MichaelLAX Posted December 27, 2022 Report Share Posted December 27, 2022 4 minutes ago, Borage257 said: There may also be a firmware update you need. Most new radios should already have it. For sure: CHIRP will not update firmware. Quote Link to comment Share on other sites More sharing options...
Borage257 Posted December 27, 2022 Report Share Posted December 27, 2022 2 minutes ago, MichaelLAX said: For sure: CHIRP will not update firmware. No, it won’t. I think you can find directions to the firmware update here https://www.miklor.com/COM/Review_UV5X.php Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted December 27, 2022 Report Share Posted December 27, 2022 3 minutes ago, Borage257 said: No, it won’t. I think you can find directions to the firmware update here https://www.miklor.com/COM/Review_UV5X.php Could you provide the exact link for firmware download; the Miklor link seems to only provide the CPS software download. Quote Link to comment Share on other sites More sharing options...
Borage257 Posted December 27, 2022 Report Share Posted December 27, 2022 Trying to find the download file. I can remember if it is part of the new CPS or a standalone file. I’ll have to check my desktop this evening. Quote Link to comment Share on other sites More sharing options...
Borage257 Posted December 28, 2022 Report Share Posted December 28, 2022 Found the files Baofeng_UV-5X_Firmware_V1.9_CPS_V2.0_Update_20210309.zip Quote Link to comment Share on other sites More sharing options...
Borage257 Posted December 28, 2022 Report Share Posted December 28, 2022 Baofeng UV-5X Firmware Update Guide_20210308.pdf Read this first. This update was to correct a CTCS and narrow band issue the first few runs of UV5x or G radios shipped with. If your radio out of the box does not have CTCS tones on the channel and is not on narrow band, you already have this firmware. WRUU653 and MichaelLAX 2 Quote Link to comment Share on other sites More sharing options...
Danjc1109 Posted December 31, 2022 Report Share Posted December 31, 2022 Did you figure it out? I have a solution Quote Link to comment Share on other sites More sharing options...
WRVG593 Posted January 1, 2023 Author Report Share Posted January 1, 2023 15 hours ago, Danjc1109 said: Did you figure it out? I have a solution I would love to hear your solution. But I did create some sort of solution for my needs. I was able to save my repeater channels to channels 30+ and just change the repeater tones to be what ineed and change the name in program. I did that so I could have a repeater anywhere i go in the state of Ohio. Would love to hear your solution!! Quote Link to comment Share on other sites More sharing options...
WRVG593 Posted January 2, 2023 Author Report Share Posted January 2, 2023 On 12/31/2022 at 9:57 AM, Danjc1109 said: Did you figure it out? I have a solution After I Downloaded BaoFengs version of chirp, it suddenly recognized the radio on the actual chirp program. Unfortunately i already programmed in every frequency up to 120! lol. What was the solution you had? Quote Link to comment Share on other sites More sharing options...
Borage257 Posted January 2, 2023 Report Share Posted January 2, 2023 30 minutes ago, WRVG593 said: After I Downloaded BaoFengs version of chirp, it suddenly recognized the radio on the actual chirp program. you likely also downloaded the cable's driver Quote Link to comment Share on other sites More sharing options...
WSAD721 Posted January 7 Report Share Posted January 7 I have a pair of UV-5G's that was purchased in Dec 2023. I have used both Chirp and the Radioditty Software with a Baofeng/Abbree PL2303 cable and was able to download and upload on either program successfully (using the Radioditty UV-5G setting for Chirp) and program channels beyond Cahnnel 30. However the minute I try to program anything outside the 462.xxx Rx frequency, it will load but no Tx. There is a local repeater that operates on 444.550000 TSQL 136.5 with a 5.000000 offset that I load into memory slot 37. It loaded fine with no need to use an xml editor to add anything but it won't transmit. Just for grins, I copied the preprogrammed setup for RPT-4 into memory slot 37 and low and behold, it does allow Tx. I also tried to modify the preprogrammed Repeater in memory position 24 and it allowed the change using the Radioditty software but no Tx. It definitely appears that the radio is locked in the firmware to only allow Tx on the 462.xxx Rx frequency with the 5.000000 offset or the 467.xxx Tx frequency. This is an older forum and I am a novice at this so I'm hoping someone has done more of a deep dive into the limitations of this radio but right now I am unable to program any Repeater channels and looking at my State using Repeaterbook, there are no repeaters that operate on a Rx of 462.xxx. So I really dont understand how this radio can even use a repeater. What am I missing here? Quote Link to comment Share on other sites More sharing options...
BeardedDragon Posted January 31 Report Share Posted January 31 On 1/7/2024 at 2:56 PM, WSAD721 said: So I really dont understand how this radio can even use a repeater. What am I missing here? Try watching this video: Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted January 31 Report Share Posted January 31 Some GMRS radios can be hacked and some can't. It's easier to just buy one that's already open like the UV-5R8W. Who said that? Quote Link to comment Share on other sites More sharing options...
WRXR360 Posted January 31 Report Share Posted January 31 If you have a BaoFeng that does not have any "issues", then you don't have a BaoFeng. My UV-5R8W has the high and low power setting reversed. Transmitted into a dummy load and the power meter displayed approximately 2 watts on high and 4+ on low. Would not have known that unless I tested it. Not a great radio, but good enough if ever needed, and the battery lasts forever, it seems. Quote Link to comment Share on other sites More sharing options...
WRWE456 Posted January 31 Report Share Posted January 31 Boy you sure get what you pay for with those it seems. 18 minutes ago, WRXR360 said: If you have a BaoFeng that does not have any "issues", then you don't have a BaoFeng. Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted January 31 Report Share Posted January 31 1 hour ago, WRXR360 said: If you have a BaoFeng that does not have any "issues", then you don't have a BaoFeng. Well, I sure am enjoying whatever these two radios are that are disguised as Baofeng UV-5R8W. Only my batteries apparently don't last as long as yours. SteveShannon and WRQC527 1 1 Quote Link to comment Share on other sites More sharing options...
edisondotme Posted April 15 Report Share Posted April 15 On 1/31/2024 at 2:33 PM, WRXR360 said: UV-5R8W has the high and low power setting reversed. Transmitted into a dummy load and the power meter displayed approximately 2 watts on high and 4+ on low. Woah, is there a way I can verify my radio isn't doing this without a power meter/dummy load/special equipment? Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted April 15 Report Share Posted April 15 (edited) 1 hour ago, edisondotme said: Woah, is there a way I can verify my radio isn't doing this without a power meter/dummy load/special equipment? On mine, I know that High power is actually High power because it is the only power setting that will hit the Channelview repeater from my house. Now, whether or not Low and Medium are reversed, I haven't done anything to verify that yet. Edited April 15 by WRXB215 Added info. Quote Link to comment Share on other sites More sharing options...
WRQI663 Posted April 19 Report Share Posted April 19 I have the same ht.....when I got it, channel 15 would not transmit (no matter what I did in chirp) I was sent a firmware update that made everything work. I never tried to program alternate channel configs until I read this thread. I just tried programming an alternate ctcss input for (rptr 2). Radioditty uv5g on chirp and it worked just fine.......I still have the zip file of that firmware upgrade. Enter the channel frequency , set duplex to "+" and offset to 5.0, uploaded to the ht and it works fine. Now I'm playing with the GM21 - I don't think I have a use for 999 memory channels though. Quote Link to comment Share on other sites More sharing options...
