koni13 Posted May 4, 2024 Report Posted May 4, 2024 5 hours ago, WRXP381 said: So get one of the many radios that does use chirp. Loads of options. Agree WRXP381, just overwhelmed with all the options out there? Also installing into a Jeep so limited space, although want to use as a dual unit with the capability of mobile and home base. Quote
back4more70 Posted May 4, 2024 Report Posted May 4, 2024 10 hours ago, koni13 said: Agree WRXP381, just overwhelmed with all the options out there? Also installing into a Jeep so limited space, although want to use as a dual unit with the capability of mobile and home base. Every mobile radio can be used as a mobile or base unit. If used as a base, you just need a decent power supply. For the mobile mount of the DB20G, you may want to spend a few $ on an external speaker, depending on mounting location and road noise. Quote
jwilkers Posted May 4, 2024 Report Posted May 4, 2024 FRS radios must have a permanently attached antenna and have a 2 watt maximum output power.Anything else is illegal.Sent from my SM-S911U1 using Tapatalk koni13 and AdmiralCochrane 1 1 Quote
OffRoaderX Posted May 5, 2024 Report Posted May 5, 2024 2 hours ago, jwilkers said: Anything else is illegal. Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? koni13 1 Quote
Guest Posted May 5, 2024 Report Posted May 5, 2024 43 minutes ago, OffRoaderX said: Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? I’m sure some ones head explodes!!! Quote
koni13 Posted May 5, 2024 Report Posted May 5, 2024 Appreciate all the insight and laughing with all the comments provided, loving the GMRS world. Just received my Radioditty DB20-G mobile radio, along with my Nagoya UT-72G antenna also DHT cable SMA female to UHF SO-239 female connector. Quote
WRYS709 Posted May 5, 2024 Report Posted May 5, 2024 12 hours ago, koni13 said: Appreciate all the insight and laughing with all the comments provided, loving the GMRS world. Just received my Radioditty DB20-G mobile radio, along with my Nagoya UT-72G antenna also DHT cable SMA female to UHF SO-239 female connector. I see that Amazon's listing of that antenna includes a SMA to 239 adapter cable, for $35. Was that your experience. koni13 1 Quote
koni13 Posted May 6, 2024 Report Posted May 6, 2024 On 5/5/2024 at 9:19 AM, WRYS709 said: I see that Amazon's listing of that antenna includes a SMA to 239 adapter cable, for $35. Was that your experience. It sure was, connecting today after work in hopes can transmit on stations and repeaters. Quote
WRYS709 Posted May 7, 2024 Report Posted May 7, 2024 16 hours ago, koni13 said: It sure was, connecting today after work in hopes can transmit on stations and repeaters. Let us know how it goes. I might pick up that antenna as an improvement instead of my $20 Dual Band Mag Mount. koni13 1 Quote
koni13 Posted May 8, 2024 Report Posted May 8, 2024 Sure will WRYS709, by the way how does the $20 Dual Band Mag Mount work out. Quote
WRYS709 Posted May 8, 2024 Report Posted May 8, 2024 4 hours ago, koni13 said: Sure will WRYS709, by the way how does the $20 Dual Band Mag Mount work out. I like it; it does not go too far above the top of my vehicle's roof, so it only hits my garage door lightly twice. But it seems that yours with a coil with have better mobile range. koni13 1 Quote
koni13 Posted May 9, 2024 Report Posted May 9, 2024 We been having lots of rain in the area, and tonight continuance of tornado warnings. Hopes are compete setup tomorrow, and hit you back on range or connectivity outcome. Quote
Davichko5650 Posted May 9, 2024 Report Posted May 9, 2024 On 5/4/2024 at 7:17 PM, OffRoaderX said: Wow, that sounds serious! What happens if I disassemble my FRS radio and attach it to a larger, removable antenna? I've seen your hands on those videos, I'm not so sure SOC radio disassembly would be your forte? Quote
OffRoaderX Posted May 9, 2024 Report Posted May 9, 2024 Just now, Davichko5650 said: not so sure SOC radio disassembly would be your forte? I have a hammer and a butter-knife, I can take anything apart. SteveShannon and Davichko5650 1 1 Quote
back4more70 Posted May 9, 2024 Report Posted May 9, 2024 3 minutes ago, OffRoaderX said: I have a hammer and a butter-knife, I can take anything apart. I built my AR-15 with a screwdriver, pliers, and a socket wrench (because I didn't have a hammer). WRXR255 and Davichko5650 2 Quote
Davichko5650 Posted May 9, 2024 Report Posted May 9, 2024 4 hours ago, OffRoaderX said: I have a hammer and a butter-knife, I can take anything apart. Everybody's babbling about Bob's bountiful bargain-basement butterknife bonanza!!!! Quote
Davichko5650 Posted May 9, 2024 Report Posted May 9, 2024 4 hours ago, back4more70 said: I built my AR-15 with a screwdriver, pliers, and a socket wrench (because I didn't have a hammer). Never built an AR-15, but could take apart and reassemble my M16A1 with bare hands. Seems to work with my AR's here in the Civilian world as well. SteveShannon 1 Quote
Guest Posted May 9, 2024 Report Posted May 9, 2024 9 minutes ago, Davichko5650 said: Never built an AR-15, but could take apart and reassemble my M16A1 with bare hands. Seems to work with my AR's here in the Civilian world as well. Haha funny statement since they are the exact same. Quote
Davichko5650 Posted May 10, 2024 Report Posted May 10, 2024 18 hours ago, WRXP381 said: Haha funny statement since they are the exact same. I don't have any selective fire models however. Now just need some LSA and a hotdog for the old barracks trick on sleeping dude. SteveShannon and WRYZ926 2 Quote
WRYZ926 Posted May 11, 2024 Report Posted May 11, 2024 One of our club members has been considering how to make a FRS base station for his grandson. We talked about taking the guts of a FRS radio and installing everything in a 3D printed body to keep the antenna permanently attached. His grandson is about 7 years old and loves talking on the radio with his grandpa. As far as assembling an AR. I use nothing but simple hand tool for the lower while sitting at my desk or on the couch. I only use a vice and torque wrench for attaching the barrel and muzzle device on the upper. Otherwise I hand assemble the rest of the upper at my desk too. @Davichko5650 your post made me smile remembering all the gags we would pull on each other when I was in the Army. Quote
WRQC527 Posted May 11, 2024 Report Posted May 11, 2024 32 minutes ago, WRYZ926 said: FRS base station There's always this if you want to go the expedient route for about a hundred bucks. https://midlandusa.com/products/xt511-base-camp?variant=39972162371761&gad_source=1&gclid=CjwKCAjwrvyxBhAbEiwAEg_KgmrtZNG6G4zjOXdzSM4kDvgkSyjlgdsFYL2Hxyd6HWkk9NiQ4kJemhoCSLsQAvD_BwE Quote
WRYZ926 Posted May 11, 2024 Report Posted May 11, 2024 17 minutes ago, WRQC527 said: There's always this if you want to go the expedient route for about a hundred bucks. Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Quote
WRYS709 Posted May 11, 2024 Report Posted May 11, 2024 1 hour ago, WRYZ926 said: Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Except for the fact that FRS is a system where the license is provided by rule. If you make a DIY FRS radio, no matter what wattage you set it for it becomes unlicensed and all users are violating Part 95E. Maybe you don't care, in which case, what we answer is irrelevant. If you want FRS, buy FRS. If you use GMRS, get a license. Over2U 1 Quote
Guest Posted May 11, 2024 Report Posted May 11, 2024 1 hour ago, WRYZ926 said: Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though. Just have grandpa get a gmrs license then grand son can use it. Buy any base station you want and use it. No need for all the junk building and FRS radio that is so limited in power. Heck you could even do an unlocked ham and only put in 1 frequency Quote
WRYZ926 Posted May 11, 2024 Report Posted May 11, 2024 12 minutes ago, WRYS709 said: Except for the fact that FRS is a system where the license is provided by rule. If you make a DIY FRS radio, no matter what wattage you set it for it becomes unlicensed and all users are violating Part 95E. Maybe you don't care, in which case, what we answer is irrelevant. If you want FRS, but FRS. If you use GMRS, get a license. And that is why this project hasn't gone beyond talking about it. Yes all involved are aware of the regulations. And this is why it was discussed using a legal FRS radio inside a 3D printed case to make it look like a mobile/base station. Quote
