WRPE755 Posted April 20, 2022 Report Posted April 20, 2022 I just ordered a Radioddity DB25g off of Amazon, and after doing so started hearing about a batch of bad units, which do not allow for the programming of addition repeater channels. Has anyone noted or heard of such issues? According to reviews one is supposed to be able additional repeater channels (yes, I know that just means differing CTSS codes, not actual channels) up to the limit of open memory slots, which total 200. This capability is why I ordered the radio! Quote
OffRoaderX Posted April 20, 2022 Report Posted April 20, 2022 (edited) Yes, I know 2 people that got 'bad' DB25G radios. IIRC they could not program them correctly but I dont remember exactly so I txt'd one of them to confirm. In both cases they sent them back and had them replaced with ones that actually work. This was a few months ago so I would hope/guess that they are no longer shipping bad units. Edit/Update: Turns out it was 3 people that got bad units, and the issue was as you described, not being able to additional repeater channels and also not being able to do a factory reset. All got replacement units that worked, but it was a PITA. Have not been able to confirm if bad units are still being shipped. Edited April 20, 2022 by OffRoaderX Raybestos, WRHS218, WRPE755 and 1 other 2 1 1 Quote
TOM47 Posted April 20, 2022 Report Posted April 20, 2022 I ALSO BOUGHT THREE DB25'S FROM AMAZON AND RETURNED FOR VARRIOUS ISSUES NOT MENTIONED ABOVE. Quote
WRPE755 Posted April 20, 2022 Author Report Posted April 20, 2022 TOM47, if you don’t mind, what issues did you have? I only have 30 days to return it, and it would be nice to know what to look for! Raybestos 1 Quote
TOM47 Posted April 20, 2022 Report Posted April 20, 2022 1 hour ago, WRPE755 said: TOM47, if you don’t mind, what issues did you have? I only have 30 days to return it, and it would be nice to know what to look for! CAN'T REALLY TPPE BUT ONE TURNED INTO A BRICK ANOTHER STOPPED ACCEPTING SOFTWARE CHANGES FORGOT THE THIRD . HAD OTHER SMALL PROBLEMS,ALL THIS DURING FEBRUARY. NO SUCH PROBLEMS WITH A NUMBER OF DB-20'S I BOUGHT SET UP AND GAVE TO FRIENDS. Quote
MichaelLAX Posted April 20, 2022 Report Posted April 20, 2022 I am also a Happy Anytone AT-779UV user (a/k/a Radioddity DB20-G) and recommend that you consider the switch! So much more can be accomplished with this model (except, as of this date, no CHIRP availability). Notarubicon's review PartsMan, TOM47 and wayoverthere 2 1 Quote
TOM47 Posted April 20, 2022 Report Posted April 20, 2022 25 minutes ago, MichaelLAX said: I am also a Happy Anytone AT-779UV user (a/k/a Radioddity DB20-G) and recommend that you consider the switch! So much more can be accomplished with this model (except, as of this date, no CHIRP availability). Notarubicon's review Quote
PartsMan Posted April 20, 2022 Report Posted April 20, 2022 I have a friend that cannot get his DB25 to program as well. My Retevis RA25 works great. It's like a DB20 but has a twenty five in the name so it is better. Quote
WRPE755 Posted April 20, 2022 Author Report Posted April 20, 2022 Thanks, folks. I appreciate the advice. I will probably send it back and get the DB20. I was trying to choose between the two anyway. Sounds like I chose “poorly”. No big deal. It is easily rectified! Quote
TOM47 Posted April 20, 2022 Report Posted April 20, 2022 1 hour ago, PartsMan said: t's like a DB20 but has a twenty five in the name so it is better. NO IT'S WORSE 25 MORE ISSUES, NONE WITH DB20! Quote
MichaelLAX Posted April 21, 2022 Report Posted April 21, 2022 My only issues with the DB20-G: 1) It's not CHIRP compatible and it's software does not import, so you must type out all of your channels. My advice: leave space between different categories of channels for later growth and easy insertion; 2) It does not scan for tones; and 3) a 50 watt model would be great! That being said: I have one in my EV and the other in my shack; both opened up to transmit on 2 meters, 70 cms, and MURS as well as GMRS. PartsMan 1 Quote
donniefitz2 Posted April 22, 2022 Report Posted April 22, 2022 On 4/21/2022 at 8:51 AM, MichaelLAX said: My only issues with the DB20-G: 1) It's not CHIRP compatible and it's software does not import, so you must type out all of your channels. My advice: leave space between different categories of channels for later growth and easy insertion; 2) It does not scan for tones; and 3) a 50 watt model would be great! That being said: I have one in my EV and the other in my shack; both opened up to transmit on 2 meters, 70 cms, and MURS as well as GMRS. As for number 2, it does not scan for tones automatically. But, you can manually scan for tones. If you have a RX signal and you go into the menu for RX CTS or DCS, you can manually click through and it will break squelch once you hit the tone. Not ideal, but it does work. K3MRK 1 Quote
MichaelLAX Posted April 23, 2022 Report Posted April 23, 2022 On 4/22/2022 at 10:38 AM, donniefitz2 said: As for number 2, it does not scan for tones automatically. But, you can manually scan for tones. If you have a RX signal and you go into the menu for RX CTS or DCS, you can manually click through and it will break squelch once you hit the tone. Not ideal, but it does work. I suppose that workaround is true for any radio. For me purchasing a $30 HT with tone scanning solved that problem! WRPE755 1 Quote
donniefitz2 Posted April 24, 2022 Report Posted April 24, 2022 8 hours ago, MichaelLAX said: For me purchasing a $30 HT with tone scanning solved that problem! I have done that too. Works well. WRPE755 1 Quote
WyoJoe Posted April 24, 2022 Report Posted April 24, 2022 On 4/20/2022 at 1:26 PM, PartsMan said: I have a friend that cannot get his DB25 to program as well. My Retevis RA25 works great. It's like a DB20 but has a twenty five in the name so it is better. I suppose then, that the AT-779UV is waaaaay better! PartsMan, MichaelLAX and wayoverthere 3 Quote
back4more70 Posted June 10, 2022 Report Posted June 10, 2022 On 4/20/2022 at 1:26 PM, PartsMan said: My Retevis RA25 works great Mine too! Quote
WRPC600 Posted September 2, 2022 Report Posted September 2, 2022 I have the DB-25G and have had 0 issues with it, using it that is. There are some things I've noticed about it, I know I'm going to get flack/wrong answers, BUT, for my radio, the channels 8-14 don't show up period (even using CHIRP to Program them into their respective slots, the radio simply WON'T allow those channels to be added back in). I KNOW THEY ARE LOW POWER!! I KNOW WE "CAN'T" TRANSMIT ON THEM. That's not the issue, I'm wondering is there are other DB-25G users out there that are able to have those SPECIFIC Channels show up WITHOUT "adding" them on to the end of the Programs. See attached picture. My programing will NOT allow for those channels to be added. The other issue I had with mine is that the NOAA channels weren't included, I had to manually add them, not that its such a big deal, I've just been told before that: "they are already programmed..." aside from those 2 issues, I love my DB-25G and again, 0 issues with it. Quote
TOM47 Posted September 2, 2022 Report Posted September 2, 2022 On 4/20/2022 at 10:57 AM, WRPE755 said: TOM47, if you don’t mind, what issues did you have? I only have 30 days to return it, and it would be nice to know what to look for! I NO LONGER REMEMBER BUT ALL WERE VERY SERIOUS AND PREVENTED USE. BOUGHT THEM FOR GIFTS AS THE DB20'S I GAVE OUT WORKED SO WELL. SORRY FOR LATE RESPONSE. Quote
KAF6045 Posted September 2, 2022 Report Posted September 2, 2022 3 hours ago, WRPC600 said: I have the DB-25G and have had 0 issues with it, using it that is. There are some things I've noticed about it, I know I'm going to get flack/wrong answers, BUT, for my radio, the channels 8-14 don't show up period (even using CHIRP to Program them into their respective slots, the radio simply WON'T allow those channels to be added back in). I KNOW THEY ARE LOW POWER!! I KNOW WE "CAN'T" TRANSMIT ON THEM. That's not the issue, I'm wondering is there are other DB-25G users out there that are able to have those SPECIFIC Channels show up WITHOUT "adding" them on to the end of the Programs. See attached picture. My programing will NOT allow for those channels to be added. The other issue I had with mine is that the NOAA channels weren't included, I had to manually add them, not that its such a big deal, I've just been told before that: "they are already programmed..." aside from those 2 issues, I love my DB-25G and again, 0 issues with it. Ever consider that the radio may, somehow, not even have those memory slots? That is, the firmware may have something like "if channel# >14, memory# = channel# - 7" Quote
gortex2 Posted September 3, 2022 Report Posted September 3, 2022 8-14 dont show up as its a mobile. Rules specifically specify those are portable frequencies only. Quote
SteveShannon Posted September 3, 2022 Report Posted September 3, 2022 2 hours ago, gortex2 said: 8-14 dont show up as its a mobile. Rules specifically specify those are portable frequencies only. For transmitting yes, but it’s odd the radio doesn’t include them as receive only. Quote
gortex2 Posted September 4, 2022 Report Posted September 4, 2022 If they are included as RX only people would be on here asking why they can't transmit on them. None of the midland MTX mobiles have them either. Its not just this radio. Quote
WRPC600 Posted September 4, 2022 Report Posted September 4, 2022 11 hours ago, gortex2 said: If they are included as RX only people would be on here asking why they can't transmit on them. None of the midland MTX mobiles have them either. Its not just this radio. That makes sense, including what everyone else has said. I wondered why my HT had them, but not the mobile. Again, makes a lot of sense. Quote
WA7SKG Posted January 22, 2024 Report Posted January 22, 2024 A little late to these comments. Just got a couple DB-25G radios. They program OK with CHIRP. Channels 8-14 are present as RX only and cannot be changed. Programming not very intuitive. One nice (for me) feature over the DB-20 is the Quad-Watch, ability to monitor four channels at once. Having a bank or group function would be nice as I travel a lot and the ability to put additional repeaters in groups for different areas would be useful. The scan is kind of slow compared to most radios these days. The manual is just shy of worthless. After watching a couple YouTube videos I finally got it set up how I like it. The WX channels are way up at the end of the list (190-199) but are not marked to skip in scan by default, so you have to go in and mark them skip if you want to scan, which was a bit annoying. There is no resume delay when scanning, so if it stops on someone talking, it resumes as soon as they stop, if you have a lot of channels programmed, it will take a few seconds to get back to that channel so you will miss part of the reply. So far, so good. It meets my particular needs. Michael Dave524 and TrikeRadio 2 Quote
WSHF619 Posted April 4 Report Posted April 4 @WA7SKG I have a db25g I programmed in my local repeaters with correct ctcss and offsets everything looks good but for some reason my radio won’t transmit or receive anything any tips or advice would be appreciated TrikeRadio 1 Quote
