MarkAG Posted April 27, 2022 Report Posted April 27, 2022 Ok, I’m being impatient. I’ve seen one YouTube vid mentioning this new version of the UV9G, but I can’t find any specs on it either on the BetterSafeRadio page or the Wouxun home page. Anyone have any info? Quote
OffRoaderX Posted April 27, 2022 Report Posted April 27, 2022 I have one right here on my desk.. It's a nice upgrade the the UV9G.. The release has been delayed due to supply chain/shipping issues, but it should be available soon (my GUESS is 30-60 days, but this is only a guess).. Some new stuff on the UV9Gx: theme able color schemes much brighter LED flashlight stiffer knobs can receive down to 219Mhz more power control settings for better battery life a priority channel button, pre-set to the official highway channel, CH19 more pre-programmed frequenicies and most important a ROGER BEEP .................affiliate link below.. Oops.. sorry.. bad habit. OldBlue, gskbrew, wrci350 and 9 others 5 7 Quote
MarkAG Posted April 27, 2022 Author Report Posted April 27, 2022 Lucky dog! What are the power ranges? So does the UV9GPro not have a Roger beep? and, is this Randy? I won’t tell anyone if it is. Quote
OffRoaderX Posted April 27, 2022 Report Posted April 27, 2022 Some of the early UV9GPro and the UV9GLite had Roger beeps, but IIRC, the bulk of the UV9GPro units do not have a Roger Beep.. Due to the outcry of customers from around the world, they added it back for the UV9GX. Mid power is now 2watts, high power is still 5watts.. I dont remember what low power is, but its the same as the the UV9GPro. I'm only telling you this because YOU are my favorite user here at MyGMRS ... WRMD634, gearjunkie, Whiskey363 and 3 others 4 1 1 Quote
MarkAG Posted April 27, 2022 Author Report Posted April 27, 2022 Excellent. I look forward to a review. Soon? Mark NotaCherokee Quote
BSRMark Posted May 21, 2022 Report Posted May 21, 2022 On 4/27/2022 at 10:29 AM, MarkAG said: Excellent. I look forward to a review. Soon? Quote
giantfuton Posted May 21, 2022 Report Posted May 21, 2022 Do you feel that the changes in screen theme help at all with visibility when using outside? This seems like it would still share the same issue was the KG-935 Quote
BSRMark Posted May 22, 2022 Report Posted May 22, 2022 20 hours ago, giantfuton said: Do you feel that the changes in screen theme help at all with visibility when using outside? It helps a bit due to the added contrast, but doesn't totally solve the problem. That will have to wait for an OLED screen in a future version. gearjunkie and TXFitz 2 Quote
TNRonin Posted May 22, 2022 Report Posted May 22, 2022 3 minutes ago, BSRMark said: It helps a bit due to the added contrast, but doesn't totally solve the problem. That will have to wait for an OLED screen in a future version. Heck I'd get giddy for an OLED version. jbkalla and BSRMark 2 Quote
flashover52 Posted May 26, 2022 Report Posted May 26, 2022 I have one right here on my desk.. It's a nice upgrade the the UV9G.. The release has been delayed due to supply chain/shipping issues, but it should be available soon (my GUESS is 30-60 days, but this is only a guess).. Some new stuff on the UV9Gx: theme able color schemes much brighter LED flashlight stiffer knobs can receive down to 219Mhz more power control settings for better battery life a priority channel button, pre-set to the official highway channel, CH19 more pre-programmed frequenicies and most important a ROGER BEEP .................affiliate link below.. Oops.. sorry.. bad habit.Ugggh, I thought the GMRS travel channel was 20? Quote
TNRonin Posted September 6, 2022 Report Posted September 6, 2022 Maybe 3 weeks! I can't wait. This is like a long ketchup commercial!Ordered May 8th. Sent from my SM-G973U using Tapatalk Quote
KAF6045 Posted September 6, 2022 Report Posted September 6, 2022 On 5/26/2022 at 1:12 AM, flashover52 said: Ugggh, I thought the GMRS travel channel was 20? Channel 20, .675, had been the FCC regulated Emergency/Traveller Assistance frequency back when a GMRS license specified two of the 8 main channels. Channel 19 had been a common CB road channel (and 9 is still considered an emergency channel) Quote
BSRMark Posted September 7, 2022 Report Posted September 7, 2022 On 5/25/2022 at 10:12 PM, flashover52 said: Ugggh, I thought the GMRS travel channel was 20? It is, and the previous poster has some incorrect info. The UV9GX comes with the Priority Channel set to GMRS Ch 28, the Travel Channel repeater. Also, there are no new battery saving features over the UV9G PRO and the new color screens aren't thimble, but rather 3 new fixed (yellow, white or red on a dark background) schemes. The power levels are also tweaked from the UV9G PRO and are close to what the UV9G LITE had way back when. Quote
KAF6045 Posted September 7, 2022 Report Posted September 7, 2022 1 hour ago, BSRMark said: It is, and the previous poster has some incorrect info. The UV9GX comes with the Priority Channel set to GMRS Ch 28, the Travel Channel repeater. Back in the day that I referenced, GMRS didn't go by channel numbers (as any authorized frequency could be assigned -- by a radio shop/dealer -- to any of the two channel slots in that class of radio), hence my inclusion of the kHz portion of the frequency, which was how one commonly referred to the authorized frequency programmed into the radio. Those radios typically had a switch or button to toggle between repeater and simplex. There was no requirement that only repeaters were usable for emergency. My mention of channel 20 was just to indicate where the .675 first appears in the "modern" consolidated channel listing. On my Midland MXT115, there is no channel 28 -- if repeater channels are active, it shows up as "20rp" when scrolling through the channels. On the hand-helds (and the DB20-G that may be getting returned for excessively LOW power output) I have named the channels similarly: simplex is named "G20 Em/Tr" and repeater is "R20 Em/Tr" (the Line A exclusion frequencies were similarly named with "...LinA" so it is easy to avoid them). Quote
BSRMark Posted September 8, 2022 Report Posted September 8, 2022 On 9/7/2022 at 12:32 PM, KAF6045 said: ... Correct. I was referring to the physical channels in the KG-UV9GX, where ch 28 is the repeater configuration for what is now commonly assigned as GMRS channel 20 (i.e. .675). There's no requirement that repeaters be used only for emergencies - in fact, all channels must give priority to any emergency traffic, including ch 20 (675) simplex or repeater, etc. Quote
TNRonin Posted September 30, 2022 Report Posted September 30, 2022 Got the radio the other day. Impressive. I need to explore it further. Wish I could open it up. Sent from my SM-G973U using Tapatalk BSRMark 1 Quote
KAF6045 Posted October 1, 2022 Report Posted October 1, 2022 On 9/8/2022 at 5:47 PM, BSRMark said: Correct. I was referring to the physical channels in the KG-UV9GX, where ch 28 is the repeater configuration for what is now commonly assigned as GMRS channel 20 (i.e. .675). There's no requirement that repeaters be used only for emergencies - in fact, all channels must give priority to any emergency traffic, including ch 20 (675) simplex or repeater, etc. In the old days, .675 was an FCC designated emergency channel usable by any licensee for /emergencies/ (this is back when one applied for TWO of the main frequency pairs, and they were listed on one's license -- you could NOT use any other main frequency; if your radio was, as many business radios of the era, only a two-channel radio [A/B toggle switch], and your license did not include .675, you had no access to the emergency frequency. If you specified .675 as one of your two frequencies, then it was available for general use. When I got licensed, the Maxon GMRS 210+3 was a desirable radio: it had the 462MHz interstitials (in 1-7), .675 (as channel 8), and channels 9&10 were "shop" programmable for the two frequencies on one's license. [While FCC regulations specified a radio shop must do the programming, they included the programming manual -- take the back off, press some button to enter #9 mode, rotate dial to select frequency, press button to enter #10 mode, turn dial to select frequency] Repeater vs Simplex was handled by a front-panel button which would toggle the current channel's state. Note the age of my call-sign -- a 3x4 vs the current crop of 4x3. BSRMark and gortex2 2 Quote
WRVR429 Posted January 1, 2023 Report Posted January 1, 2023 What antenna pins do they use? It would be nice to be able to use all the antennas I have for my Btech gmrs v2 without adapters. Im on the long wait list for mine. Its hard to float $200+ for a radio. Any comments?? Quote
wrci350 Posted January 1, 2023 Report Posted January 1, 2023 I do not have one, but according to the website it uses an SMA-Male Antenna (so it has a standard SMA female connector on the radio). The Btech radios have SMA male connectors and use SMA female antennas, I'm pretty sure. Quote
WRVR429 Posted January 1, 2023 Report Posted January 1, 2023 Oh well. Ill be buying a new antenna after I get it. Or use adapters. Quote
SteveShannon Posted January 1, 2023 Report Posted January 1, 2023 46 minutes ago, WRVR429 said: Oh well. Ill be buying a new antenna after I get it. Or use adapters. There are some very inexpensive sets of SMA adapters at Amazon that will work for many different combinations. Quote
MichaelLAX Posted January 1, 2023 Report Posted January 1, 2023 Be careful: I use an Amazon adapter to use my Ham Radio Diamond-771 on my TYT-88UV and it is definitely a dangerous spot for torque damage to the antenna connector on the HT if it gets hit in the wrong place. Quote
pcradio Posted January 3, 2023 Report Posted January 3, 2023 On 1/1/2023 at 10:39 AM, WRVR429 said: What antenna pins do they use? I have the UV9PX, same radio but firmware for HAM. My review. Its a nice radio. It takes a SMA male antenna. BSRMark and gearjunkie 2 Quote
gearjunkie Posted January 6, 2023 Report Posted January 6, 2023 On 1/1/2023 at 11:39 AM, WRVR429 said: What antenna pins do they use? It would be nice to be able to use all the antennas I have for my Btech gmrs v2 without adapters. Im on the long wait list for mine. Its hard to float $200+ for a radio. Any comments?? I'm on the list as well. As far as I know the use SMA male antennas so you just need an adapter. I just received a package of them so I can use anything including my Midland MXT12 mag mount on my roof mounting an MXT26 6db gain antenna for my truck. Also got a super flexible cable to attach to the roof antenna to any HT. Hoping my 9GX gets here soon! BSRMark 1 Quote
WRUK662 Posted February 19, 2023 Report Posted February 19, 2023 After 5 months on the waiting list, I received notice my KG-UV9GX has shipped. My order # was in the 130xxx range. I also ordered the Smiley Slim Line Whip. Received my Ed Fong DBJ-UHF antenna kit last week. I completed a CERT program via our county sheriff's office a couple of months ago. Now studying for my HAM Extra class exam. Major snowstorm will impact us middle of the week. WA7HPK BSRMark and Chimborazo 2 Quote
