CjwKCAjwrvyxBhAbEiwAEg_KgmrtZNG6G4zjOXdzSM4kDvgkSyjlgdsFYL2Hxyd6HWkk9NiQ4kJemhoCSLsQAvD_BwE Quote Link to comment Share on other sites More sharing options...
WRYZ926 Posted May 11 Report Share Posted May 11 17 minutes ago, WRQC527 said: There's always this if you want to go the expedient route for about a hundred bucks. Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Quote Link to comment Share on other sites More sharing options...
WRYS709 Posted May 11 Report Share Posted May 11 1 hour ago, WRYZ926 said: Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Except for the fact that FRS is a system where the license is provided by rule. If you make a DIY FRS radio, no matter what wattage you set it for it becomes unlicensed and all users are violating Part 95E. Maybe you don't care, in which case, what we answer is irrelevant. If you want FRS, buy FRS. If you use GMRS, get a license. Over2U 1 Quote Link to comment Share on other sites More sharing options...
WRXP381 Posted May 11 Report Share Posted May 11 1 hour ago, WRYZ926 said: Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Just have grandpa get a gmrs license then grand son can use it. Buy any base station you want and use it. No need for all the junk building and FRS radio that is so limited in power. Heck you could even do an unlocked ham and only put in 1 frequency Quote Link to comment Share on other sites More sharing options...
WRYZ926 Posted May 11 Report Share Posted May 11 12 minutes ago, WRYS709 said: Except for the fact that FRS is a system where the license is provided by rule. If you make a DIY FRS radio, no matter what wattage you set it for it becomes unlicensed and all users are violating Part 95E. Maybe you don't care, in which case, what we answer is irrelevant. If you want FRS, but FRS. If you use GMRS, get a license. And that is why this project hasn't gone beyond talking about it. Yes all involved are aware of the regulations. And this is why it was discussed using a legal FRS radio inside a 3D printed case to make it look like a mobile/base station. Quote Link to comment Share on other sites More sharing options...
